JC316
02-19-08, 06:01 PM
I just wanted toask before I go tearign my door apart. If the ones from the back door will fit the front, I would be VERY happy. This is on a 98 SLS.
| View Full Version : will the rear window regulators work on the front? JC316 02-19-08, 06:01 PM I just wanted toask before I go tearign my door apart. If the ones from the back door will fit the front, I would be VERY happy. This is on a 98 SLS. mtflight 02-20-08, 06:20 PM Well you know I don't speak from experience, but on RockAuto, I see some of these listed as "Front Left and Rear Right" so it's possible. Then again, I'm sure you would not be surprised if they are mislabeled coming from them. 1998 CADILLAC SEVILLE SLS 4.6L 281cid V8 MFI (Y) : Body-Interior : Power Window Motor Item Price Core Total A-1 CARDONE Part # 42128 {[Window Lift Motor] Reman.} Front Left; Supplied w/Gear;Supplied w/o Regulator; Part numbers may be reversed on some models. Physically check unit off vehicle Rear Right; Supplied w/Gear;Supplied w/o Regulator; Part numbers may be reversed on some models. Physically check unit off vehicle $29.79 $7.00 $36.79 A-1 CARDONE Part # 42129 {[Window Lift Motor] Reman.} Front Right; Supplied w/Gear;Supplied w/o Regulator; Part numbers may be reversed on some models. Physically check unit off vehicle Rear Left; Supplied w/Gear;Supplied w/o Regulator $29.79 $7.00 $36.79 CARDONE SELECT Part # 82129 Front Right; Supplied w/Gear;Supplied w/o Regulator; Part numbers may be reversed on some models. Physically check unit off vehicle Rear Left; Supplied w/Gear;Supplied w/o Regulator $37.79 $0.00 $37.79 DORMAN Part # 742104 Front Right & Rear Left RH Front or LH Rear; Motor Only $37.79 $0.00 $37.79 DORMAN Part # 742105 Front Left & Rear Right LH Front or RH Rear; Motor Only $37.79 $0.00 $37.79 ACI Part # 82977 {Power Window Motor} w/ Metal Gear; Front Right w/ Metal Gear; Rear Left $38.79 $0.00 $38.79 ACI Part # 82978 {Power Window Motor} w/ Metal Gear; Front Left w/ Metal Gear; Rear Right $38.79 $0.00 $38.79 CARDONE SELECT Part # 82128 Front Left; Supplied w/Gear;Supplied w/o Regulator; Part numbers may be reversed on some models. Physically check unit off vehicle Rear Right; Supplied w/Gear;Supplied w/o Regulator $43.99 $0.00 $43.99 ACDELCO Part # 25649704 {W/MOTOR} REGULATOR,FRT S/D WDO RIGHT HAND * Non-stock item--shipping delayed up to 12 business days $230.79 $0.00 $230.79 ACDELCO Part # 25649705 {W/MOTOR} REGULATOR,FRT S/D WDO LEFT HAND * Non-stock item--shipping delayed up to 12 business days $230.79 $0.00 $230.79 JC316 02-20-08, 06:23 PM Hmm, I guess the best way is to take the door panel off and look. I need to anyway, try and fix my speaker. mtflight 02-20-08, 06:39 PM Hmm GMParts has different part numbers for each single motor: GM Part # Category Description Pack Qty Unit Price *25649704 Front Door Window Regulator/Motor REGULATOR 1 $217.62 *25649705 Front Door Window Regulator/Motor REGULATOR 1 $217.62 *25719488 All REGULATOR 1 $214.69 *25719489 All REGULATOR 1 $214.69 ewill3rd 02-20-08, 06:45 PM I wouldn't bet on it, I don't recall them looking very similar, the insides of the doors are shaped differently. JC316 02-20-08, 08:25 PM I wouldn't bet on it, I don't recall them looking very similar, the insides of the doors are shaped differently. Yeah, i know, but the regulator itself could be the same. It's just a bar with pullies and a motor on it. | |
