View Full Version : 2 things in my 96 deville
96DEVILLE2LOW
02-19-08, 01:04 AM
i know you all have a lot of these threads when it comes to the traction control light abs light on, both have been on for a while now
is it the computer, sensor, etc?
also i was wondering if a really good code reader would be able to read
my friend has shop with some pricey code readers , ive been meaning to stop by and see if anything comes up
i know the codes but will it tell me if its a sensor or something
also my passenger side tweeter will randomly have a loud static noise
ive never opened the panel or messed with it
even does when the cars off
id appreciate it if someone can steer me in the right direction
ill have some pics of my car up soon
chubbyranger
02-19-08, 07:01 AM
:welcome: Pull your own codes: http://www.cadillacforums.com/forums/cadillac-tech-tips/55172-how-pull-codes-got-codes-warning.html
And translate them here: http://myweb.accessus.net/~090/dtcobd2.html
That will get you started on whether its a computer, sensor, etc.
misfit6794
02-19-08, 11:35 AM
Your abs/traction control issue is a wheel speed sensor, the traction control and abs work off that sensor. The crappy part is that it is intergrated into the wheel hub, so you have to replace the entire unit. Once you pull the codes you will know which one has failed. You also don't have first gear, since it disables when the trraction control is disabled.
The tweeter sounds like a loose wire.
x69x442x
02-20-08, 12:32 PM
I already said this on another thread but my alternator was going bad and the abs and trac control light would come on. My speakers would also make weird noises because there was not enough power to run them(I am guessing). Check your voltage and see if that is your problem.
96DEVILLE2LOW
02-20-08, 04:09 PM
i tried looking for my codes
i couldnt find anything even close to them
here they are
PZ1558
PC0603
TP1552
TC0047
RS0030
RF25060
96DEVILLE2LOW
02-22-08, 04:02 PM
Ranger
02-22-08, 06:19 PM
Go to the link Chubby posted and scroll down to Typical DTC Prefix. With those prefix's you can figure out if your DTC is a body, chassis or powertrain code.
