View Full Version : Visor plaques
BillM
02-18-08, 08:26 PM
My last car was a Chry 300M Special. I found nicely made plaques ( covers) to put over the ugly yellow safety stickers on the visors. They were brushed alum looking with the Chry logo engraved into them. Heres a link showing them... http://www.ptwarehouse.com/accessories/interior/visor.htm#chrysler
I searched around the forum but didn't find anything. Has anyone seen this for Caddy's
PygmySurfer
02-18-08, 09:04 PM
Instead of covering the stickers you should be able to remove them pretty easily. Just warm them up with a hair dryer.
proexpert
02-18-08, 09:09 PM
Has anyone successfully removed these from a 2008 CTS?
BillM
02-18-08, 09:59 PM
I haven't tried this on my CTS, but the stickers on the 300m were fused into the fabric. Those safety stickers weren't supposed to come off.... ever!
Zymurgy
02-18-08, 10:59 PM
Try C6DecalDesigns (http://www.c6decaldesigns.com/page10.htm). While he started with Corvette (C6) stickers, he has expanded to C5 and other car makes. The link shows an example of a Cadillac crest logo. Whatever you want, he can do it for you.
davidaugust111
02-19-08, 07:58 PM
I peeled mine off easily with a hair dryer. It leaves an adhesive "shadow", but it FAR less obnoxious than the stickers.
auraph
02-19-08, 08:23 PM
Also removed mine as did DavidAugus111. It took some time for mine to heat up enough to start a good "peel" but then it came off easily.
calcustom
02-27-08, 09:17 PM
Has anyone sucessfully removed the left over adhesive after removing the yellow warning labels, and if so what did you use?
Southern
05-04-08, 03:28 PM
Here's another way to approach the problem.
You "could" put a Cadiilac seal there........
http://www.c6decaldesigns.com/Page2.htm
gm_eng
05-04-08, 03:44 PM
I took mine off with a hair dryer. Had to heat them up pretty good to get them loose. To get the adhesive off I used a product called Goo Gone. Worked good.
badblkcts
05-27-08, 10:28 PM
sorry to bring back an old thread, but did the goo gone stain the cloth visors? i took my stickers off and there is a slight blue shadow.
gm_eng
05-28-08, 08:13 AM
Goo Gone did not stain my visors. But instead of spraying it on the visor and then rubbing it (I worried about the visor absorbing it), I sprayed some on a paper towel and rubbed the remaining adhesive off. I also found, the hotter I got the sticker initially, the less adhesive remained and the easier it peeled off. The cooler the sticker, the more it wanted to stretch the visor material when pulling it off. I used the same method on the visors and seat stickers on my Corvette.
