: Please Name this part/valve
wildrage
02-09-08, 01:23 PM
I noticed that a vacuum line attached to it had broken off. A piece of the valve had broken off into it, so it neads to be replaced. It is located in the rear of the engine compartment, driver's side, just below the cowl. It has 2 large lines connected to it and one small vacuum line. Pic attached. Thankks.
frank moran
02-09-08, 03:11 PM
from what I can see it may be the power brake booster check valve??
R-Caddy
02-11-08, 08:57 PM
I think the same. I had to replace mine because of broken nipples.
wildrage
02-12-08, 07:43 AM
Yup. Mine has the same problem. I have it on order online. About $8
