: head gasket seeping oil
jcurry
02-08-08, 02:30 PM
Has anyone with a 2002 or 2003 sts had a headgasket seep oil into the vally from the fwd end of the right head? It looks like the area where a oil path to the top of the head (cams) might be.
AJxtcman
02-08-08, 06:57 PM
I have seen this.
I would need your VIN to answer this question better
jcurry
02-08-08, 08:30 PM
Thanks I knew someone has seen this. I will get the vin number and post it for you. I assume the fix is replacing the head gasket.
jcurry
02-09-08, 01:29 AM
Heres the vin no. 1g6ky54922u189904
Ur7x
02-16-08, 11:04 AM
Are you sure it is leaking at the head gasket? Its more likely that a sloppy kid at Jiffy Lube spilled oil at the fill and drained oil down the front side of the motor.
