View Full Version : Oil pan sumps: Eldorado vs. stock Deville 368
fslay
02-06-08, 09:03 PM
Sorry guys, not trying to beat this topic too much, but I'm in a bind of sorts trying to find out if the sump on a '70 Eldorado oil pan would be farther back than a stock Deville 368 oil pan. The 368 pan appears to be a rear sump unit, but is causing clearance problems in my old truck. I've only got enough money to buy one oil pan and need the most clearance possible. I appreciate your help more than you know.
jsharpe
02-08-08, 11:51 PM
The Eldorado sump is at the back to accommodate the right drive axle. Look here: http://www.gmcmhphotos.com/photos/showgallery.php?cat=3378
jsharpe
02-09-08, 12:37 AM
Here's an Eldorado Pan *****and ***** Rear Drive Caddy Pan
fslay
02-11-08, 02:50 PM
The RWD caddy pan I have appears to be rear sump. The sump, while near the back, is set forward a couple of inches. Those couple of inches are what's killing my install. I hope that the Eldorado pan might spare a couple by being set a little farther back
montrosepatriot
02-12-08, 12:45 AM
There are 3 oil pans used with the 472/500/425/368 family - front sump (68-76 RWD), rear sump (Eldorado), center sump (77-85 RWD).
