: My motor rebuild -pics
stkshkr
02-05-08, 09:26 PM
Bob at EPP sent these today.... I'm getting excited
Engine(382 cu in)
New LS6 Block
New SLP double roller timing chain and blueprinted oil pump
Callies Compstar 4.00 Crank
Compstar forged rods with ARP bolts
Diamond custom forged pistons 9:1 static compression ratio
ARP head studs
Balanced assembly
Cadillac racing lifters
ATI harmonic balancer
Comp Cams custom grind 228/238 .571”/.585” 113LSA +1 advance
Heads
Comp chromemoly push rods
Yella Terra 1.7 ultra lightweight roller rockers
Patriot Gold dual valve springs with titanium retainers
Ported and polished by BES, racing valve job
Transmission
RPM transmissions Stage V rebuild
TCI scattershield and trans blanket
New Textralia QZ700 Z grip clutch with 18# billet steel flywheel
http://img2.putfile.com/thumb/2/3521204420.jpg (http://www.putfile.com/pic.php?img=7623697)
http://img2.putfile.com/thumb/2/3521204431.jpg (http://www.putfile.com/pic.php?img=7623692)
http://img2.putfile.com/thumb/2/3521204423.jpg (http://www.putfile.com/pic.php?img=7623694)
http://img2.putfile.com/thumb/2/3521204425.jpg (http://www.putfile.com/pic.php?img=7623695)
StealthV
02-05-08, 09:42 PM
Clean new aluminum looks so pretty. :)
Any particular reason for staying with a 5.7L instead of 6.0+?
StealthV
02-05-08, 09:44 PM
Before going too much further, get the buffing wheel out and polish that thing! :D
rand49er
02-05-08, 10:23 PM
Whoa, Gene, thanks for this update! Love it, so far.
What's goin' on top? An MP122?
stkshkr
02-05-08, 11:27 PM
I stayed with the 5.7 because I had already ordered custom pistons, crank and cam, then they discovered the crack in the block when they put the torque plate on.
The old Maggie is going back on till next winter, then a Procharger.
Also having EPP put sub frame connectors and a motor brace on, may also upgrade the fuel system in prep for the Procharger.
When I get it back I've got the Lingenfelter launch control and PLX boost gauge to put on.
Nutz
02-05-08, 11:52 PM
Did you get to see it with the pan off to see the freaky tight tolerances that the crank operates in? :bonkers:
Anything done to the bottom end (main caps area) to hold boost?
Looks good, bet it sounds better.
stkshkr
02-06-08, 12:11 AM
No didn't get to see it.
No girdle, just what's listed above
Dennisscars
02-06-08, 01:13 AM
I'm responsible for a number of the beer cans that were sacrificed in the making of that block..
Beautiful...:thumbsup:
10secTy
02-06-08, 01:13 AM
What do you plan to do for the fuel system? Is there a intank upgrade pump for the V? Also what is the Lingenfelter launch control?
Thanks
Nolan
trukk
02-06-08, 08:05 AM
Awesome build. I'd love to go forged one day, up my compression, and do a max effort 383 N/A. Baby steps for me though. Need to finish cam first :D
Is that CAM going to be a good blower cam, isn't that a lot of overlap?
Make sure Bob sends a vid of the startup.
-Chris
stkshkr
02-06-08, 08:46 AM
Thanks
Nolan
Probably 2 walbro pumps
Sometimes referred to as a 2-step or launch controller, the LNC-001 can be used to provide consistent launch rpm off the line in drag racing and standing start road racing applications. In turbocharged applications the use of the LNC-001 also allows the engine to build more boost off the line during the launch.
The LNC-001 can also be used as an adjustable individual cylinder rpm limiter, providing reliable and fast acting spark based engine rpm limit control. This is especially useful in vehicles that have auxiliary fuel control systems where it is not possible to make sure that both the factory ECM/PCM and the auxiliary systems both turn off fuel at exactly the same time. Ff the two don’t completely cut fuel at the same time, instead of having an RPM limiter you will likely go dangerously lean, risking severe engine damage.
"Is that CAM going to be a good blower cam, isn't that a lot of overlap?"
Cam was speced by PatrickG, should work great
10secTy
02-06-08, 09:47 AM
Would you mind taking some pics of this if you do it? I use 2 walbro's all the time on Syclone/Typhoons and it works great. I just was not sure how they would fit in the V's fuel bucket.
Thanks
Nolan
stkshkr
02-06-08, 05:06 PM
Glad to, when I get it back
Washin
02-07-08, 11:27 AM
TCI makes a scattershield for a T-56?
stkshkr
02-07-08, 12:17 PM
Yes, contact Bob at EPP, it has to be trimmed a little I believe
onebadcad
02-07-08, 01:07 PM
Gene,
Sounds great!!! That 9.0:1 compression will allow 20+ psi, you may be looking at single-digit runs in the future:lildevil:.
stkshkr
02-08-08, 03:14 AM
More pics
http://img2.putfile.com/thumb/2/3803130670.jpg (http://www.putfile.com/pic.php?img=7637739)
http://img2.putfile.com/thumb/2/3803130613.jpg (http://www.putfile.com/pic.php?img=7637738)
rand49er
02-08-08, 07:11 AM
Gorgeous ... just gorgeous.
Love the porting/polishing pics. Did you leave the rear pulley setup stock?
stkshkr
02-08-08, 12:56 PM
Yes it's stock
onebadcad
02-08-08, 01:57 PM
Gene,
You may want to explore the rear pulley, as my 112 saw big TQ gains after the unit was overdriven. Here are the graphs:
Before overdrive work:
http://i167.photobucket.com/albums/u150/onebadcad/Darren_scott_CTSV.jpg
After overdrive work:
http://i167.photobucket.com/albums/u150/onebadcad/05_CTSV_nonmeth.jpg
I cannot find a chart from a Dec 2006 pull which was at 510/560, but as you can see the difference and there are no other mod changes than the work Magnuson did with the rear pulley.
stkshkr
02-08-08, 03:53 PM
Looks good, how much did they charge you to do that and how long did it take? PM if you like
onebadcad
02-08-08, 11:04 PM
Gene,
My tuner called in a few favors and got it done for free. I think Magnuson did the work in two days.
I think you and Bob together could figure out how to do it if the techs at Magnuson shipped the parts to you along with the instructions.
theloanman219
02-09-08, 01:20 PM
That is insane! Im very jealous :)
trukk
02-11-08, 02:03 PM
Since the first graph is Dyno Jet Corrected WP, and the Second is Standard Correction, you are actually looking at larger change than stated below. :eek: :thumbsup:
-Chris
Gene,
1QUICKV
03-27-08, 06:54 PM
So do you like the clutch so far?? I'm going to order one really soon after i hear from ppl. I'm goin to order
http://www.byunspeed.com/product_info.php?manufacturers_id=293&products_id=5857&osCsid=49b0e4c9be31a7ab7d224f1747ce03de
Or anybody no a better replacment thats not over 800 bills, by car is stock but it get driven hard some times, and the only reason i want to replace is very very hard shifts the pedal does' not return. I want to get a flywheel disc and a flywheel because i believe the fly wheel is off balance????
Help me out.... other wise i'll just buy not knowing..........
Thanks a lot
MauiV
03-27-08, 07:26 PM
Thanks a lot
Have you changed the clutch fluid? Mine had stuck on 3 different occasions during hard 2nd to 3rd shifts. I just got my 50K service done and clutch/tran flush and service. Seems great so far.
I dont recall who posted this originally but it should help you it sounds....
http://www.rangeracceleration.com/Clutch_Care.html
1QUICKV
03-27-08, 08:13 PM
yeah i did change it a couple of times, intill it was clean, didit do it, i'll try again before i order it..... but i heard at hi rpms the pressure plate cant hold the disc because f the rpms, so who know???? anyone else know?
