: Changing the cams on an STS to the SLS Cams
dwight.j.carter
02-04-08, 08:32 PM
What do I need to do ? Can I just swap the cams and my computer will still work fine ?
AJxtcman
02-04-08, 08:54 PM
Yes the PCM will work
I can tell you that one tool work the best to do this.
I am headed out to look for a new TV, so I will get back to you on the tool.
dwight.j.carter
02-04-08, 09:13 PM
I'm not in any hurry to do it. How much do the cams run and does the engine need to come out to change them ?
CadillacSTS42005
02-09-08, 01:03 PM
cheaper to buy complete heads off ebay and just use the cams from them imho
and AJ i thought the different Cam profile would cause many of the pretty little dash lights and messages to appear...
could be wrong though
AJxtcman
02-09-08, 03:17 PM
No
You and the dash lights.
Why is it that you have had dash lights come on?
I can throw a 2005 Northstar engine/powertrain assembly in a 99 Seville and I will get NO lights.
Why would I?
Trust me the VIN in different modules will not be an issue. :cookoo:
Ur7x
02-16-08, 02:59 PM
No
Why would I?
Wow, is that right? I though the 93-99 Northstars could not be swapped for a 2000-newer... Even some some of the 98-99 ones have unique cooling systems with odd ball water cooled alternators.
If this is the case this is wonderful news, the 2004 and newer FWD North*s seem to be the best of all. These can be had at yards for way less then the cost of a dealer installed timesert.
AJxtcman
02-16-08, 05:45 PM
98 to 00 have liquid cooled alternators on VIN 9 engines.
I am going to do a Tech Tip on 00 to 03 cam swapping.
NHRATA01
02-16-08, 07:12 PM
No
Why would I?
I'm not so sure that would be the case. GM programs enough changes in their PCM's year to year, that a 7 M/Y difference will probably cause some conflicts. Hell between '97 and 2002 GM had 3 different iterations of PCM programming on LS1 cars, partially a factor of using differing cam grinds and minor head casting differences over the years, and adjusting the Torque Management on the automatic cars. I would be very surprised if a '99 PCM would even work in a '00-'03 N*, as I'm sure they pulled out timing to make the switch from 91 to 87 with the associated drop in compression, and I bet if you put them on a cam doctor, the cam profiles would differ from pre and post '00. Think they made a few more changes on the 320 N*'s in RWD versions later on.
Also if the odo mileage is stored in the PCM, and if it does not match the mileage stored in the instrument panel, it will cause a program conflict.
AJxtcman
02-16-08, 09:30 PM
I would use the PCM that matches the engine.
The odometer is updated from the IPC upon installation.
This is the 1st cal ID #12585501 for 2003
So far this is the last #12585554 for 2003 that I have collected.
Oh wait that would be 53 different first run Cal ID's for two car models only. The Eldo was gone.
Think about that. 50+ different Calibrations for the same size engine and transmission all in 1 year. That would be 2 engine configuration (VIN Y & 9) and two gearing options (3.11 & 3.71). They don't even mix that up between the two and they still have over 50 Cal ID's for just the Seville's and Deville's in 2003.
A 05 Deville engine will bolt into a 00 FWD Cadillac with no modes and the 00 stock PCM. It may need to have me give it a performance tune to the program to correct a rough idle.
With that said I can install an 00 Deville's complete powertrain assembly including the wire harness and PCM into a 98 Seville. I would need to relocate a few wires in different terminals of connectors. You would not need to string new wires they are already in the connectors. Example: connector C101 terminal A5 may need to go to terminal D14.
The complete powertrain assembly not just the engine.
STS 310
02-19-08, 05:12 PM
SmoothTS
05-20-08, 05:03 AM
Any updates?
Mark C
05-20-08, 06:20 PM
Is this true for all cadillacs after a certain year? I've got a 2002 Deville Analog Dash cluster that i want to swap into my 2000 Deville with the digital dash cluster, and don't really want to pay someplace 300 bucks to make the new ODO match the old one. I've been delaying the swap because I wasn't sure if the car would update the readings from one of the onboard control modules, or if it was kept in the cluster itself. I don't want to end up with a car that has lower mileage on the odometer than the title and annual inspections report.
AJxtcman
05-20-08, 08:29 PM
The Cluster/IPC stores the mileage.
Mark C
05-21-08, 07:52 AM
So the cluster and the IPC are the same thing? In other words the IPC is in the part containing the speedometer, tach DIC etc?
MisterBlue
05-21-08, 12:43 PM
I don't know why you'd want to do that. Do you plan to change the gears as well? The few pounds of extra torque might give a little help at low speeds, but you'd be losing HP and speed on the top end, IMHO. Of course, if your plan is to run on a short (1/8 th mile) drag strip, it might be a good move. I can't see it helping much in the 1/4 mile, though. :confused:
Highline Cady
05-24-08, 02:27 AM
00-03 SLS/Deville cams are better than the STS/DTS cams, in my opinion. Keep the 3.71 gears and grab some SLS/Deville intake cams, it's the best combo. I did that combo, I'm very happy, AJ tuned mine for the differences over a year ago, we've also done other mods but that was a good one especially seeing as we were doing the gears we dropped in a 3500 stall while it was opened up. Whole different car and it doesn't hit fuel cutoff at 112 anymore. Your STS pcm is probably an H rated tire program, good for 130, to begin with. Mine will do 150, I know it does 140, that was fast enough for me.
You won't lose anything in the 1/4 either.
