rocken
02-04-08, 02:45 PM
Help my 91 deville is idle out of control i replaced the idle control sensor and the pigtail and i fired it up and its rpms are about 7ooo and i dont know what or where to go next please help me:(
| View Full Version : Help my 91 cadilliac deville 4.9 rocken 02-04-08, 02:45 PM Help my 91 deville is idle out of control i replaced the idle control sensor and the pigtail and i fired it up and its rpms are about 7ooo and i dont know what or where to go next please help me:( Ranger 02-04-08, 08:33 PM Press on the plunger till it retracts. When it bottoms out, pull the plug. Set the gap between the plunger and the throttle linkage to .060. Plug it back in and you are done. carnut 02-05-08, 01:29 PM With the key on, engine off, open the the throttle and as Ranger says, depress the idle solenoid shaft till it fully retracts, then release the throttle arm. Then quickly disconnect the ISC electrical connector. You should see a small air gap between the throttle and the shaft. If not, screw in the shaft gently till you get .060 gap. Then turn key off, wait 10 seconds and restart the car. It should race for a few seconds then calm down to approx 600 RPM. Do this with the climate control system off. Once idling normally, turn the climate system back on to AUTO mode. You should see the ISC shaft extend just before the A/C compressor engages. I'm sure you meant 700 RPM not 7000!!! rocken 02-18-08, 06:50 PM no i meant 7000 rpm shes going crazy but ill try that guys thanks :bonkers: rocken 02-18-08, 07:17 PM hey guys i tried pushing on the screw on the idle speed control it didn't go in am i doing it right or not i turn the key to the on position and push nothing happen HUF 02-18-08, 07:37 PM It moves very slowly when you press it. You should keep the throttle lever up with one hand and push the ISC motor plunger with other. If it does not move at all, the switch inside the ISC motor is bad. HUF 02-18-08, 07:40 PM no i meant 7000 rpm shes going crazy but ill try that guys thanks :bonkers: 4.9 cannot make 7000 RPM... carnut 02-18-08, 08:23 PM No way!! 7000 RPM at idle? The fuel will shut of way before that. We can only assist or try to help with proper clues. carnut 02-18-08, 08:27 PM You might try taking the idle motor back off, reconnect the pigtail to it then with key on, car off, retract it in the palm of your hand with your thumb. Thats assuming you repaired the pigtail correctly and have power to the idle motor. | |
