View Full Version : 4.9 water pump
NellMac4621
02-03-08, 01:55 AM
i am about to replace my water pump on my 4.9. me and my cousin are going to jump on it. he's done it before and this is my first time doing it. do any one 1 no how long it should take if person does it.
kdcing
02-03-08, 09:29 AM
Your question is not worded well and is difficult to understand...it appears that you are asking how long it will take for one person to change the water pump. Is this the correct interpretation?
On my '93 Eldorado w/ a 4.9L, it took about 2 hours to complete the job (including draining and refilling the cooling system). The job is not difficult, however, several of the bolts/nuts are difficult to access because that are very near to the subframe/cradle....just enough space for a small hand. Btw, having a 2nd person will not significantly increase the speed of the replacement as there is only enough space for 1 person to work on it at a time.
noahsdad
02-03-08, 10:24 AM
Agreed. Mine took a little longer, about 4 hours total. I ran into trouble when the head stripped on one of the Torx bolts. I had to drill it with a right angle drill and then tap the block - not fun in that tight space. A Cadillac tech told me it's not all that uncommon, so be very careful when removing the Torx bolts.
If you want to read more about my experience (with pictures) click this link:
http://cadquest.blogspot.com/2007/08/water-pump-challenge-august-2007.html
NellMac4621
02-05-08, 12:39 AM
thanks a lot for the help. sorry about the wording on my last post I was in a rush. it took me about 4 hours to do it and now i got my baby back:thumbsup:
Lithorian
02-13-08, 09:44 AM
LOL noa u and I ahd the same problem with the exact same bolt, know what i did to it? I didnt havea right angle drill, so i cut the bastard off! and RTV'd the livin hell out of the area around it, 4000 miles and not a drop of coolant lost!
