View Full Version : pcm1106
mpayton4
01-29-08, 11:33 AM
ok i have a 97 sts and have been trying to diagnose a morning hard start. it take 3-4 key turns 30 seconds each turn to finally get it started. once it starts it will start for the rest of the day 1st turn. i have cleaned the tb, replaced the fuel filter, performed a fuel pressure check which is 30 psi at key turn to on, and 40 psi when running.( i already know that these readings are low, i just want to exhaust all starting possibilities before replacing the dreaded fuel pump) I just had this pcm 1106 pop up with a history label to it? what exactly does this code mean and could this be my hard start problem. what exactly can i check to see if there is a problem with the map sensor? where is the map sensor, can i test it somehow?
any help would be greatly appreciated.
BigJon
01-29-08, 11:42 AM
http://www.cadillacforums.com/forums/cadillac-tech-tips/55172-how-pull-codes-got-codes-warning.html
go there and it will explain how to get them and tell you what they are..
i got this off my all data
manifold absolute pressure map sensor circuit intermittent high voltage p1106
boricuacaddy
01-30-08, 07:55 AM
Hi, did you check your FPR? (Fuel pressure regulator) also you might check your injectors. One or more may be leaking, which would cause a hard start. I have 2 that are leaking and giving me a hard start in the mornings. I still have warranty left in my car that will cover that.
David
mpayton4
01-30-08, 10:15 AM
David
HOW DO YOU CHECK INJECTORS
submariner409
01-30-08, 12:37 PM
Go to the FSM and look for injector replacement. It involves removing any obstacles in the way of the 8 injectors and fuel rail, then lifting the entire assembly out of the cylinder heads in order to check leaks with a quick "key on" maneuver by an assistant.
Careful....you'll be working with atomized gasoline if one or more have leaks.
There are several threads in here and N* performance about fuel rails and injectors.
