: Need a reliable source for Northstar Torque specs
01-29-08, 02:10 AM
I am timeserting a 98 Northstar engine and was looking for the best place to find current torque specs for Northstar head bolts, cam shafts, and oil pan for example. I found M11 cylinder head bolts first pass 30 ft. lbs. , second pass +70 degrees, third pass +60 degrees, final pass + 60 degrees. Does anyone know a good source for newest torque settings?
01-29-08, 06:38 AM
GM's Northstar TimeSert procedure (http://www.cadillacforums.com/forums/cadillac-tech-tips/122133-gms-northstar-timesert-procedure.html)
Case Halves Reseal...FWD RTV Sealant Procedure with Current Oil Distribution Plate (http://www.cadillacforums.com/forums/cadillac-tech-tips/117232-case-halves-reseal-fwd-rtv-sealant.html)
93 to 99 Northstar dis-assembly and inspection (http://www.fiero.nl/forum/Forum2/HTML/082157.html)
93 to 99 O/H assembly (http://www.fiero.nl/forum/Forum2/HTML/080614.html)
if you follow the links you will get all the information and more.
01-29-08, 06:42 PM
Thank You very much AJxtcman.
