: Fuel pressure regulator?
01-27-08, 06:23 PM
I have quick question - is this part in picture fuel pressure regulator?
It seems seeping very small amount gas - just little bit wet outside
So i think it is time to change it - or has it some kind of gasket there, what is repairable?
01-27-08, 06:43 PM
Yes, that is it. While idling, pull the vacuum hose off of it. If there is any fuel present at the nipple, replace it. If the leak is at the base where it is mounted, The "O" ring is either installed wrong or damaged and needs to be replaced.
Be sure to relieve fuel pressure before removing the retaining clip.
01-27-08, 06:49 PM
Thanks Ranger!
I test it first thing in tomorrow morning.
Yes. its seems leaking from O ring, so it is easier fix i hope. Well, after blower motor change everything feels easy :D
01-28-08, 07:31 PM
took me less than 5 mins to change mine, very easy job...
