View Full Version : Anyone know the Frontal Area Spec (in Sq Ft) on the STS-V ?
CIWS
01-25-08, 06:51 PM
I searched through the net and couldn't find the specification of the frontal area on the STS-V (in Sq feet), only an estimated figure on the STS. Anyone out there have that number somewhere ? I'm trying to get a CDA (aerodynamic drag) measurement for the car. I've found drag coef @ .33
Slo-Mo-Shun
01-26-08, 04:43 PM
For the purpose of aero calcs, the frontal area should be (height - ground clearance to spoiler) x width. If you want to get picky you can add in the mirrors. Frontal area is a 2 dimensional figure so it doesn't matter that the highest point is not at the "front." The drag coefficient is where the streamlining and other 3D factors get counted.
CIWS
01-27-08, 11:32 AM
Thanks for the info, but I'm really kinda looking for the spec as stated by Cadillac/GM for the car. :)
edit - since this doesn't seem to be readily available info, I've gone ahead an e-mailed some folks at GM to see if they can get it for me.
ssstealth
04-14-08, 01:03 PM
Drag area, Cd (0.32)
Frontal area (26.3 sq ft, est):
This is for the standard STS, GM is not required to calculate the frontal area of the "V" option since it does not break the 33% production threshold. If you really want to be more confused, check out the 12 page EPA instructions on how to calculate this figure...
http://www.epa.gov/OMS/cert/dearmfr/ac_73.pdf
LITTLEELVISDAN
04-15-08, 10:36 AM
here is a real stupid question. Wh7y would you want the exact CD? It's not too dissimmilar from the STS and then again why would this be so important to know.
CIWS
04-15-08, 12:24 PM
One of the input numbers a gadget uses to calculate horsepower. CDA, weight and a couple of other numbers I can't remember off the top of my head. :)
