View Full Version : I give up! AMP bypass instructions?
wrenchr
01-24-08, 02:08 PM
OK so I tried the 3rd gmos-06 and it still doesn't work properly! So I guess the next thing is can I bypass the bose amp crap but keep the speakers? Hoping someone can shed some light on this.
Specs again...
trying to put a Pioneer D3 Nav,bluetooth,xm setup in my 1999 Cadillac SLS
Thanks for any help,
Frank
dwight.j.carter
01-24-08, 03:57 PM
If they are bose speakers no you will need to replace them as well and run new wiring.
wrenchr
01-24-08, 04:34 PM
What should I do about the SUB? I'm not needing a high end setup.. The bose sounded GREAT to me. Anyone know the sizes on all the speakers?
Thanks for the info
Frank
dwight.j.carter
01-24-08, 04:45 PM
I never tried re doing mine because it sounded so good. You should have tried to get a factory dvd nav. Cadillac STS 2003 knows how to re wire it to fit into the 98-01 sevilles. All that would need to do is the dealer would have to reprogram the theft lock on the new unit. In answer to your question though I would think 6 1/2 speakers would fit in the doors but up front I would recomend using components.
wrenchr
01-24-08, 10:04 PM
I thought the factory nav was having problems? Something about causing a module to fail? And it was more involved than a reprogram.
Frank
CadillacSTS2003
01-25-08, 01:49 AM
enjoy replacing EVERYTHING
as thats what you must do now
wrenchr
01-25-08, 12:22 PM
I have one other option....A new car/truck...lol
I've been looking for a while but haven't found one yet. Will just have to move up my schedule
Thanks for all the help! Just my luck I'd have the year that is a pain in the ass. lol
Frank
GattiB
01-25-08, 03:23 PM
i am lost, how did you know he would need to replace EVERYTHING now just from that thread . . .?
ryansts
01-25-08, 03:39 PM
As for the sizes of the speakers, there are 3 2.5" highs on the dash, 8s in the front doors, 6.5s in the rear doors (but aftermarket 6.5s won't bolt in) and the sub in the rear deck is similar in size to an aftermarket 12". You'd basically have to make custom adapters for everything if you want to replace the speakers. Plus, there are very few aftermarket setups that incorporate a center channel (the speaker in the middle of the dash).
dwight.j.carter
01-25-08, 07:18 PM
This is true and why I chose not to change mine. I just added satelite radio and am fine with what I have. I may add subs though to the bose system though I know it will never sound as good as it would hooked up to an aftermarket head unit.
MrGifford
02-08-08, 11:32 PM
Is your 99 sls a Head unit going to a self amplified Bose setup? If It is the same as My 93 seville you do NOT have to rip everything out as people like to tell you. I posted about this before. It was something like "Head unit integration success". And I'm glad to say it still sounds GREAT! right down to the Best of Kansas cd I was just listening to. Very crisp and clean.
Good luck I hope it is the same for you
MrGifford
02-08-08, 11:40 PM
I'm not sure if the people that I mention in this post have the harness you need but they were very helpfull to me. Good luck
"93 Seville Bose self amplified/Sony Hu Success!!"
