: Control arm bushing question
AwfulSmokey
01-23-08, 05:15 PM
On our lower control arms, we have 2 bushings and the ball joint. Are the 2 bushings the same and 1 is just sideways?
elvin315
01-23-08, 07:00 PM
No. They are both very different. See numbers 2 & 3.
http://i.pbase.com/g6/69/14969/2/85551427.XA8HO0RV.jpg
Elvin
AwfulSmokey
01-23-08, 07:46 PM
I can't see the picture for some reason.
elvin315
01-23-08, 08:33 PM
Here's another try.
http://www.pbase.com/elvin315/image/85551427
Elvin
AwfulSmokey
01-23-08, 10:41 PM
I have seen that schematic. If you look what number 2 means.. it says lower control arm. Like i said it looks like the same bushing, only sideways. There was no part number/name for 2. I have two number 3's. I'm getting ready to order for the other side,i went to gmpartsdirect and i ran across that schematic. I was like hmmm is the front different? That brings me here.
gmpartsdirect doesn't show a different listing. I dont like the setup on the site for searching. Does anyone know for sure if they are different or not?
elvin315
01-24-08, 05:11 AM
This isn't the first time we've delt with front bushings. No diagrams here but this listing shows 2 distinct part numbers. The bushings are different.
http://www.rockauto.com
SPICER Part # 5651329 {CHASSIS CONTROL ARM BUSHING}
Front Suspension; Lower Rear $22.89
SPICER Part # 5651330 {CHASSIS CONTROL ARM BUSHING}
Front Suspension; Lower Front $44.99
cateraowner
02-11-08, 12:08 PM
sorry to pull this thread up again, but I've been told a couple months ago that I need "lower control arm bushings- both sides"
does these 2 parts come with both sides? (meaning 2 to each set?)
also does this sound like symptoms of worn control arm bushings?
-I hear a (and kinda feel) a clunking towars the front of the car under my feet.
- this happens when the suspension is at full lenght or at full compression.
- also this happens more often during cold mornigs, as it warms up it pretty much goes away (pretty much cause I've never really test it so I'm not 100% positive)... but now that it's friggin cold out it never warms up enough so I hear it all the time.
- most noticable when I go through intersections that has a gradual hump in it at about 50km/hr or so.
I'm gonna change my bushings any ways, but I was wondering if there was anything else I should look into.
(I also have warn outter tie rods that I'll be replacing at the same time.)
sorry, when it comes to suspension I know next to nothing.
