: Need help finding some part numbers for the CTS-V intake and rear suspension bolts
verbs
01-20-08, 07:24 PM
Any help would be greatly appreciated!
I need to find out what the part number is for these bolts in the picture with the red arrows:
http://www.obesitydiscussion.com/forums/imagehosting/164793e36460438.jpg
this is what those bolts look like up close:
http://www.obesitydiscussion.com/forums/imagehosting/164793e3649adb3.jpg
I also need to find out what the part number is for the bolts that hold down the cold air intake box where the red arrows are, as well as the part number for the stock rubber air tube (see the blue arrow) that connects the MAF sensor to the throttle body and any clamps/rubber grommets used to hold the rubber air tube on the throttle body and MAF sensor.
http://www.obesitydiscussion.com/forums/imagehosting/164793e364df39b.jpg
Thanks in advance!
verbs
01-21-08, 02:51 PM
tttttt
verbs
01-22-08, 05:14 PM
Anyone???? Puhlease :D
lunarx
01-23-08, 11:01 AM
Forward a link to this post to:
Luke at Lindsay Cadillac.
LButler at LindsayCadillac dot com
He will hook you up. :D
cobrayankee
01-23-08, 11:31 AM
Go to www.gmpartsdirect.com, scroll yo the bottom for the catalog, put your vehicle in and use the diagrams.
verbs
01-23-08, 07:18 PM
Go to www.gmpartsdirect.com (http://www.gmpartsdirect.com), scroll yo the bottom for the catalog, put your vehicle in and use the diagrams.I tried there already and couldn't find any of it. :(
SkullV
01-23-08, 08:00 PM
Is there a particular reason you dont just go to the harware store and get new bolts? Are the factory bolts important? I have the entire factory intake for an LS6 with bolts if you really need the factory stuff.
1badjimmy
01-24-08, 01:24 PM
These bolts are P/N 89058602.
The bolts holding the airbox down (red arrows) are P/N 11588831.
The tube going from the MAF to the throttle body (blue arrow) is P/N 25750705.
The clamp at the throttle body as well as the one between the MAF and the intake tube is P/N 25750696.
trukk
01-24-08, 01:42 PM
Wow, imaginary points to 1badjimmy for that response. :yup:
-chris
