: Catera V8 by Lucky Cowboy
elvin315
01-19-08, 08:05 AM
Checking out CarDomain and found this:
click
http://memimage.cardomain.net/member_images/3/web/2955000-2955999/2955374_9_full.jpg (http://www.cardomain.com/ride/2955374)
The owner, Jeric, has swapped the 3.0L V6 for a 5.7L V8. His page says he's still working on it but the engine and transmission are in. The engine is carburated and the tranny a 4 speed manual so no ECM headaches. It wouldn't pass emissions tests in NY but he's in Texas so maybe it's different there. I invited him to come and tell us about the project. There's been a lot of discussion here about the V8 swap but this is the first time, other than Catera V's Cat, that I've seen one get to this stage. I wish him luck and hope he stops by.
Elvin
CadillacSTS42005
01-19-08, 09:46 AM
not bad
R-Caddy
01-19-08, 06:20 PM
I was rhinking about doing the same thing! But here somewhere I read that EBTCM is not a standalone computer, and I would like to keep my ABS and TC even if I remove the ECU and tranny computer.
P.S. for now, we are putting a 305 in my friend's '83 Malibu Wagon on Sunday. :stirpot: The stock 3.8 V6 crapped out... :alchi:
Warez
01-20-08, 04:40 PM
The ABS is stand alone. The TC is not becuase the EBTCM has to tell the engine to cut timing and shut off fuel injectors. So when you remove the ECU, this is not possible.
sccatera97
01-20-08, 07:44 PM
Looks like the engine is sitting awfully high in the engine bay. It would have to be high to clear the cross member and probably had to severly modify the oilpan to clear the steering. Being that high, he probably had to modify the firewall and trans tunnel to make it fit. I would like to see how it runs afterwards.
R-Caddy
01-21-08, 09:06 PM
So, I will still have ABS but not TC? That's fine I guess...
big1keg
12-30-12, 12:18 PM
im in the process of dropping a 350 30 over mild cam turbo 350 trans in a 00 catera have the oil pan figured out email me if you have any questions big1keg@gmail.com
elbrown4183
02-09-13, 02:41 AM
Eeeek! Catera Blasphemer! Put that back in a truck where it belongs! :-)
