View Full Version : 4.9 and spark knock
Brizzal
01-15-08, 10:24 AM
does anyone know much about spark knock on the 4.9? ive had it for the longest time now.... :thepan:
cadillac_al
01-15-08, 01:31 PM
Is the EGR system clean? Do you think it could be running hot? I run regular fuel in mine and it never knocks. Maybe I'm losing power and the computer is retarding the timeing but she never knocks and has plenty of pep.
awadecki
01-15-08, 03:04 PM
The computer won't retard the timing on 4.9s, there is no knock sensor. Cadillac al, your timing is probably conservatively set.
Brizzal, your EGR valve is probably sticking closed. Push up on the underside of the diaphram and see if it moves. If it doesn't, you'll need to replace the valve.
Brizzal
01-15-08, 11:19 PM
any pics on what the egr looks like or where it is? ive never worked on it before. thanks :)
HUF
01-15-08, 11:51 PM
Behind Throttle Body , looks like 3" diameter mushroom with a vacuum line attached to it. Please search the archives for EGR , knock, etc. Tons of info. May be a lot of things besodes the EGR valve. Look for vacuul leaks as well clogged EGR tubes inside the trottle body, under the plates.
