View Full Version : brake line busted??
JmOz
01-08-08, 09:41 PM
98 sts. yesterday in my driveway, i go in my car to switch cars in my driveways. i push on the brake and it goes all the way down. makes like a air pressing noise?:hmm:. i get out and look and a big brake fluid is on my driveway. i dont know if its one line or what. i turn the car off and try to pump the brake it gets a bit harder but i can still push it all the way down. how much you think it is to fix and everything??
submariner409
01-08-08, 09:47 PM
Exactly where and under what was the puddle of fluid? That will give you an idea of whether you're in the steel line replacement mode (PITA) or a flex hose to an individual caliper (messy but simple and cheap). Or even a blown caliper puck, not too difficult but $50 +/-.
arrow1965
02-24-08, 07:48 PM
I also have a 97 STS and my brake line rub a hole in it. I called GM and told them but they said they would not do anything about it. It is a safety issue and I think they should stand behind it, it is a design problem.
raymondk
02-26-08, 11:15 AM
There are two porportioning valves one on each rear line. I have had mine dump all the fluid in a few days. Note also that the dual master cylinder is connected crossways: ie. left front and right rear on one, etc.
arrow1965
02-26-08, 01:36 PM
Does anyone else have a brake line leak?
arrow1965
02-26-08, 01:38 PM
Does anyone else have a leak brake line problem on 97 Seville
