: Transmission issues
reif
01-08-08, 01:35 PM
ok, so my girlfriend's 01 catera is having some issues with the transmission.
we were driving back from a our winter vacation going ~70mph on the highway when the sport mode light turns on and all the gear indicator lights on the gear selector turn on, the car didn't seem to suddenly downshift or have any immediate issues. we pulled off to the side of the road and turned off and restarted the car, the sport light was off now, but all the indicator lights were still lit up. the first time we tried to accelerate the care hesitated to go into second, only getting there with a substantial clunk which triggered the blinking sport light again. since then the seems to shift up smoothly (though the sport light will start blinking the first time the car shifts gears) but it will not shift down unless the gear selector is moved to one of the three manual gears.
she took the car to a mechanic (not a Cadillac specialist) who seems to think a brake sensor is causing this issue, which seems really off to me.
from what I've read here, and experienced on my own car it seems to me that it would be and issues with low or fouled transmission fluid (hasn't been changed in ~90k miles :tisk: ), the TCM, or the PRNDL sensor. this car seems a lot more complicated than the 20+ year old cars I'm used to working on, so I'm kind of doubting myself
Am I right in my thinking? is there a known issue with some braking component causing this sort problem (maybe abs speed sensor?), or is there something else I haven't considered yet?
any help would be appreciated :worship:
dwheeler
01-08-08, 08:40 PM
I don't know if there is a brake sensor relation to the transmission, but my 97 just did the same thing. I have a code reader and it said that a transmission component slippage. I was going to check the fluid but can't find a dipstick for it. I was going to hope that changing the fluid might help, but I do fear that it will turn into another big ticket fix.
MyOpel
01-08-08, 09:20 PM
Just had this happen on my car. Go to a place that will scan the codes for free, they will probably tell you it's PO705 Automatic Transmission Manual Shaft Shift Position Switch AKA PRNDL sensor. If you live in Canada $410 just for the part, I got it from SPDC for about 150. Dont drive the car much until this is fixed.
BackStreet
01-09-08, 05:31 PM
There is no dipstick on a CAT but there is a fill/overflow hole.
All you have to do is jack up the car on that side, remove bolt, squirt in fluid, put a pan under, jack down to remove extra fluid, jack up to put bolt back.
Way easy on a lift. Just fill to bottom of hole.
passionaterage
01-09-08, 07:17 PM
Thats a good way to add the fluid and get it the right level, just be sure the car is at operating temperature and RUNNING (in park of course) when you do all that. Some people may not know that and just do the "jack-up-add-fluid" thing and wayyyy too much will run out, causing the level to be WAY low. Just thought it should be clarified.
PEETYZ
01-10-08, 05:42 PM
you could change fluid and add a bottle of lucas tansmission fix use whole bottle of lucas and mix in fluid till full Lucas will renew worn bands and helped my transmission but you will hear mixed thoughts about it but first check fluid level and change/add accordingly best of luck
reif
01-11-08, 08:31 PM
well heres an update:
she ended up moving the car to a transmission specialty shop nearby, it turns out the transmission is pretty much shot. the fluid basically got so bad it managed to cake everything up. but a new tranny(used) is in there, and everything seems to be working, fine, but the car is going to stay under the mechanics observation till the end of the weekend.
so thats going to be a lesson well learned, never forget the transmission fluid.
KateraK
01-12-08, 02:56 PM
I have a 1998 catera and I had the same problem, and I too replaced the tranny, and it did fix it.
BUT now its happening again and I thought noooo it cant be another bad tranny!!!! So i looked at the connectors on and around the tranny housing. They were a little oxydized so I cleaned them out and now it shifts just fine and is back to normal, so I looked at the tranny i replaced and it is still good, just a dirty connector.
My two cents.
my ABS and TCS and check engine light are still on though and I have no speedometer still but the tranny still shifts good in drive at least.
BTW I have went through school for automotive repair and received a degree but no longer work on cars for a living, so I pretty much know what im doing, just dont always know the problem lolz.
but anyway i hope this helps someone, dont forget dielectric grease on all connectors!
edit
eastsidercaddy
01-12-08, 11:48 PM
to fix the ABS/TC light you may want to look at replacing the fuse. I have a switch wired to my fuse, so when it rains i can burnout and do doughnuts. If that's not it then don't worry about it.
KateraK
01-13-08, 01:07 AM
I have a TCS button that is factory i can press so i can burnout but my complaint is that my speedo doesnt work, im pretty sure its the EBTCM though ima check er out tomorrow prolly
MyOpel
01-13-08, 10:35 AM
Your speedo gets its signal from the right rear abs sensor
Xaphoeous
01-27-08, 05:56 PM
My two cents.
edit
Could you please explain where and how I should look for these connectors on the transmission? I had this problem today, the PRNDL lights all on but randomly changing, winter 3rd gear start contantly on, can't shift past 3rd gear...etc. I unplugged the number-5 fuse from the panel (TCM fuse) and it now shift fine, but the PRNDL lights are still going nuts.
Where can I find the connectors that might be oxidized and need to be cleaned?
Thanks!
Just_me
03-06-08, 04:57 PM
My 2000 catera with 80K miles on it has a problem shifting when the car starts running only when its cold and not worm enough. If I drive it that way before you know it often times the "S" sports mode light starts flashing and then the car can't shift hears no more. I was thinking maybe I need to change my transmission fluid, but it seems so complicated so I wanted to get more help. I think I found the drain plug, but it seems like its a bit high, so I was wondering if that will get all the oil out. And one big question is where is the fill hole located? I can't seem to find it, is it located somewhere really close to where the drain hole is? I just don't want to unscrew anything extra. And I was thinking if that would be okay to just change the oil and not the filer, withough going through so much trouble. It's just im not even sure if the oil is causing the problem. Also, what kind of transmission oil would be recommeneded? and how much oil should be in the transmssion? Thanks!! :)
Xaphoeous
03-11-08, 11:52 AM
Just_me, my problem ended up being the Transmission Range Switch. It was about $390 for the part and labor at my local Cadillac dealership. The "drain plug" you're speaking of is also the fill hole, I think. If you're not broke, I'd recommend taking your car to a Cadillac dealership. You're probably better off paying a few hundred bucks to get it done right, than to "save" money by doing it yourself, just to eventually get it towed to a dealership for a new transmission after doing something wrong.
mdksupra
01-12-11, 04:08 PM
Ttt
ttt
hgqguy
01-14-11, 08:42 PM
The catera tranny fluid filter is not hard to change. the trannys do have 2 differant pan shapes, so be sure to get the correct one. I think it takes 8 qts of fluid, but not 100% on that. you do not need synthetic fluid in a 2000 but may in a 2001.
drop the pan to drain. replace filter and reinstall. there is the fill plug in the side. you have to fill it untill fluid spils out.. and as I learned here.. car need to be running in park so that the fluid fills everywhere.. otherwise it will not get enough fluid. the car has to be leval, IE on a lift, or evenly lifted on jack stands. you fill the hole till it leaks out, then replug and all done!
be sure you have something to refill with.. its impossible to just pour out of a bottle. they make a suringe ESP for this kinda tranny. Good luck!
