Bill@hptuners
01-02-08, 10:35 PM
Help File (www.hptuners.com/help)
HPTuners Forum (http://www.hptuners.com/forum/)
Installing-NEW!
Running HPTuners installer (http://www.thetuningdoctor.com/HPTuners/FlashDemos/installer.swf)-NEW!
Installing MPVI Drivers (http://www.thetuningdoctor.com/HPTuners/FlashDemos/MPVIDrivers.swf)-NEW!
Pinging your hardware also referred to as resyncing your licenses (http://www.thetuningdoctor.com/HPTuners/FlashDemos/pinghardware.swf)-NEW!
General
Saving a VCM Suite Info Log (http://www.hptuners.com/forum/../help/demos/infolog.swf)-NEW!
VCM Editor
Reading your VCM (http://www.hptuners.com/help/demos/Read%20Entire%20VCM.swf)
Writing Calibration to the VCM (http://www.hptuners.com/help/demos/write%20to%20vcm.swf)
Failed VCM Calibration Write - VCM Recovery (http://www.hptuners.com/help/demos/write%20with%20recovery.swf)
Changing Fan Settings - 160 Degree Thermostat (http://www.hptuners.com/help/demos/160%20Thermostat.swf)
Applying a 1 Bar SD Enhancement (http://www.hptuners.com/help/demos/1%20bar%20sd%20apply.swf)
Applying a 2 Bar SD Enhancement (http://www.hptuners.com/help/demos/2%20bar%20sd.swf)
Using the Compare Feature (http://www.hptuners.com/help/demos/Compare%20Feature.swf)
Gear Change for 98 LS1 Fbodies (http://www.thetuningdoctor.com/HPTuners/FlashDemos/98gearchange.swf)-NEW!
Using AutoVE/AutoTune/Copy Paste Special feature (http://www.thetuningdoctor.com/HPTuners/FlashDemos/copypaste.swf)-NEW!
Changing Decimal Precision (http://www.thetuningdoctor.com/HPTuners/FlashDemos/IncreaseDecreaseprecision.swf)-NEW!
Licensing a file/pcm (http://www.thetuningdoctor.com/HPTuners/FlashDemos/licenseafile.swf)-NEW!
Applying a RTT(Real Time Tuning) Custom Operating system (http://www.thetuningdoctor.com/HPTuners/FlashDemos/RTTapplication.swf)-NEW!
Applying a RTT(Real Time Tuning) Custom Operating system and Using it via the VCM Suite Scanner (http://www.thetuningdoctor.com/HPTuners/Live%20Screen%20Recordings/CamaroRTTeditedcustomsized.html)-NEW!
Quickly Change Units of measure (http://www.thetuningdoctor.com/HPTuners/FlashDemos/Unitchange.swf)-NEW!
Using the Comparison Copy over All feature to quickly copy over a starter tune (http://www.thetuningdoctor.com/HPTuners/FlashDemos/copyoverall.swf)-NEW!
VCM Scanner
Adding and Removing PIDs (http://www.hptuners.com/help/demos/add%20remove%20pids.swf)
Creating a Custom PID and Adding a Custom PID to the Histogram (http://www.hptuners.com/help/demos/Creating%20and%20Adding%20a%20Custom%20PID.swf)
Creating a user defined EIO Input (http://www.hptuners.com/help/demos/custom%20EIO.swf)
Standalone Data Logging (http://www.hptuners.com/forum/../help/demos/standalonelogging.swf)-NEW!
Creating and Saving Custom Histograms (http://www.hptuners.com/forum/../help/demos/customhisto.swf)-NEW!
Using Plot Filtering in Histograms (http://www.hptuners.com/help/demos/using%20plot%20filtering.swf)
Using Bi-Directional Controls (http://www.thetuningdoctor.com/HPTuners/FlashDemos/VCM%20Controls.swf)-NEW!
Reading and Saving DTC's (http://www.hptuners.com/forum/../help/demos/dtc.swf)-NEW!
Performing a CASE learn (http://www.thetuningdoctor.com/HPTuners/Live%20Screen%20Recordings/CASELearn1.html)-NEW!
Forum Demos-NEW!
Adding Attachments to a post or thread (http://www.thetuningdoctor.com/HPTuners/FlashDemos/addingattachment.swf)
MISC
Taking a screenshot (http://www.thetuningdoctor.com/HPTuners/FlashDemos/screenshot.swf)
Creating a User Defined Output (http://www.hptuners.com/help/demos/custom%20EIO.swf)
Stock OS 1 bar SD Tuning How-To using a wideband oxygen sensor (http://www.hptuners.com/help/vcm_editor_tuning_how_to_user_sd.htm)
HPTuners Editor quick start guide (http://mysite.verizon.net/whenn1/Microsoft%20Word%20-%20HPTUNERS%20EDITOR%20STARTUP%20GUIDE.pdf)
Installing-NEW!
General
VCM Editor
VCM Scanner
Forum Demos-NEW!
MISC
