View Full Version : north swap
PhillyCaddy
05-09-04, 07:07 PM
I just like to know if a 94 eldo north could replace a 96 deville northstar. and if not what would it take to do so.
DaveC
05-09-04, 08:15 PM
94 intake manifold /head interface is different from 95/99. 95/99 NS would be the way to go. Need to use the intake manifold/throtle body from the 96.
DaveC
PhillyCaddy
05-09-04, 08:50 PM
I have a 96deville with blown heads and have 94 eldo wreck with good engine. this is why I ask. just trying to make things work if possible.
If I swap intakes would that work.
DaveC
05-10-04, 01:01 AM
96 intake will not work on the 94 engine. I'm not completely sure on this but I don't think the 96 wiring harness will work with the 94 intake. Maybe someone else can help on that issue. Also fuel rail connections could be a problem.
Lawrence
05-10-04, 02:41 AM
Search for user "dloch". He is doing the same thing. You have to add holes to the 94 heads to use the 95+ intake, among other things.
dloch
05-10-04, 10:37 AM
You can't just swap the intakes from 94/95 to 96/97 engine. Here are the links to the information you are looking for. If you have any other questions I think I can help you out as I have done this... and you will have to have to drill and tap some additional holes, close the others but it can be done. I used the intake itself as a guide to do the drilling and longer than normal drill bit. You will also need to use a .409 drill bit to open the end holes since the intake gasket uses them as locating spots.
The electrical issue I can't answer just yet as I'm not quite that far yet. As a far as the fuel rail and the location of the connections some are different, it depends on what car the engines came from and are going into although you can swap that stuff from one to another, not a big deal.
http://www.cadillacforums.com/forums/showthread.php?t=11408
http://www.cadillacforums.com/forums/showthread.php?p=88849#post88849
http://www.cadillacforums.com/forums/showthread.php?t=11015
Like said if I can help you out let me know.
PhillyCaddy
05-10-04, 07:04 PM
well I just might be parting out the 96 deville if all that must be done. not sure yet. or maybe I might just do the head gasket. I rather not play to much with them.
Thank you all for the info.
If I part out, I will let you all know.
