Iansts
12-28-07, 02:54 PM
Hello,
I have read everything I can find on this subject on this forum as well as other forums. Here is a brief history of my cooling problems.
1.) Water pump was leaking fixed by local shop, I personally did a pressure test of the cooling system afterwards and check out fine.
2.) Took car back to shop, for them to help me figure out way the COMPUTER displayed on the dash the car was getting hot. Found that the Rad cap upper seal was missing, replaced cap idiled the car at the shop for over and hour everything was fine.
3.) Again when driving down the road the COMPUTER displayed temp said it was getting hot (around 250) pulled over let it cool check fluid level which was ok.
4.) Checked both cooling fans working fine at 2 speeds.
5.) Now in process of reseting the Computer by disconnecting the Battery for a spell.
Next on my list may be a thermostat replacement? Gold pellets (gold seal same thing) worked well temporary on the leaking water pump? Last on my list would be the dreaded pressure test for head gasket loss? Could the COMPUTER be giving me false information? (the car has not actually boiled over). I understand the STS operating temp is higher than most normal cars, but a temp higher than 230 concerns me.
Any help or Ideas would be welcome. If possible also give me an idea were non obivious parts my be located ie: temp. sensor etc. this car is new to me and do not have a repair manual yet.
Thanks Ian (newbe)
Thanks Ian (newbe)
