View Full Version : Rear seal recall
Benjamin Simon
12-21-07, 02:02 PM
http://www.msnbc.msn.com/id/22359333/
Is this the rear seal everyone was/is having trouble with?
Force-1
12-21-07, 04:34 PM
GM recalling 313,000 vehicles to fix fluid leak
By KEN THOMAS
Associated Press
WASHINGTON — General Motors Corp. said Friday it was recalling about 313,000 passenger cars and crossover vehicles to fix a fluid leak that could lead to the driver losing control of the vehicle.
The recall involves 275,936 vehicles in the United States, including the 2005-2007 Cadillac CTS and STS sedans, 2005-2007 Cadillac SRX crossovers, and 2006-2007 Pontiac Solstice and the 2007 Saturn Sky convertibles. About 38,000 additional vehicles are under recall in Mexico, Canada, the Middle East and Asia, GM said.
GM said the seal on the rear axle pinion, which provides power to the wheels, does not meet all specifications and could leak fluid. GM spokeswoman Carolyn Markey said the leak could lead to the drivewheel jamming up and locking while the vehicle is being driven, possibly causing the driver to lose control.
There has been one crash reported in which the rear wheels locked because of the leak and hit another car. In a separate incident, a driver reported an injury after moving around in the car as the vehicle lost control.
Markey said there have been "a higher than normal" number of warranty claims because of the problem.
The recall is expected to begin in February 2008 and dealers will replace the pinion seal free of charge. Owners may contact Cadillac at 800-982-2339, Pontiac at 800-620-7668 and Saturn at 800-972-8876.
http://www.businessweek.com/ap/financialnews/D8TLUN281.htm
northlites
12-23-07, 03:49 AM
:eek:Now they tell us !
I've had my STS for 3 years. So far so good, but this recall doesn't bring
really good news. It makes you want to resume bad habits like drinking
while driving.
ewill3rd
12-23-07, 01:44 PM
I posted a copy of the notice from GM advising us that this recall will probably begin in February.
Watch your mailboxes for a letter from GM about any affected vehicle.
Check here and when people start having it done you can call your dealer and have them check GMVIS to see if your vehicle is affected.
rb92gt
12-24-07, 12:52 PM
Huh! If your rear diff does not leak, I would be cautious letting the dealer touch your diff. Mine still leaks after 4 dealer visits including replacing the entire rear diff. Seems like a serious design flaw, not just quality control anymore.
dkozloski
12-24-07, 03:14 PM
Fifty or more years ago automotive shaft seals were made from leather. In fact, the largest producer was Chicago Rawhide. Leather seals were very reliable but would weep a very small amount of fluid. The answer was to change the sealing material to synthetic rubber or plastic. These seals can be made totally leak free but are not anywhere near as rugged as leather and are subject to catastrophic failures. Sometimes the best progress is a step backwards in time.
Ernie Short
12-24-07, 04:21 PM
My differental locked up at 70MPH and luckily the spider gear shattered and unlocked the differential. I was able to drive (with much rearend noises and vibrations) to a rest area and called roadside assistance. The dealer in Joplin, Mo told me it looked like the differential never had fluid in it. The car had a little over 5000 miles. The replaced the differential. Subsequently the seal had to be replaced at about 15000miles and is leaking again - so back to the dealer to get the seal replaced again. Nice of GM to issue a recall in 2008 for a problem that surfaced in 2005. Guess they were waiting for someone to get hurt.
ascariSTS
12-25-07, 05:14 PM
Ernie
Didn't you notice the leak below the car ?
Guys,
Is there any chance that the leaked fluid doesn't reach the floor ?... meaning, do I have to check the car from down instead of the floor ?
ewill3rd
12-25-07, 08:28 PM
It could leak and not make a puddle, have the car inspected if you are scared.
Otherwise wait for the recall.
corvette00
12-26-07, 11:00 AM
My 07 leaked a puddle. I asked Cadillac for recommendations on garage floor cleaners. My 07 has had two front end leaks and the rear seal issue. Leaks appear to be fixed, no suggestions on floor cleaners yet.
ascariSTS
12-26-07, 11:43 AM
ewill
mine was leaking... They replaced my seal.. no more leak.. but I dunno...
What would the recall do for those who replaced it several times and it's still leaking ?
ewill3rd
12-28-07, 09:16 PM
The recall will likely involve an inspection procedure. If the new design seal is not in place I suspect that they will have us install the new design seal. Even if the seal has been replaced before, if it is the old style I am confident that your dealer would intall the newer design part.
As I have said though, until it comes out in print from GM it is all speculation.
pjbizjak
12-30-07, 11:49 AM
YEP, there it is, a little puddle on garage floor right below the rearend differential. 2007 STS with 11k miles. Touched puddle with my fingers and then smelled and felt it, sure smells and feels like some kind of lubrication. I'm not waiting for the recall since the car is still under warranty, calling dealer Monday.
ewill3rd
12-30-07, 05:16 PM
Make sure they are aware of the TSB so they don't install the original seal. I think the parts catalog already reflects the proper part numbers so maybe they can't even do it by accident.
You might mention that you heard of the TSB to your advisor.
sapien
01-05-08, 12:34 AM
thanks for the info, good to know and something to check as I just bought an '05
Galvatron808
01-15-08, 03:12 PM
Just had mine fixed today. Service writer said don't wait for recall, fix it now. I asked if there would be a recall gasket to fix the problem but he didn't know. Hope I don't have to go back for the same thing again.
TobyJohnson11
02-01-08, 03:19 PM
Just wondering if anyone has any new info on this topic? Now that its Feb can we call Cadillac and find out if the recall affects our cars?
Cajonkev
02-01-08, 03:55 PM
If you are leaking then definetely get it in regardless. If not...
Spoke to my Service Manager two weeks ago when I was in and he was waiting for GM to issue the replacement part numbers. He was unsure as yet whether they had a new part ready and was not authorized to do warranty replacements unless there was an active leak.
As with mine which has been fixed already; if there is a new part then even the previous repairs will have to be brought back in.
WillySTS
02-01-08, 06:29 PM
Recall 07204 is on the GM VIS now, our dealer is ordering the recall parts now.
ewill3rd
02-01-08, 08:19 PM
Yes the recall is out!
Don't go all in at once, there might not be a huge supply of parts yet and a lot of dealers might not be carrying them.
Subject: Product Safety - Drive Axle Seal Leak-Replace Seal #07204 - (01/31/2008)
Models: 2005-2007 Cadillac CTS, CTS-V, SRX, STS
2006-2007 Cadillac STS-V
2007 Daewoo G2X
2007 Opel GT
2007 Saturn SKY
Condition
General Motors has decided that a defect, which relates to motor vehicle safety, exists in certain 2005-2007 model year Cadillac CTS, CTS-V, SRX, STS; 2006-2007 model year Cadillac STS-V; 2007 model year Daewoo G2X and Opel GT; 2006-2007 model year Pontiac Solstice; and 2007 model year Saturn SKY vehicles. The drive axle differential seal (two on all-wheel drive vehicles) may leak because it does not meet GM's specifications. If a seal is leaking, there will be fluid on the ground where the vehicle is parked. If enough fluid leaks, the differential will become noisier because of reduced lubrication. After about two-thirds of the differential fluid is lost, the bearings may no longer be lubricated and may start to overheat. Damage to the bearings and other differential components could then occur. Damaged bearings will create noise that may be heard by the vehicle occupants. If the vehicle is not repaired and damage progresses, three conditions can occur: (1) When the vehicle is stopped and shifted to reverse, the differential may jam and prevent vehicle movement; (2) the damage can cause drag that will feel like the brake is applied; or (3) the differential could jam and lock the drive wheels while the vehicle is in motion. If (3) occurs, the driver may not be able to control the vehicle and a crash could occur without warning.
Correction
Dealers/retailers are to install a new drive axle differential seal (two on all-wheel drive vehicles).
Vehicles Involved
Involved are certain 2005-2007 model year Cadillac CTS, CTS-V, SRX, STS; 2006-2007 model year Cadillac STS-V; 2007 model year Daewoo G2X and Opel GT; 2006-2007 model year Pontiac Solstice; and 2007 model year Saturn SKY vehicles built within these VIN breakpoints:
Year
Division
Model
From
Through
2005
CTS
50207119
50237751
2006
CTS
60100001
60213969
2007
CTS
70100002
70198445
2005
CTS-V
50207126
50234392
2006
CTS-V
60102809
60209495
2007
CTS-V
70100001
70197204
2005
SRX
50207077
50237338
2006
SRX
60100011
60222963
2007
SRX
70105009
70193999
2005
STS
50207130
50237744
2006
STS
60100019
60222184
2007
STS
70100056
70197027
2006
STS-V
60104156
60217940
2007
STS-V
70100060
70195959
2007
Daewoo
G2X
7Y136494
7Y140874
2007
Opel
GT
7Y111678
7Y142685
2006
Pontiac
Solstice
6Y000001
6Y120195
2007
Pontiac
Solstice
7Y103375
7Y142882
2007
Saturn
SKY
7Y100001
7Y142740
Important: Dealers/retailers are to confirm vehicle eligibility prior to beginning repairs by using the system(s) below. Not all vehicles within the above breakpoints may be involved.
-- GM dealers and Canadian Saturn retailers should use GMVIS.
