cadmat
12-19-07, 11:56 PM
I've noticed this a few times, i can only hear it if the windows are open.. This car is not driven but a few times a month, but I always make sure part of the trip is a few minutes to an hour of freeway speeds. always starts right up, choke drops down properly after warm I bump it, the engine is so smooth that I can't tell if it's on at stop lights, but after it's driven awhile, I notice a little pre ignition gergle under load at low speeds ( under 25 ish) what should I check first?
car has about 140000 miles, and was tuned up about 2500 miles ago ( a year and a half ago) , plugs, wires etc.. not sure if the carb was serviced any further then simple adjustments.. passed an emmissions test at about the same time with flying colors.. I've wondered if a sea foam treatment may be in order.. never did it, but it always seemed like a good idea.. What do you think?
Thanks, Matt
Thanks, Matt
