CADILLAC_GUY
12-13-07, 02:16 PM
Hey guys, i'm new to this board and have been reading a lot of the threads where similar problems have been discussed, however i'm having a hard time understanding a few of them. I'll start out by explaining my situation.
Problem 1... My car was having some intermittent startup issues before it completely decided to not crank over anymore but before all the intermittent problems occured, when it would crank, it sounded pretty weak. The solenoid engages because i hear it click. Now how exactly does this starting system work? When i enter the key i hear the security clear beep, then i try to crank and i hear the solenoid engage, does the starter have an additional relay as to tell it that it's ok to enable itself? or does the soloenoid do all the talking for it, sort to speak?
Attempts to troubleshoot/resolve problem one:
Used battery Cleaner at possitive battery side post and terminal. (Noticed corrosion)
Used a multimeter to obtain a voltage readout at battery. (Read 12.1volts)
Tried a jumpstart *i know, bad idea* (Did nothing, still same solenoid click.)
One day i was at the airport waiting for my parents with the car off and hazard lights on and i saw some white smoke come through the top of the steering wheel cylinder cover. I immediately shut the hazards off but i dont know if this has anything to do with it?
Problem 2:
Below 1,000 rpm my car at (Idle) seems to shake a lil not all of the time, but it's very annoying. ... During problem one, i had the hood up turned the key and it started, before failing of course and i heard a POP sound..kind of like a backfire.. could this be the Fuel Pressure Regulator? I will be constantly checking this thread for any advice/help one can provide.. Thanks, Jaime
Problem 2:
