: Need part numbers
il capo
12-12-07, 04:02 PM
Ok I have searched many times and didn't see the parts numbers for the HCV, oil cooler seals, cps, and outside temp sensor. Any help would be good. Thanx guys.
12-12-07, 05:09 PM
I can help you with the outside temp. sensor. I just got one for my car. The part number is 9152245, and I got mine from gmpartsdirect.com for $13.40. It won't have a picture of it, it will just say "sensor" when you type in the part number, but it is the correct sensor.
il capo
12-12-07, 05:34 PM
cool that helps since Napa has 2 and one is an ac ambient sensor and another one, so I wasn't sure.
il capo
12-30-07, 05:04 PM
Ok got the HCV solved but still need part #'s for the seals on the oil cooler or washers, which ever they are. Are these something that can be replaced with aftermarket washers if they match up?
