View Full Version : Engine Oil Myths including ZDP by GM AJxtcman 12-11-07, 08:15 AM Over the years there has been an overabundance of engine oil myths. Here are some facts you may want to pass along to customers to help debunk the fiction behind these myths.
http://216.182.211.32/techlink/images/issues/dec07/images/6x6/fig1.jpg
The Pennsylvania Crude Myth -- This myth is based on a misapplication of truth. In 1859, the first commercially successful oil well was drilled in Titusville, Pennsylvania.
A myth got started before World War II claiming that the only good oils were those made from pure Pennsylvania crude oil. At the time, only minimal refining was used to make engine oil from crude oil. Under these refining conditions, Pennsylvania crude oil made better engine oil than Texas crude or California crude. Today, with modern refining methods, almost any crude can be made into good engine oil.
http://216.182.211.32/techlink/images/issues/dec07/images/6x6/fig2.jpg
Other engine oil myths are based on the notion that the new and the unfamiliar are somehow "bad."
The Detergent Oil Myth -- The next myth to appear is that modern detergent engine oils
are bad for older engines. This one got started after World War II, when the government no longer needed all of the available detergent oil for the war effort, and detergent oil hit the market as “heavy-duty” oil.
Many pre-war cars had been driven way past their normal life, their engines were full of sludge and deposits, and the piston rings were completely worn out. Massive piston deposits were the only thing standing between merely high oil consumption and horrendous oil consumption. After a thorough purge by the new detergent oil, increased oil consumption was a possible consequence.
If detergent oils had been available to the public during the war, preventing the massive deposit buildup from occurring in the first place, this myth never would have started. Amazingly, there are still a few people today, 60 years later, who believe that they need to use non-detergent oil in their older cars. Apparently, it takes many years for an oil myth to die.
The Synthetic Oil Myth -- Then there is the myth that new engine break-in will not occur with synthetic oils. This one was apparently started by an aircraft engine manufacturer who put out a bulletin that said so. The fact is that Mobil 1 synthetic oil has been the factory-fill for many thousands of engines. Clearly, they have broken in quite well, and that should put this one to rest.
The Starburst Oil Myth -- The latest myth promoted by the antique and collector car press says that new Starburst/ API SM engine oils (called Starburst for the shape of the symbol on the container) are bad for older engines because the amount of anti-wear additive in them has been reduced. The anti-wear additive being discussed is zinc dithiophosphate (ZDP).
http://216.182.211.32/techlink/images/issues/dec07/images/6x6/fig3.jpg
http://216.182.211.32/techlink/images/issues/dec07/images/6x6/fig4.jpg
Before debunking this myth, we need to look at the history of ZDP usage. For over 60 years, ZDP has been used as an additive in engine oils to provide wear protection and oxidation stability.
ZDP was first added to engine oil to control copper/lead bearing corrosion. Oils with a phosphorus level in the 0.03% range passed a corrosion test introduced in 1942.
In the mid-1950s, when the use of high-lift camshafts increased the potential for scuffing and wear, the phosphorus level contributed by ZDP was increased to the 0.08% range.
In addition, the industry developed a battery of oil tests (called sequences), two of which were valve-train scuffing and wear tests.
A higher level of ZDP was good for flat-tappet valve-train scuffing and wear, but it turned out that more was not better. Although break-in scuffing was reduced by using more phosphorus, longer-term wear increased when phosphorus rose above 0.14%. And, at about 0.20% phosphorus, the ZDP started attacking the grain boundaries in the iron, resulting in camshaft spalling.
By the 1970s, increased antioxidancy was needed to protect the oil in high-load engines, which otherwise could thicken to a point where the engine could no longer pump it. Because ZDP was an inexpensive and effective antioxidant, it was used to place the phosphorus level in the 0.10% range.
However, phosphorus is a poison for exhaust catalysts. So, ZDP levels have been reduced over the last 10-15 years. It's now down to a maximum of 0.08% for Starburst oils. This was supported by the introduction of modern ashless antioxidants that contain no phosphorus.
Enough history. Let's get back to the myth that Starburst oils are no good for older engines. The argument put forth is that while these oils work perfectly well in modern, gasoline engines equipped with roller camshafts, they will cause catastrophic wear in older engines equipped with flat-tappet camshafts.
The facts say otherwise.
Backward compatability was of great importance when the Starburst oil standards were developed by a group of experts from the OEMs, oil companies, and oil additive companies. In addition, multiple oil and additive companies ran no-harm tests on older engines with the new oils; and no problems were uncovered.
The new Starburst specification contains two valve-train wear tests. All Starburst oil formulations must pass these two tests.
- Sequence IVA tests for camshaft scuffing and wear using a single overhead camshaft engine with slider finger (not roller) followers.
- Sequence IIIG evaluates cam and lifter wear using a V6 engine with a flat-tappet system, similar to those used in the 1980s.
http://216.182.211.32/techlink/images/issues/dec07/images/6x6/fig5.jpg
Those who hold onto the myth are ignoring the fact that the new Starburst oils contain about the same percentage of ZDP as the oils that solved the camshaft scuffing and wear issues back in the 1950s. (True, they do contain less ZDP than the oils that solved the oil thickening issues in the 1960s, but that's because they now contain high levels of ashless antioxidants not commercially available in the 1960s.)
Despite the pains taken in developing special flat-tappet camshaft wear tests that these new oils must pass and the fact that the ZDP level of these new oils is comparable to the level found necessary to protect flat-tappet camshafts in the past, there will still be those who want to believe the myth that new oils will wear out older engines.
Like other myths before it, history teaches us that it will probably take 60 or 70 years for this one to die also.
Special thanks to GM's Techlink
- Thanks to Bob Olree – GM Powertrain Fuels and Lubricants Group
http://216.182.211.32/techlink/images/issues/dec07/TLdec07e.html#story1 ncCADDYman 12-11-07, 10:35 AM damn, i feel educated after reading that post ... thanks dkozloski 12-11-07, 11:07 AM That is why the OLM system was developed by observing the operating conditions that depleted ZDP and finding a way to quantify the remaining ZDP by calculation with the ECM. The OLM knows the amount of ZDP the oil starts with and what depletes it. It keeps track of these factors and lets you know when the ZDP needs to be replenished by an oil change. I saw that article a few days ago on GM TechLink. With all the talk regarding the new oil specifications, it was an interesting read... especially since it's straight from an automaker. Cadillacboy 12-11-07, 01:07 PM Another oil thread :yup: AJxtcman 12-11-07, 02:26 PM I saw that article a few days ago on GM TechLink. With all the talk regarding the new oil specifications, it was an interesting read... especially since it's straight from an automaker.
A few weeks back I changed my oil. I kind of stopped driving the car after that. I might have 40 miles on it since. I asked the parts guys to get me some EOS. No can do:mad: To add to that we switch oils about 2 or 3 months ago and it come out of the gun with the consistency of mineral spirits. Yeah it is very thin and clear as good water on the other hand our water is black now.
My motor had about 6k on it when I had my issues and had to swap blocks and one head. When I did this repair I found major lifter wear:rant2: The oil that was put in that motor when new was GF-4, but I think it was 10W-30. Maybe we have 5W-30? I thought we had 5W-30 before that went to the runny stuff.
Anyway I have been scared that I am damaging my cams. Now I am sure that I am. You have to realise that the engine is inches from my head and the ambient temp is low, so this loud a$$ Northstar is rattling away. :cool2:
I will look for a new source of oil. EcSTSatic 12-11-07, 03:32 PM I hate perpetuating yet another oil thread but this question has bothered me. Maybe someone can ease my angst. How does one know that the OLM is working properly? Is there a self-test or something? Will I always be able to rely on it? AJxtcman 12-11-07, 04:26 PM I hate perpetuating yet another oil thread but this question has bothered me. Maybe someone can ease my angst. How does one know that the OLM is working properly? Is there a self-test or something? Will I always be able to rely on it?
This may shed some light
http://www.cadillacforums.com/forums/cadillac-tech-tips/118135-oil-life-monitor-how-does-know.html clarkz71 12-11-07, 08:02 PM I'll stick with Rotella 10/30.:thumbsup: AJxtcman 12-11-07, 08:41 PM I'll stick with Rotella 10/30.:thumbsup:
If I didn't I was going to PM you about EOS. I thought GM had a new listing under engine assembly lube.
Now I looked at the oil tanks today. The oil is listed as GF-4, 5W-30, Synblend. The tank also has a sticker for GF-4, 10W-30 supreme. I am thinking it is a seasonal thing and this season has not come yet:annoyed:
The 5W-30 is probably out of season, so it is probably on sale. That 5 cent they are saving is going to help:thumbsup: clarkz71 12-11-07, 09:01 PM If I didn't I was going to PM you about EOS. I thought GM had a new listing under engine assembly lube.
New formula EOS. Part# 88862586 You guys should have stocked up on the EOS a couple months back. I have about fifteen bottles of the old formula. :) The 396 in my '67 Camaro has a flat-tappet cam, and I do not trust the new SM standard yet. Even the diesel oils, such as Mobil Delvac, aren't as potent as they once were. It'll be interesting to see if the new anti-wear formulations are as good as ZDP in real-world usage. Considering that the move towards lessening ZDP was brought on to avoid catalyst damage, I'm not holding my breath. eldorado1 12-11-07, 09:55 PM Put some context in....
What benefit does GM have to keep our older (>10years old, out of warranty) cars on the road? Wouldn't it be better if all of our cars blew up, so we'd be forced to drive the newest models? Planned obsolescence? Conspiracy theory? ehh... I like my ZDDP, until someone proves "beyond a reasonable doubt" that it's either not necessary or causing damage. This means I want numbers!! EcSTSatic 12-12-07, 12:39 PM This may shed some light
That's good information but the question is how do you know that the OLM sensors are working properly? Are there OLM error codes in the DIC? That's good information but the question is how do you know that the OLM sensors are working properly? Are there OLM error codes in the DIC?
I'm just taking a stab in the dark here, but I bet the PCM would throw a checksum error if the OLM code wasn't working. Keep in mind that the OLM bases its calculations from various engine sensors, so if one of those went bad, it would display a DTC for that particular sensor.
Outside of those sensors, the OLM is just a program inside the PCM that calculates the estimated oil life from a set of mathematical algorithms. I surmise the only thing that would really cause the OLM to fail is PCM data corruption (and you'd probably have a bunch of other problems besides the OLM not working!). I'm not sure how Cadillac does it, but most other PCMs will perform a quick test at key-on to ensure the code and calibration data are intact. It's called a "checksum," and is really nothing more than comparing the code against an expected value. dkozloski 12-12-07, 12:54 PM That's good information but the question is how do you know that the OLM sensors are working properly? Are there OLM error codes in the DIC?
There is no such thing as an OLM sensor. It computes the remaining oil life from oil temperature, RPM, and other operating conditions. EcSTSatic 12-12-07, 05:12 PM There is no such thing as an OLM sensor. It computes the remaining oil life from oil temperature, RPM, and other operating conditions.
All of those values must have a pickup point somewhere, usually a sensor.
The checksum theory sounds reasonable if GM thought of it. No, Koz is correct. The OLM uses an algorithm in the PCM to decrement oil life based on many many inputs such as RPM, ambient air temp, engine temp, throttle position and many other factors. So it uses many "pick up points" from many sensors. I think AJ posted a thread on how it works as well as the Guru himself long ago. All of those values must have a pickup point somewhere, usually a sensor.
GM engineers more than "thought of it". They researched/tested/documented/adjusted/corrected parameters over many hundreds of thousands of test miles with a variety of GM test engines. Sufficient scientifically valid data was accumulated/documented to earn a US Patent for the GM OLM system.
Plus, the testing/documenting/parameter adjusting is a continuing process to keep pace with the progression of API lubrication oil standards.
The soft spot has been previously identified. Owners of 10 year old engines and 10 year old PCM OLM parameters are unable to purchase oils with the 10 year old API specifications.
I feel for the owners of 1970 vintage engines trying to provide adequate wear protection with contemporary lubricants. submariner409 12-12-07, 07:47 PM JimD, We run either Mondello (Engle) or Comp Cams RV flat tappet hydraulics with Cloyes double roller chains in our Olds 455 marine conversions, BUT we set them up to run Pennzoil 15W-40 Long Life truck oil at 50 psi, hot. So far we have had no premature lobe or tappet wear. Initial flat tappet breakin determines the life of the cam.
We have also set up essentially the same engine with roller tappet and roller tip rocker gear, and no problems there, either.
Perhaps a letter or very specific e-mail to one of the big cam grinders would shed some light????? I would hope they're better on metallurgy and lubrication than most........... dkozloski 12-12-07, 07:56 PM GM engineers more than "thought of it". They researched/tested/documented/adjusted/corrected parameters over many hundreds of thousands of test miles with a variety of GM test engines. Sufficient scientifically valid data was accumulated/documented to earn a US Patent for the GM OLM system.
The lead engineer on this GM program was Dr. Shirley A. Schwartz. She has won several nationwide awards and is generally regarded by her peers as being one of the foremost lubrication engineers in the world. EcSTSatic 12-12-07, 08:37 PM No, Koz is correct. The OLM uses an algorithm in the PCM to decrement oil life based on many many inputs such as RPM, ambient air temp, engine temp, throttle position and many other factors. So it uses many "pick up points" from many sensors. I think AJ posted a thread on how it works as well as the Guru himself long ago.
Koz also said there isn't a sensor. Sure there's an algorithm in the OLM, that's obvious to anyone. The point is, the inputs you both mention have to come from somewhere, and it's sensors in key areas again like you both mentioned. The question I asked was how do you know all of these sensors are working properly and sending correct information to the OLM and other vital sampling functions. That's why the checksum theory sounds plausible to me. I'm not sure if JimD is confirming that or not in his response. I think Koz meant that there is no oil life sensor. All the other sensors are monitored and will set a DTC if they fail. submariner409 12-12-07, 09:45 PM Any individual sensor which is primary to other control functions and secondary to the OLM will, if subject to fault, set a code pertaining to the individual sensor's primary task. As long as that fault remains (C)urrent, it would stand to reason that that sensor's percentage input loss would then skew the OLM to some degree. Thus the checksum proviso.......I'll bet even money that the OLM has a default oil degeneration backup to input the system during DTC and system diagnosis in the event of a sensor failure.
Yeah.....What ranger said.......! EcSTSatic 12-12-07, 10:39 PM ...All the other sensors are monitored and will set a DTC if they fail.
That's what I was looking for. Thanks!! AJxtcman 12-23-07, 06:03 PM Look everyone this did not turn into one of those oil threads:histeric:
AS Of 12-04-07 New bulletin
DESCRIPTION:
GM Vehicle Care announces our new E.O.S. (Engine Oil Supplement) Assembly Lubricant, part number 88862586. This product replaces part number 1052367. GM E.O.S. Assembly Lubricant is specifically formulated as an engine assembly lubricant that provides outstanding protection against run-in wear and piston scuffing, as well as run-in camshaft lube and lifter scuffing resulting from insufficient lubrication. clarkz71 12-23-07, 06:52 PM My last one.
http://i86.photobucket.com/albums/k120/clarkz71/HarmonicBalancerremoval001.jpg riverrat 12-31-07, 01:03 AM I just came across this thread when I searched zinc and the wear with new oils is a myth!! I guess some engine builders that have had cams wear out with new oils during break-in were just having myth problems. The new Joe Gibbs Hot Rod oil with zinc w as developed because many performance car owners are having myth wear. Torco oil a company with a long record as a premium racing oil is promoting a myth with their oils and supplements. And this well known car collector has also fallen into the myth:http://www.jaylenosgarage.com/video/video_player.shtml?vid=198306 AJxtcman 12-31-07, 08:37 AM :2thumbs: Thanks submariner409 12-31-07, 01:19 PM riverrat, In our boat engines (Olds 455) we generally use flat tappet hydraulics for cam work, and to compensate for the lack of zinc in the oil we do two things (for a unit with heavy valve springs): breakin with light valve springs, then change at 100 hours, and, use TORCO cam lube at first startup.
No wiped cams so far...Engle/Mondello units. I think CompCams puts out a breakin lube (paste) also.
I have no idea, but I'm guessing that most engines now use roller lifters or followers and maybe roller rockers, so they can get away with less zinc/phosphorus in the lube oil.
Although it's not recommended for a lot of newer engines, you can always run Pennzoil 15W-40 Long Life truck oil. dkozloski 12-31-07, 07:22 PM Lycoming aircraft engines have had some difficulties with mushroom cam followers for years and supply an oil additive containing TCP(tricresyl phosphate) as an anti-scufing agent. submariner409 12-31-07, 10:20 PM Before my wife slits my throat (company's here), Happy New Year from the +5 to the +9 (4 hours?) time zone.......
All the best, Jim AJxtcman 01-01-08, 01:29 PM Hope everone has a great new year. AJxtcman 01-01-08, 02:08 PM you all know that NASCAR switch to unleaded?
They had to work with coatings. :hmm: Yeah they coat the valves:hmm: you know with a water based product:hmm: You have to have the engine apart to do this:stirpot:
OK you can coat the cam and lifters before installing them and they should/will last with thin oils and low ZDP oils.
Think about powder coating them.:hmm: Ceramic coating them (Cermet coating)
I have used Techline Products. :hmm:
Hyperlinks
Dry Film lubricants (http://www.techlinecoatings.com/introduction.html#dryfilm)
Dry film lubricants, also known as solid film lubricants, provide a lubricating film that reduces friction, inhibits galling and seizing and in some instances can aid in dispersing heat. The appearance is generally a charcoal gray and takes on a sheen upon burnishing. They are slippery and provide an extremely low coefficient of friction.
The two most important components are the binders and lubricating ingredients. Without a good binder the coating will not stay in place and will simply cold flow or buff off in operation. Similar coatings using the same pigments but different binding systems can show a wide variation in load carrying abilities, ranging from 100,000 psi to over 350,000 psi . The pigments determine the actual lubricating potential. PTFE, as an example, is listed as having the lowest coefficient of friction (COE). However, under high speed and load, the COE of PTFE degrades while that of MOS2 (Moly) improves, until it is significantly better than PTFE. Selecting the proper ingredients can make or break a coating.
One of the obvious reasons for using a lubricating coating is to reduce friction, which improves wear, extends part life and frees up H.P. normally lost to friction. A second major benefit is a reduction in part temperature. This is especially important to such parts as valve springs. Here the pigment choice is critical as certain ingredients can trap heat in a part. Not all coatings are created equal. . It is recommended by TECH LINE that coatings using PTFE be avoided in these cases. Contact our TECH DEPT before choosing a dry film lubricant.
Coatings Application Guide (http://www.techlinecoatings.com/articles/application_guide.htm)
Internal Engine Coatings (http://www.techlinecoatings.com/Engine.htm)
TECH LINE makes available a full range of power enhancing coatings for internal engine parts that can be applied at home. These coatings are the same products being applied by professional coating shops and give the individual the opportunity to benefit from this advanced technology at a cost and time savings. For those who do not wish to do their own coating work, or wish to have TECH LINE specialty coatings applied, hundreds of professional coating shops worldwide apply TECH LINE coatings.
INCREASE TORQUE AND HORSEPOWER, INCREASE PART LIFE, REDUCE FRICTION AND WEAR
http://www.techlinecoatings.com/images/enggraph.gif
DFL-1 POWERKOTE (Dry Film Lubricant)
Part #2107
http://www.techlinecoatings.com/images/dfl1.gif
7 oz.
High pressure lubricant
Reduces friction, galling and scuffing. Increases part life
Requires no clearance changes to compensate for the coating
Apply to any part subject to sliding or rotating friction
Excellent for use on bearings
Water based no hazardous fumes
Requires baking. Cures at 300f minimum. Must be oven cured
CBC1 POWERKOTE (Cermet Coating Thermal barrier)
http://www.techlinecoatings.com/images/cbc2.gif
Part #2213
3oz.
Retail packaged version of CBC2/CBX
Designed for Performance engines.
Thermal barrier coating
Reduce part temperature.Keeps heat in combustion chamber longer through the power stroke
Increase torque and H.P. Increase combustion chamber efficiency
Reduce fuel consumption
Water based no hazardous fumes, non flammable
Requires baking. Cures at 300f for 1 hour. Must be oven cured
WSX POWERKOTE (Lubricant)
http://www.techlinecoatings.com/images/wsx.gif
Part # 3401
1 oz.
Designed for cylinder walls, lifter bores and valve guides
Extreme pressure and temperature lubricant
Can carry loads up to 350,000 psi
Requires NON BAKING, simply buff on
Reduces friction and wear, improves ring seal and leak down
Bonds at 20 millionth of an inch
Retail Price List (http://www.techlinecoatings.com/retailprice.htm)
Bulk and Shop-Only Coatings
Internal Engine Coatings (http://www.techlinecoatings.com/BulkEngine.htm)
Cermalube(TM) Ceramic Lubricant
CermaLube is a ceramic coating, designed to be used, on any rigid or semi rigid surface experiencing sliding, rotating or oscillating friction. CermaLube is designed to carry loads in excess of 350,00 PSI as well as lubricate at temperatures in excess of 1600f. CermaLube is a combination of a unique water based ceramic resin and lubricating solids including, a ceramic lubricating frit. CermaLube combines the durability of a ceramic resin with the lubricity of the ceramic lubricant. CermaLube works well in light duty applications as well as in applications where high temperatures, high loads and high speeds are experienced. When higher temperatures, than most other types of coatings can provide protection at, are experienced, CermaLube is fully capable of carrying the load. CermaLube is gray in color and acquires a glass like finish in use. CermaLube is formulated to provide a cured film thickness of .001" or less. CermaLube is a water based material that contains no hazardous solvents.
PROTECTIVE TO ABOVE 1600F
Maintains adhesion at base metal temperatures in excess of 1600f.
HIGHLY RESISTANT TO THERMAL SHOCK
Survives cyclic heating and cooling.
DURABLE SEMI-RIDGID
Creates a hard, semi rigid, ceramic like finish that survives impact, as well as expansion and contraction without separating from the base metal.
HIGH LOAD CAPABILITY
Lubricating pigments are capable of carrying loads in excess of 350,000 PSI.
CORROSION AND CHEMICAL RESISTANT
Resistant to most chemicals and acids while inhibiting oxidation.
CermaLube is a unique water based system that cures at 350f for 1 hour, at temperature. Material cleans up easily before curing with water. Non flammable system with no V.O.C.'s ( volatile organic compounds ) is compatible with today's emphasis on environmentally friendly products. CermaLube may be used on all metals except magnesium.
CBC2 POWERKOTE (Cermet Coating Thermal barrier)
Combustion chamber coating for all metals
Thermal barrier
Reduce part temperature. Keeps heat in combustion chamber longer, through the power stroke
Covers approximately 24 pistons
Requires baking. Cures at 350f for 1 hour. Must be oven cured
Note use CBX below if using nitrous oxide, supercharged, or turbo charged
CBX POWERKOTE (Cermet Coating Thermal barrier)
Designed for Performance engines running; Nitrous oxide, Supercharged or Turbocharged. For all other applications use CBC2
Creates a hard surface specifically designed for engines running High volumes of fuel and/or high compression ratios
Reduces part temperature. Keeps heat in combustion chamber longer through the power stroke
Must be oven cured
http://www.techlinecoatings.com/images/cbxgraph.gif
TLML DRY FILM LUBRICANT
Extreme pressure bonded lubricant
Solvent based, can be sprayed in very thin films
Reduces friction, galling and scuffing. Increase part life
Requires no clearance changes to compensate for coating
Oil retaining
Aids in cooling parts
Requires baking. Cures at 300f minimum. Must be oven baked
TLML2 DRY FILM LUBRICANT
Has the same qualities as listed above for TLML
Softer coating, burnishes very easily
Use as a top coat for TLMB
Excellent for crankshaft journals
Use on parts where no liquid lubricant will be used
TLMB HIGH LOAD DURABLE LUBRICANT
Primarily used to build up piston skirts
Used in very high RPM engines or where very long rods are run
Top coat with either TLML2,TLML or WSX
WSX POWERCOAT LUBRICANT
Extreme temperature and pressure lubricant
Bonds at 20 millionth of an inch thick
Requires NO Baking, Simply buff on.
TLTD THERMAL DISPERSANT
Rapidly disperses heat away from a coated component
More evenly distributes heat over a coated surface
Aids in cooling heat sensitive parts
Excellent for intake manifolds, brake components, oil pans etc…
Very good chemical and corrosion resistance
Black in color
Cosmetically appealing
TLLB LUBRICATED THERMAL BARRIER
Oil shedding thermal barrier
Designed for the bottom of intake manifolds
Use on windage trays, crank scrapers, connecting rods etc…
TLHB HI HEAT I.D. COATING
Modified Polymer
Designed for the I.D. of chrome pipes to reduce bluing
Excellent thermal barrier for exhaust ports
Smooth finish enhances flow in exhaust ports
May be flowed, brushed, sponged or sprayed
They have a lot more on the website. http://www.techlinecoatings.com/index.htm
Exhaust System Coatings (http://www.techlinecoatings.com/BulkExhaust.htm)
Brake System Coatings (http://www.techlinecoatings.com/brakes.htm)
Specialty Coatings (http://www.techlinecoatings.com/BulkSpecialty.htm)
Assembly and Gear Lubricants (http://www.techlinecoatings.com/AssemblyGear.htm)
New stuff
Newhttp://www.techlinecoatings.com/techtrex/images/techtrex_logo_ssm.gifwith Peek™ (http://www.techlinecoatings.com/techtrex/)
TECH ARTICLES AND INFORMATION (http://www.techlinecoatings.com/TechnicalInformation.htm) dkozloski 01-01-08, 06:17 PM There is a British anti-scuffing coating for internal engine parts called Cargraph thats been around for at least 75 years. Similar products have been applied to lifters and cams in the U.S. for at least that long. AJxtcman 04-02-09, 11:04 PM http://i224.photobucket.com/albums/dd25/AJxtcman/93%20to%2099%20Cams/PIC-0150.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/93%20to%2099%20Cams/PIC-0151.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/93%20to%2099%20Cams/PIC-0152.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/93%20to%2099%20Cams/PIC-0153.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/93%20to%2099%20Cams/PIC-0154.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/93%20to%2099%20Cams/PIC-0155.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/93%20to%2099%20Cams/PIC-0156.jpg
I don't think you need ZDP submariner409 04-03-09, 09:53 AM A direct contact cam and tappet, ZDP or not, is not forever. One microscopic mismatch in the face hardening or a machine nick and the wear begins. One too many "dry starts" from engine inactivity and the wear starts. We're fooling with a poorly lubricated (the nature of the beast) area of horrendous scuff and pressure loading. That a cam and flat tappet lifter set lasts 1,000 miles is a miracle in itself.
The Northstar DOHC flat tappet wear was one of the driving forces that made GM shift to roller followers in 2000.
As Dkoz observed, many, many flat tappet cams come from the manufacturer with anti-scuff breakin compound already applied. The instruction sheets plainly tell you NOT to wash off the coating with solvents or cleaning chemicals. The cam manufacturers also tell you to break in the engine with low tension valve springs and then shift to your fancy high tension double set later because the possibility of scuffing is so great. Cam wear has been around since Day 1 and obviously magic potions don't stop it.
GM and other assembly lube suppliers didn't change their EOS for no reason: the EPA and pollution regulations made them reduce the ZDDP load to comply with legislation.
You might look at engine oils which comply with a Porsche, Mercedes, or Ferrari spec or Marine or Fleet oils. They have a high ZDDP load and do not comply with the EPA specs, so are not labeled with the starburst "Energy Conserving" propaganda. chubbyranger 04-04-09, 11:41 AM There was an article last fall in the rag my collector insurance company sends me every so often about ZDDP reduction in oils and impacts to classic car engines. They recommend using racing oils or a couple of specialty options, classiccarmotoroil.com or ZDDP additives like www.zddplus.com. So with my 99 STS, if I were to use ZDDP additive would it not result in shortening the life of the catalytic converter? I would bet you would never notice the difference. Remember that this reduced ZDDP is probably pushed on us by the tree huggers. dkozloski 04-04-09, 12:42 PM I would bet you would never notice the difference. Remember that this reduced ZDDP is probably pushed on us by the tree huggers.
The tree huggers are fine with ZDDP. It's the bunny huggers that are making all the fuss. submariner409 04-04-09, 03:14 PM Chubby, Catalytic convertors were perfectly happy with a ZDDP load of 900 - 1300 PPM before 2004 (the change/turnover year), so if you could calculate how much XYZ additive to use, you should be OK. Better to use a Euro spec or Marine/Fleet oil which is spec'd not only for gasoline engine use, but also for diesel (CC/CD) because that oil will have a controlled 1,000 - 1300 PPM ZDDP additive as opposed to today's automobile-only 500 - 750 PPM spec.
There are some pretty impressive 10W-30 HD fleet oils out there. Your car would be a happy camper.
My 2002 uses 5W-30, there aren't any fleet oils in that grade, so before GM discontinued ("reformulated") their original EOS I bought 2 cases of the old stuff and now add 1/4 pint with each Pennzoil Platinum change. No problems. I'll be in EOS for a long time at that rate. (I DO use it building Olds 455's.) chubbyranger 04-05-09, 10:29 PM My oil is rated API SM/CF. I found this definition for CF:
CF – Indirect Injected Diesel Engine Service – Service typical of indirect injected diesel engines and other diesel engines that use a broad range of fuel types, including those using fuel with sulfur content above 0.5%. Requirements include control of piston deposits, wear and bearing corrosion. Engines may be naturally aspirated, turbocharged or supercharged. CF rated oils may be used when API CD oils are called for.
If CF > CD I guess I'm OK? submariner409 04-05-09, 10:42 PM From the 3 oils on my shelf which carry a CF rating (Pennzoil 15W-40 Long Life, 10W-30 Truck/SUV blend, and 30W Marine) all are additionally rated at least CC/CD and do not carry the "starburst" energy saving emblem, so by definition they carry a higher ZDDP load than the "starburst" labeled oils. mikelawson 04-09-09, 01:03 AM I have repaired a couple of N*'s lately that have very badly worn exhaust cams only. One was so bad it had worn completely through the tappet. Anyone have any reason why it's exhaust cams only? The engine had 180k on it and was getting HG's for the first time. That same customer also has a 93 seville with 250K with only a starter being replaced :). submariner409 04-09-09, 09:14 AM Poor metallurgy, grinding, and hardening of the cam lobes and lifter faces.
Flat-tappet lifters take a terrible beating and as I said before, it's a wonder they last as long as they do. At an average speed of 35 mph for 180,000 miles, figure out how many times that exhaust lobe has punched that lifter up and down against 200 pound spring pressure. AJxtcman 04-09-09, 09:45 PM I have repaired a couple of N*'s lately that have very badly worn exhaust cams only. One was so bad it had worn completely through the tappet. Anyone have any reason why it's exhaust cams only? The engine had 180k on it and was getting HG's for the first time. That same customer also has a 93 seville with 250K with only a starter being replaced :).
I feel this is the angle that the cams sits on the lifter. OK I know it has the same angle. Maybe the offset of the cam.
If you have seen these apart you know what I mean by angle and that must be the offset, because if you stare at it long enough you will see that the cam still sit about the lifter
No it is the angle chubbyranger 04-12-09, 08:27 AM I have repaired a couple of N*'s lately that have very badly worn exhaust cams only. One was so bad it had worn completely through the tappet. Anyone have any reason why it's exhaust cams only? The engine had 180k on it and was getting HG's for the first time. That same customer also has a 93 seville with 250K with only a starter being replaced :).
Mine was also both exhaust cams and I don't recall seeing a thread here where the intake cams were a problem. On my car #5 was singing and #4 was starting but got drowned out by #5. | |
