View Full Version : 94 Northstar Flexplate knocking noice. HELP!!
Evita
12-10-07, 10:55 AM
I own a Concourse -94, last week when I was driving to my work the engine starts knocking real bad. I shut it down. I have finally found out the problem:
It seems that the crankshaft have moved with the result that the flexplate and the bolts for the converter going in to the block. How is this possible???
I can now start the engine but the sound is terrible. Ideas??? Please help!!
I'm from Sweden.
eldorado1
12-10-07, 04:10 PM
Are you sure one of the flexplate bolts hasn't come loose?
submariner409
12-10-07, 05:45 PM
If you believe that you have mechanical problems with the crankshaft, flexplate and torque convertor, based on noise and operation, then your only solution is to remove the engine and/or transmission for repair.
Unfortunately there is no easy solution.
Evita
01-09-08, 03:23 PM
Problem solved!
The flexplate was totally broken from crankshaft.
I could fix it without pulling the engine.
I just wondering. -Why the flexplate broke down?
Zorb750
01-09-08, 07:03 PM
Problem solved!
How could you fix that without removing the engine? Did you just drop the transmission?
Evita
01-15-08, 07:53 AM
You dont need to drop anything. Remove all surounding things, take the bolts off engine-transmission. Unscrew the right transmission hold. Lift the engine and push it over the frame rail, passenger side. Now you get a 2,1/2" gap between the engine and transmission.
submariner409
01-15-08, 10:20 AM
Evita, Zorb, That's dedication !!!
tateos
01-15-08, 12:50 PM
Evita - I am impressed!
