View Full Version : engine swap for a 2001 dts
704caddyman
12-03-07, 11:47 PM
hello everyone i'm a newbie who suckered by a local used car lot. I had car only 1 week before it ran hot. mechanic says that the car wa doped up, it was leaking from center of motor. he couldn't say if the block had holes or if the hed gaskets were blown. water pours out like crazy. so i was wondering if a motor out of a 2003 or 2004 with same option L37 vin code 9 fit in my 2001 dts thanks for any advice or help
Ranger
12-04-07, 11:16 AM
I think the motors are compatible. That said, holes in the block are unlikely and head gaskets rarely leak externally. Your problem might be a simpler and cheaper fix. I'd locate the leak before swapping motors. It migjt be as simple as the heater core lines running behind the rear head.
704caddyman
12-04-07, 02:11 PM
thanks for the info. i called the mechanic back and he said once the pressure builds up the water leaks from the reap or weep holes whatever those are thanks
Ranger
12-04-07, 04:44 PM
I have no idea what a "reap or weep hole" is either.
CadillacSTS42005
12-04-07, 11:54 PM
i think your mech is the one trying to sucker you
where are you located?
zonie77
12-05-07, 10:35 AM
A weep hole is a hole for condensation or small leaks to exit.
The water pump usually has weep holes. Mufflers and the doors usually have weep holes. The water pump is the only place I can think of in the engine compartment.
If it's from the water pump that's not a major problem. Head gaskets are a major problem.
I'd go look at the leak myself.
704caddyman
12-13-07, 12:04 PM
Hello everyone, thanks for the help nad responses. I`searched and found the leak myself and boy was my feelings hurt. I have a hole on the lower end of my block close to the frame or support :crybaby::mad::rant2:
Ranger
12-13-07, 09:52 PM
I know that a used car sale is usually "as is", but I would go back to the lot you bought it from and raise holy hell. Maybe threaten legal action. Nothing to loose.
On another note, most of these nondescript used car lots get their cars from the auction and there is usually a reason they go through the auction.
dkozloski
12-13-07, 10:12 PM
What kind of a hole? A crack? Pinhole? With a pinhole just drill it, thread it, and screw in a plug. Take us some pictures. I fixed a cast iron Caddy block that threw a rod and made a pretty good sized hole by filing it round with a rat tail file, threading it, and screwing in a pipe plug. I reground the crank found a new rod and piston and it ran another 50,000 miles.
CadillacSTS42005
12-15-07, 09:41 PM
could just use an actual welder to try and fix it too
not JB weld
i mean a mig welder...
704caddyman
12-15-07, 11:52 PM
hello everybody the block has a crack instead of the hole i suggested at first. thanks for any info:bomb::annoyed::crying:
704caddyman
12-20-07, 02:52 PM
:worship::worship:if i were to exchange the 2004 dts motor with my 2001 dts motor what changes will i need to make as a far as sensors , mounts, exhaust or any thing else ? thanks
Robs2000STS
12-26-07, 04:07 PM
You should contact the office of attorney general in your state. The last thing these used car shops want is to be on the radar.
704caddyman
12-28-07, 01:44 AM
I contacted the office after having the car for 10 days 5 0f which was back on the carlot with them assuring me that it was a simple fix. the attorney general office said once i signed the as is form that basically i was stuck with the car:banghead:
dkozloski
12-28-07, 02:03 AM
Usually a used car dealer will include a minimal warranty but knocks off some on the price if you'll sign an as-is. It sounds like you outdid yourself.
Crown Vic Owner
12-28-07, 02:12 AM
alot of the places are as - is
I would just call and pitch a fit
704caddyman
01-02-08, 06:59 PM
can someone please tell me if the motors are compatible? thanks
AJxtcman
01-02-08, 07:51 PM
Yes any 00 to 05 will work. You may need a PCM program update. If you use a 02+ engine you should have a PCM program change it will really help:D
codewize
01-02-08, 08:23 PM
I was going to put a plug in here for you. It's my understanding that the only changes in the 00 -05 engines is the cams. that correct?
Then I was going to say, and AJ can get you a tune to work :)
Ranger
01-02-08, 08:38 PM
I don't think there where any cam changes.
AJxtcman
01-02-08, 10:06 PM
Plenty of changes. The specs used to show the differnces, but don't now:crybaby:
Ranger
01-02-08, 10:11 PM
Really? Different cams?
AJxtcman
01-02-08, 11:32 PM
I have a sheet they comes with replacement engines. It says if you have engine broadcast code XXX, YYY, ZZZ, or TTT you will need to get a VCI calibration.
I will post the info tomorrow. I had lost it but found it last week.
CadillacSTS42005
01-02-08, 11:40 PM
isnt the different cams the reason why the 05 Vin 9 DTS is rated at 292 HP instead of 300?
correct AJ?
I~LUV~Caddys8792
01-03-08, 12:38 AM
No, I don't think so Jason. I think the only reason the rating dropped 8hp is because the way they rate the motors changed ever so slightly for '05 or '06. I may be mistaken, but I've heard that a few times before.
AMGoff
01-03-08, 02:59 AM
Not quite... it was mainly imports that took the biggest hit from the revised SAE ratings... some domestics actually jumped higher from the new testing procedures. Granted, pretty much all of them were only within a 3% variance - plus or minus. I know both the Viper and the 'Vette ended up "gaining" power... in fact, when the new DTS came out it was rated at 291 I believe, now it's at 292. The biggest reason is unlike many import (especially Japanese) manufacturers, Detroit's been known to underpromise and overdeliver in terms of power on more than one occasion.
Submariner409
01-03-08, 11:24 AM
Underpromise and overdeliver........Even as far back as 1967. The 427c.i./"435"hp Corvette, if I remember my hot rod days correctly, was actually within a shade of 500 hp, "stock". Several U.S. manufacturers played with advertised horsepower a lot - I know Dodge had some real 440 screamers, too.
Then we got into the SAE, rwhp, flywheel, gosh-knows-what method of quoting/advertising hp.
Today, with the tickle of a computer, you can juggle hp figures to suit whatever tickles your fancy.
codewize
01-03-08, 11:34 PM
The cam change happened mid year 01 or 02 correct ? Actually I think the real cam change happened in 03 BUT sometime in 01 they issued a TSB for a rough idle condition which resulted in a cam change also. Is that about right AJ? I'm trying to keep up :)
704caddyman
01-04-08, 05:39 PM
thank everyone for your help
704caddyman
01-16-08, 06:32 PM
:stirpot::highfive: hello everybody i found a motor on ebay out of a 2005 dts with 14,392 miles for 1900.00 wish me luck on the exchange. Aj i took your word and knowledge while making the decision. So please look for any post or questions that i might have.:alchi:
tateos
01-16-08, 08:00 PM
$1,900 sound like a good price. How much will it cost for the swap?
AJxtcman
01-16-08, 08:12 PM
:thumbsup:
704caddyman
01-17-08, 02:27 PM
my mechanic at a local shop said he would the swap for $1200.00 . he and staff are pretty good. no backyard dude here
tateos
01-18-08, 12:01 PM
1,200 sounds like an excellent price to me
704caddyman
01-30-08, 10:46 PM
update on the swap.
mechanic says he has to swap the intakes and coil packs because of the wiring harness, he says everythings ok. should be ready by the week-end
704caddyman
02-04-08, 11:33 PM
:bouncy: update i recently picked my car up on thursday and drove to beach this week end which is about 360 miles away. car an fine with no problem. i also have a wire harness and intake for sale for a 2005 dts make offer
Destroyer
02-05-08, 10:06 PM
:bouncy: update i recently picked my car up on thursday and drove to beach this week end which is about 360 miles away. car an fine with no problem. i also have a wire harness and intake for sale for a 2005 dts make offerWow, you have to travel 360 miles for a beach?. Damn. Congrats on the motor, you made out well all things considered.
AJxtcman
02-06-08, 07:36 AM
I am interested. PM sent
704caddyman
02-06-08, 01:39 PM
i do not have enough posts to respond to pm. sorry
