: Missfire help pls
zealious
11-29-07, 02:54 PM
Hey there, been a long time since Ive been on this board =D good to see it is thriving.
Got a 98 catera with 96k miles
Any how, I had a bad oil leak going on and my car sat for about 3 months while I repaired her. after many rains, water had built up in a few of my spark plug wells. So I cleaned them out real well and replaced my plugs.
She Only starts misfiring after running about 10 min or when warm. I did get some wires today and will be trying them out.. but Ive been warned that the dis pack and coil are a common problem and The wires are probably fine.
Well is there any thing else i should be looking for?
Where would be the cheapest place to find the coil and dis pack?
Anyone got any tips on changing out the wires.. I have no Idea how to get my hands back there the frame of the car is in the way?
yellowxhoodie
11-29-07, 03:07 PM
well first you should get diagnostics run on your car to see which cylinder(s) is/are misfiring. Then you should post the code on here so we can help you figure it out.
zealious
12-01-07, 12:58 PM
It WAS MY 6TH CYLINDER WIRE. PROBLY WATER DAMAGE. THANKS
yellowxhoodie
12-01-07, 01:29 PM
what was the code? did u figure out the problem already?
