View Full Version : so i got a few PCM codes
Crown Vic Owner
11-19-07, 03:46 PM
I got some circuit codes, but i have
P1617 - Engine Oil Level Switch Circuit
P1520 - Transmission Range Switch Circuit
The first one, that is to tell how high the oil is, right, aka it wont go off if its low?
And the second, what the hell is that
the motor was changed in this car, i know that.
Cadillacboy
11-19-07, 04:09 PM
Those are news to me too .
BTW, I don't think changin the engine has anything to do with those codes .My car's engine was replaced too yet never seen such codes .
Crown Vic Owner
11-19-07, 04:17 PM
i mean, its probobly my dads f*** up.
He installed the engine, and i know the trans guy at the shop did some "teaking" to it, and i know he knows his shit.,
Cadillacboy
11-19-07, 04:23 PM
I didn't like "teaking" thingy I must admit . I presumed the engine was replaced by a dealer .So may be some solenoid problem might cause those codes too .
Crown Vic Owner
11-19-07, 04:30 PM
Tweaking*
The guy knows tansmissions, and i am not sure if this is due to the new converter installed, or if it is just a sensor that took a dump.
I also had the dash that liked to shut down all the backlighting and the goofy driver number thingy. Some codes explain it.
Crown Vic Owner
11-19-07, 04:53 PM
z2q--ggzmLA
CadillacSTS42005
11-19-07, 08:09 PM
i see a white box...
Crown Vic Owner
11-19-07, 08:48 PM
its a youtube vid of the codes
Ranger
11-19-07, 08:54 PM
Just the opposite. It DOES go off when it is 2 qts. low. It is a low oil level warning.
I think the Transmission Range Switch is what we used to call the PRNDL switch.
CadillacSTS42005
11-19-07, 09:00 PM
post link of vids
you didnt post it right
Crown Vic Owner
11-20-07, 04:46 AM
post link of vids
http://www.youtube.com/watch?v=z2q--ggzmLA
my car is NOT low on oil,i know that. No messages on the DCC, and i checked it a bit ago.
I pulled dipstick out, wiped, put back in, and rechecked at the same time, it was NOT low..
Crown Vic Owner
11-20-07, 05:21 AM
B1327 - Vehicle system voltage below 9.0 volts (history)
B1328 - Vehicle system voltage is greater than 15.9 volts(history)
B1328 - RH Sun Load Sensor Fault (history)
B1652 - Loss of Keep Alive Memory (KAM) (history)
B1983 - Device Power Circuit Low (history)
B3033 - Security System Indicates Tamper
B3055 - Key Not Present (i had to break into my car)
P0603 - Control Module Long Term Memory Reset (history)
P1599 - Engine Stall or Near Stall Detected (history)
u1255 = Serial Malfunction (history)
U1300 - Class 2 Short to Ground(history)
U1064 - Loss of Communications with DIM(history)
U1128 - Loss of Communications with IRC (history)
Current
U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction) (current)
C1738 - Exhaust Solenoid Valve Short to GND
