View Full Version : A/C clutch and pulley swap.
LS1Mike
11-17-07, 07:09 PM
I did this on my 89 Big Block GMC, but it is virtually the same for all AC units.
You will just have to buy the right tool for your compressor type.
It cost me about 100 bucks total. No removing the compressor or costly recharge.
Ok so I had a whirl, it wasn't the compressor just the pulley.
I got the pulley and clutch for 81 dollars. I bought the AC clutch install and removal tools on line for 26 bucks. Auto Zone only has the Ford crap.
So here goes...This is for obs, but all ac's are similar.
You need (obs 454 w/R4 compressor.) to remove the fan shroud.
(10mm bolts) 7 plus one for the coolant hose.
Next you have to remove the belt. Pause for a sip of beer.
Next step is to remove the center bolt from the saft on the compressor (14MM) You can use a special tool to hold the clutch or a flat tipped screw driver. I rented the tool from Auto Zone.
http://img267.imageshack.us/img267/3608/holddn7.jpg
It has tree prongs that fit in the compressor and a hole to get at the nut.
One the nut is removed it is time to get the clutch off. The clutch is treaded on the inside. The tool screws into it and has a center piece that pushes against the shaft.
http://img267.imageshack.us/img267/5704/removeclutchnj0.jpg
Just hold the end screwed into the clutch and turn the one that presses on the saft and it will pop right out.
Underneath mine looked like this all the grease was coming out of the bearing.
http://img267.imageshack.us/img267/8086/greaseuk3.jpg
Under all that grease is a snap ring that must come off.
This is what it looks like.
http://img267.imageshack.us/img267/1342/snapringfq7.jpg
Next the pulley has to come off. Mine popped right of with a pry bar and a little push against the compressor. They do make a special A/C pulley puller but I didn't need it.
The pulley is actually pressed on to the compressor body.
Here is what it looks like removed.
http://img267.imageshack.us/img267/6840/emptyxe5.jpg
You can see the grove where the snap ring was.
Ok have some more beer and clean up the compressor.
Now you are ready to install the new pulley, It will slide on a bit, but I used a board and hammer to get it the rest of the way on. I put a little grease on it so it would slide better. I couldn't find a tool that would press it back on.
http://img267.imageshack.us/img267/3148/newpulleyzg8.jpg
Once you have the pulley on, install the snap ring.
http://img267.imageshack.us/img267/6140/snapringinstalledws1.jpg
Now it is time to install the clutch. NOTE*There has to be .20 to .30 air gap between the clutch and the pulley*NoteThe clutch is keyed.
http://img267.imageshack.us/img267/6236/newclutchoz6.jpg
Slip it on the shaft, this is when you need the clutch install tool.
It threads over the shaft and there is a piece you screw down on it that presses the pulley on. Screw the installer ALL THE WAY onto the shaft
or it will keep backing off the compressor shaft.
http://img267.imageshack.us/img267/5802/pressonpy0.jpg
You hold the outer most portion and turn the inner big piece that just pushes the pulley on. Use a feeler gauge to check air gap.
Once that is on, remove the tool, put the bolt back on, reinstall the belt and Fan shroud.
You saved some cash! No replaceing the compressor or getting a recharge.
Hope this helps.
This is the clutch puller
http://img57.imageshack.us/img57/6778/pullerrp6.jpg
This is the clutch installer
http://img57.imageshack.us/img57/5435/presservi4.jpg
This is the part of the installer that screws onto the saft.
http://img57.imageshack.us/img57/7058/press2xx5.jpg
urbanski
11-17-07, 07:15 PM
LS1Mike
11-17-07, 07:33 PM
Oh some additional information I thought of. If your pulley and clutch are fine. You can purchase just the bearing for anywhere from 20 to 40 dollars at Napa. Have the old pressed out of the pulley and the new one pressed in. You will then most likey be close to 80 bucks for the repair.
It is very easy to do. It took me about 45 minutes (with three beers). For your first time allow about 2 hours.
Here is a link to the tool I used.
I believe there are Cadillacs out there with the same tread pattern on their clutch.
http://www.mytoolstore.com/kd/kdspec01.html
LS1Mike
12-02-07, 06:16 PM
Update: This has worked very well, I have put a 1000 miles on the truck with no problems. If you guys try it and get hung up feel free to PM me with questions as necessary to save yourself some cash.
