: Nitto drag radials, Will 305/35/18 fit on rear of the V
11-17-07, 05:35 PM
Trying to get the widest drag radial I can under the rear. going to be using HRE competion C-20 wheels 9.5 inches wide, I know the 305 are a little wide for the 9.5 in rims, But I think that'll be fine as long as the 305 will not rub. Seems the nitto's run a little on the narrow side for there size which might help some. So has anyone managed to get 305 on the rear without rubbing ?
11-17-07, 07:13 PM
I'm running those tires on my C5 with 18X11" wheels. If you're going to use 9.5" wide wheels you should probably stick with the 275 wide DRs.
11-17-07, 08:06 PM
That's going to be close. Here's a 295 on a 19 x10 wheel. Don't hit any bumps...... if you do it.......they will rub.
11-18-07, 01:13 AM
Well, if you talk with our friends at Specter and get a set of fender flairs, you wouldnt have to worry too much. You will be able to run the 305s but do not go with lowered springs...You will rub...
