View Full Version : 150 miles in limp home mode
tman2093
11-11-07, 05:48 AM
Was driving back to my dorm tonight and a ford escort ran a red light at an intersection i was crossing. Long story short, the escort had its whole passenger side smashed in, bloody passengers and spun 180 degrees. I'm perfectly safe.
Damage to my 99 STS: airbags deployed, front bumper and styrofoam torn off, headlights shattered, hood crumpled, fenders tweaked and windshield cracked. The radiator apparently is ruptured. No clue about the internals other than that.
The car runs fine. drove it onto the rollback with ease. Since the radiator is MIA, theres no coolant flow. I need to get this car home, a 150 mile drive. Limp home mode is suggested for 50 miles at 50mph only, but i need 150 miles at around 70mph for the interstate. nighttime temperatures reach around 30 degrees here.
Anyone think the drive can be made? I can take a state highway home as well, but the distance wont change any, may increase by 20 miles or so.
tman2093
11-11-07, 05:51 AM
i want to add that the engine bay looks to be intact as though mechanically, the car can make the drive, notwithstanding the radiator damage.
CadillacSTS42005
11-11-07, 08:20 AM
lets see
would i risk my 5K engine....
you realize if (and when i say IF i mean WHEN if you attempt this) YOU blow up the engine becuase YOU drove it, it wont matter that someone else was at fault resulting in the coolant loss, youll be footing the bill...
i think the answer here is REALLY common sence...
eldorado1
11-11-07, 09:12 AM
your engine's going to be glowing red by the time you get back... :D
Submariner409
11-11-07, 09:20 AM
Bummer. I wouldn't try the limp home, at that distance, on a bet. What you face is a logistic nightmare : Is it cheaper (relatively) for you to go "home" and find a rollon near your shop, or do you have someone from the scene bring it home ? There's always the slim chance that something else might be bent/broken....suspension ?
Mechanically, I'd recommend the truck. BTW, you can go after the Escort's insurance carrier.......
codewize
11-11-07, 11:28 AM
I wouldn't even consider it. That's a HUGE risk which probably won't turn out well.
AJxtcman
11-11-07, 03:00 PM
Can you please tell me what Limp Home Mode is in your opinion.
Just think a little.
You will have no way to cool the engine other than air flowing across the engine.
How hot will the oil get?
Will the oil still work?
Hmmm Why take a chance?
If you were out on the town and got drunk would you still drive?
You can alway find another way to get from A to B.
This leads to the Spare tire deal. GM needs to get rid of them and GM is Slowly. If you get a flat and you don't have a spare it is not the end of the world. If you have a spare it maybe the end of your life. That is a fact. The spare tire deal is like Points vs Electronic ignition. You can't get out and adjust Electronic ignition and get the car running again like you could points.
JN in CA
11-11-07, 03:02 PM
I once went into limp mode. I ran the car up to about 55MPH, then shut it off and coasted until it got down to about 20 MPH, then repeated. And this was to go 2 miles back to my house.
If you think you can do 70 MPH in limp home mode, let alone in a car w/o a front bumper, then it is only because you have never tried it.
What you are suggesting is simply not a realistic option.
atikovi
11-11-07, 03:44 PM
Sounds like the car is probably totaled, so what the hell, right? If you're gonna try it, first change the oil to 60 weight racing oil or even 70 weight if you can find it. Make sure the engine is warm when you change it and leave soon after, because if it gets below 60F you won't be able to start it. Let us know what happens. Heeheehee
Submariner409
11-11-07, 06:23 PM
Limp home is a restricted mode of engine operation when a specific series of emissions or cooling trouble codes occur. Limp home applies to timing, mixture, and cylinder dropping, and will allow limited (50 mile) operation with cooling troubles.
Camel mode was the attempt at dropping ignition to alternating cylinders to allow early N*'s to go somewhat more than limited distances with poor cooling. I think the idea was dropped until VVT became standard.
AJ or ewill3 would know.
Ranger
11-11-07, 07:43 PM
Don't Even Consider It! :thepan:
Sub,
The Northstars still have camel mode to the best of my knowledge.
tman2093
11-12-07, 02:46 AM
I suppose I mean camel mode and not limp home. Yes its probably stupid when I think rationally, I just can't help but think I remember Motor Trend going long distance with no coolant with no harm done other than needing an oil change. I mean the cars most likely to be totaled by insurance, so I considered what I guess is a suicide run. If I can buy it back from the insurance company at a reasonable price I'll part it out. The Northstar is still running, I know plenty of people here want one.
AJxtcman
11-12-07, 07:35 AM
One word! Marketing
Cadillacboy
11-12-07, 11:36 AM
Sorry for your nasty mishappen .Yeah, you should never try that mode that coould be end for your engine
Dadillac
11-12-07, 12:25 PM
I am not sure where the OP is located, but here in NJ, you can forget about it. Let's put the "is it okay for the engine" thing aside for now. Let's only mention the body damage to the car. Here in NJ, if you have that kind of damage (bumper cover gone, headlights broken, etc) it is unlawful to drive on the street, let alone a highway. You will probably be pulled over in less than 10 miles. Then the LEO calls a tow truck, and you get towed to God knows where. Then you will need a tow truck to pick up the car, and bring it wherever you want it to go. So in the long run, it would be less $ and trouble, to just get it towed to the destination.
Don
STSforfun
11-13-07, 02:30 AM
Know way! Rent a trailer and truck from uhaul. If you make it more of a mess the other guys insurance is not going to pay for it. Grab a friend and a tow dolly and drag it home.
Craig
Crown Vic Owner
11-13-07, 02:59 AM
call YOUR insurance company and tell them what happened.
Tommy Deville
11-13-07, 11:21 PM
I never knew "limp mode" & "camel mode" were 2 xiffrent things, I would not try it, get the insuramce to pay 4 a rental.
Ranger
11-14-07, 11:00 AM
"Camel Mode" & "Limp Home Mode" are one in the same.
