: 96 Cylinder head on 93 block
proyan
11-03-07, 04:32 PM
Hi, newcomer here, just like to know if 96 cylinder head would fit on a 93 block, the engine goes in a 93 STS, the HG is blown and i could get the 96 heads, witch are completely redone, for cheap
thanks
AJxtcman
11-03-07, 05:18 PM
thanks
Yes they will bolt on. No they will not work for your application. The heads are not the same.
Ranger
11-03-07, 06:10 PM
Why do you think you need to replace the heads? It is the gasket that went bad. Be sure to Timesert the block unless you want to do it again.
zonie77
11-04-07, 11:49 PM
The heads don't go bad very often. Your's are probably good.
