: Help!!
Need 4 V-Speed
11-03-07, 03:21 AM
Has anyone had issues with engine bogging down to 400-500 rpms when clutch is engaged and rpms are dropping back down to idol. This mostly happens when the car is first started and it happens in reverse and forward gears. This issue seem to arise after I had the battery changed out and the throttle body cleaned. I have done the idol relearn procedure and that did not fix the problem. I am wondering if something is with the programing of the computer since it doesnt seem bog down when rpms drop to idol in neutral. My only other guess is if its something going on with the idol control motor but no code is being kicked. Any IDEAS:banghead:
