View Full Version : Running a Northstar on a LS1 PCM.
AJxtcman
11-02-07, 09:02 AM
It has been done and I have the program.
I need to look at the LS1 program closer and I have contacted a company for some help.
As we all know the 4T80E is a FWD trans and the LS1 is a RWD car. Also I need to look at the way data is transferred between the PCM and the ABS. The other module should be ok, but the PCM ABS has multiple data lines.
AJxtcman
11-02-07, 09:11 AM
Too bad the Corvette never ran MagnaRide. Because of that this setup will not work on the 02 and 03 STS models with MagnaRide :helpless:
Oh wait the Corvette had it First:histeric:
msta293412
11-02-07, 12:05 PM
I have an 01.....That would be sweet!
Cadillacboy
11-02-07, 02:47 PM
that sounds a cool project !
CadillacSTS2003
11-03-07, 09:44 AM
i though the STS had it first because it was possible in 02 while the Vette and STS had it standard in 03?
Awesome news though AJ still kickin ass!!!
AJxtcman
11-03-07, 11:28 AM
Hmmm
I am sure it was designed for Corvettes. If I find the time I will look it up.
stngh8r
11-05-07, 08:11 PM
:shocked2:
N* with LS computer!?
OH THE POSSIBILITIES AND DREAMS......
dwight.j.carter
11-12-07, 09:48 PM
Hell yeah I want one if you get it done !
AJxtcman
11-14-07, 09:55 PM
:nox:
AJxtcman
11-15-07, 08:37 PM
I will clue you in on more information.
I did not want to speak out of turn. The Horse and Cart thing.
This program Originated at GM on a 4.0L with VIN 9 cams in it.
The 4.0L had 250 HP
This program with the intake cams from the L39 VIN 9 made 320 HP
That is a 70 HP gain with just two cams and this program.
This is a 28% gain:shhh:
Next they ran a Blower on it and made 380 HP out of a 244 CID engine.
Yes it was only 60 more horses, but I think it was close to being tapped out at 320 HP.
That was a 130 HP gain :eek:
That is a 52% gain. :histeric:
Hmmm. 52% gain on a 300 HP Hmmmmmm :hmm: 456 HP + the increase of cubes from the 4.0L to the 4.6L might squeak out 460+ HP with a blower.
Remember This is a GM setup.
I will post a LINK soon
AJxtcman
11-15-07, 09:28 PM
This is a good review.
http://www.caranddriver.com/reviews/3276/shelby-series-1.html
This a not so true review, but it sounds a lot better.
Specifications
General
Manufacturer Shelby
Model Series 1 1998
Powertrain Layout Front Engine / RWD
Base Price $174,000
Dimensions
Length 4292 mm / 169.0 in
Width 1943 mm / 76.5 in
Height 1194 mm / 47.0 in
Wheelbase 2405 mm / 94.7 in
Weight 1202 kg / 2,650 lbs
Front / Rear Track F 1509 mm / 59.4 in
R 1534 mm / 60.4 in
Engine
Configuration 4.0 Liter Oldsmobile Aurora Supercharged V8
Valvetrain DOHC 4 Valves / Cylinder
Displacement 3995 cc / 243.8 cu
Power 238.6 kW / 320.0 bhp at 6500 rpm
Torque 393.2 Nm / 290.0 ft lbs at 5000 rpm
Bore 87 mm / 3.4 in
Stroke 84 mm / 3.3 in
Compression Ratio 10.3:1
Bhp / Liter 80.1 bhp
Redline 6500 rpm
Chassis & Body
Body / Frame Aluminium Frame w/ Bonded Aluminium Honeycomb Panel Inserts
Steering Rack & Pinion w/ Power Assist
Brake Type Vented Discs w/ Power Assist & ABS
Brake Size F 330 mm / 13.0 in
R 305 mm / 12.0 in
Wheels F 45.7 x 25.4 cm / 18.0 x 10.0 in
R 45.7 x 30.5 cm / 18.0 x 12.0 in
Tyres F 265/40ZR-18
R 315/40ZR-18
Transmission
Gear Type 6 Speed Manual
Final Drive 3.12:1
Performance
Top Speed 273.6 kph / 170 mph
0 - 62 mph 4.4 seconds
0 - 100 mph 11 seconds
0 - ¼ mile 12.8 seconds
EPA City / Highway 16 / 27 mpg
Then came the Series II plans. If you read the first review you would know that this would never happen.
The Cobra-like Series 2 is the successor to the ultrafast Series 1, which employed a carbon-fiber shell on an aluminum honeycomb frame. Under the hood, a supercharged Oldsmobile DOHC 4.0-liter V8 packed more than 400 horsepower.
2Y_aIf1AceM&feature=related
RRujyBu60Tg
kb9rB9Q-VNA&feature=related
MM STS
11-15-07, 10:02 PM
So this may look pretty good with this kit added?http://www.angelfire.com/stars/mycaddy/northstarsuperchargerphotos.htm
AJxtcman
11-16-07, 03:02 PM
This is almost done.
msta293412
11-17-07, 09:55 AM
What do you mean "This is almost done"? ...Where are we with this? really?....
AJxtcman
11-17-07, 11:00 AM
I have the GM program
I have paid for the Harness and PCM
The harness will be here Monday or Tuesday
I will program the PCM and send it to Bill @ HP Tuners
I will work up Schematics for 93 to 99 cars and 00 to 05 cars
I will program a second PCM and start working with the Class II and UART serial data lines and messages.
Currently this a RWD Manual trans program. I have seen the LS1 Editing files in a demo version that allows you to switch from an Auto to a Manual and viceversa. I hope Bill can do this with this program. :stirpot: This should be no problem because it is an LS1 system.
I can get a stand alone trans controller for about $800. You can run a paddle shifter if you want.
Ok it looks like it is far from done, but it is on the fast track down hill.
I had the program, but they ran two completely different PCM's between 98 and 99. This is a car that has 98 and 99 build history.
I finally got the PCM model year and the part #
I will have the schematic done by the end of next week:bouncy:
The best part
I am getting help from the pro's to finish it. I think that will be the fastest way and the best way.
To me this is almost ready. Remember this is a GM program built by GM for a performance car. Think of it like a Corvette PCM running a Northstar. Wait that is what GM did. Corvettes have all the same models and systems. They even have Magna Ride:stirpot:
pjw315
11-17-07, 01:44 PM
If you can make this work this will be real interesting for the Northstar community.
AJxtcman
11-17-07, 01:55 PM
GM and Shelby had it working!
This is not some program I worked up.
I am about 75% sure GM ran this PCM in a FWD Northstar. It never made it to the road, but I think this is part of the 00 to 03 technology.
STSforfun
11-18-07, 07:05 PM
Cool!!
AlBundy
11-18-07, 10:18 PM
Its good to see that things are progressing when it comes to this engine. I often wondered why GM considered this engine to be a performance engine but never tried to increase its hp. Now I see they did.:thumbsup:
parts68
11-20-07, 02:57 PM
Has anyone bought one of the Series 1 crate motors with wiring harness and PCM to see if this is indeed true?
AJxtcman
11-20-07, 03:08 PM
WTF:helpless:
I have a harness and PCM coming from a E-bay seller. I bought the Harness and PCM from the only one that had one listed with the engine. The Kit did not sell so I got the harness and PCM. He had only one more setup. Also he said he was the only one that got the engine, PCM, Harness, Clutch, and Bell housing.
AJxtcman
11-20-07, 03:13 PM
I have had this program on my PC for about a year. I have gone back to it several time and looked it over. :thumbsup: I have not had the schematic:( I will by the end of the week.
I have made countless calls to get this information, but the Shelby Series one is a mess. I don't think any one other than the plant had the schematics.
AJxtcman
11-20-07, 03:21 PM
I see that another is listed. :yup:
Buy it.
Lets see if you can make it run.
AJxtcman
11-27-07, 11:19 PM
I got the harness today and I am almost done with the schematic.:thumbsup:
I paid BIG dollars for the PCM harness. This is nothing under the hood. All I got was stuff inside the car and the PCM connectors. I have no engine harness:mad:
AJxtcman
11-27-07, 11:27 PM
I spent 5 hours on the schematic tonight:eek: I need a :alchi: or 2 :alchi::alchi:
AlBundy
11-27-07, 11:30 PM
Drink as much as you want just make it to work the next morning. BTW did you find about the code?
AJxtcman
11-28-07, 07:49 PM
:bump:
AJxtcman
11-29-07, 07:42 PM
:cool2: I have 2 PCM's programmed.
Cadillacboy
11-29-07, 07:46 PM
Well done :cool:
Ur7x
11-29-07, 08:03 PM
Hmmm
Not sure about which it was designed for... But the first car that you could buy Magnaride in the world was the 2002 STS. Corvette lovers had to wait until the next model year.
While we are all busy hacking up and swapping PCMs
Has anyone considered what it would take to convert a CVRSS car to a Magnaride one?
Lets say I have a set of bad CVRSS shocks and will have to spend a fortune on new shocks anyway... Magnaride would be cool...
Hint HINT!
CadillacSTS2003
12-02-07, 08:14 PM
do they run a standard N* car though...
AJxtcman
12-02-07, 08:18 PM
My car runs for 3 seconds.:crybaby:
I need to setup a different type of VTD bypass:rant2: The car sound BAD A$$
CadillacSTS2003
12-02-07, 09:10 PM
unplug the VTD?
AJxtcman
12-03-07, 12:50 AM
unplug the VTD?
I have no VTD module. I have figured it out and hope to drive this soon. :thumbsup:
AJxtcman
12-04-07, 12:01 AM
It runs for a while and then stalls.:(
If I hold it at 2000 it will run great. If I change the throttle angle rapidly it stalls. :eek:
This setup is supposed to have an LS1 MAF sensor. Well I have one. I will need to figure out how to attach it and wire it.:want:
AJxtcman
12-05-07, 10:36 PM
:histeric::hmm::histeric:
:mad2::rant2::hmm:
:mad::dammit::wtf:
:angst:
My head hurts:arghh:
msta293412
12-06-07, 09:21 AM
DONT GIVE UP!.......Theres got to be a way.....You have all of our suuport......
darien99
12-06-07, 11:39 PM
I must be missing the boat here, but what will a LS1 pcm do for our northstars besides give us fuel and spark maps that weren't designed for our motor?:hmm:
AlBundy
12-06-07, 11:43 PM
:yeah:
AJxtcman
12-07-07, 12:22 AM
This program in the PCM is built for a NORTHSTAR
This is a Custom High Performance Program built by GM
The LS1 PCM has been hacked into. That PCM and a fully aftermarket tunable program is one way to make a caddy run hard.:D
pjw315
12-24-07, 02:22 PM
Aj are you giving up on this project?
AJxtcman
12-24-07, 03:40 PM
I have a few small bugs. I got the rest of the piggyback harness done. I am running two PCM's. I push out a pin in the jumper and had no charging system. I just fixed it. It is insane fast. BTW 158 top speed.:hmm: I was under the impression it was 200+.
My VSS signal is messed up so 35 mph = 158 in the Shelby PCM, but the stock PCM shifts at the correct speed. after hitting 158 it will cut out:histeric:
I will be posting more today and tomorrow
pjw315
12-24-07, 04:50 PM
I am looking forward to your posts. Do you plan on doing a dyno run once you have all the bugs worked out?
AJxtcman
12-24-07, 05:25 PM
Yes this will take a trip to the dyno.
I have the schematics for the following
Sensor connector terminals
------------- A------------------B
99 Deville -- High (PPL 401)----- Low (YEL 400)
99 Seville -- Low (PPL 401)----- High (YEL 400) This is my car
99 Carmaro -Low (LTGRN/BLK 822)--- High (PPL/WHT 821)
99 Shelby -- Low (LTGRN/BLK 822)--- High (PPL/WHT 821)
I am going to swap the two wires at the Shelby PCM and see if it works
AJxtcman
12-25-07, 07:21 PM
Way to much power for for my already weak trans.
I can't hold the massive power back. toasted my trans. :crying2:
video soon
GizmoQ
12-25-07, 11:28 PM
video soon
:drool: Looks like I need to schedule another roadtrip. :sneaky:
AJxtcman
12-27-07, 10:55 PM
I lost the sound:crying2:
7-UzNQET3dA
AJxtcman
12-27-07, 10:56 PM
The car is way faster now. Since the Video.:D
msta293412
12-28-07, 10:23 AM
post another ....,with SOUND! :-)
AJxtcman
12-28-07, 03:33 PM
8UWJFnbyCI8
CadillacSTS2003
12-30-07, 02:55 PM
def a lil sumthin sumthin under the hood
no?
STSforfun
12-31-07, 04:16 AM
Man to many telephone poles for my liking, you got more guts that I do In that yellow plastic box.:cookoo:
Craig
med
12-31-07, 11:42 AM
Beautiful:thumbsup:.
AJxtcman
01-02-08, 08:54 PM
New test Video for you all. It was toooooo Loooooooooong so I had to chop it up:yawn:
ZVfXwRXZtGo
dwight.j.carter
01-02-08, 08:59 PM
Will that pcm still control the 4t80e transmission ?
I am interested in the pcm if I can use it on my STS.
AJxtcman
01-03-08, 09:51 AM
Rolling start with a stock PCM vs a Standing start with a Shelby/LS1 PCM.
Look at the starting spot and count the poles until 3rd gear
vbYcdsXInVY
msta293412
01-03-08, 10:06 AM
VERY INTERESTING!...What did you get to do with the ls1 pcm...get more timing?,better fuel mapping?....The video's look good...you could probably get into the 12's with that thing soon....
AJxtcman
01-05-08, 12:24 AM
I was in the 12's
Lyndon is working on software for my NEW BLOWER:D
msta293412
01-05-08, 11:08 AM
If you put a blower on that thing and youre in the 12's now..........You will need large drag radials to get any traction at all, and you WILL be in the elusive 11's.......
AJxtcman
01-05-08, 01:41 PM
We have a new kid at work that details cars. He said don't kill your self in it. :suspect:
I have been driving sideways all my life. I grew up in SW Washington state. It can rain from time to time and cause slipery when wet conditions.
med
01-06-08, 04:02 PM
I visited my brother in Portland and it was wet and slippery everywhere by foot or car. On the rainy side of the mountains (coastal temperate rainforest) -- with superhuge slimy snails:cookoo:, wet slippery leaves, turns, and huge changes in elevation I took it easy. I can see how you have to learn driving sideways out there:yup:. Sorry for rambling, but those snails really creeped me out and were everywhere - kinda like driving on a road covered completely with earthworms. I for one love videos of powerslides, drifts, etc especially with a nice recovery. A screeching tire's a happy tire. Have you ever thought of taking that car to a Road America club event or to New Glarus for their city-sanctioned hill climb? <-- That would be some sweet and condoned video.
AJxtcman
01-06-08, 05:20 PM
I am working on your project also:D
CadillacSTS2003
01-06-08, 05:31 PM
very nice!
AJxtcman
01-06-08, 07:35 PM
Ok This is it.
I need to replace a bearing in it first.
http://i224.photobucket.com/albums/dd25/AJxtcman/Fiero/Blower%20Project/HPIM3461.jpg
I don't have P/S so I will mount it here
http://i224.photobucket.com/albums/dd25/AJxtcman/Fiero/Blower%20Project/HPIM3463.jpg
Inlet and outlet
http://i224.photobucket.com/albums/dd25/AJxtcman/Fiero/Blower%20Project/HPIM3464.jpg
AlBundy
01-06-08, 10:30 PM
Taking it up a notch huh?:lildevil::thumbsup:
CadillacSTS2003
01-08-08, 07:59 PM
totally hott
so AJ you coming to Chi town for the meet again?
Ill be bringin the STS likely!
mazda1949
01-09-08, 12:21 PM
Hey AJ , Lyndon Westor says he's been sending you Emails with no responses from you. He seems to think that its a server problem. Anyway, he says the software is ready and you need to get in touch with him. Im kinda anxious to see what happens in the next week or so.
Thanks
Steve (AKA mazda1949)
AJxtcman
01-09-08, 12:34 PM
The cat may be out of the bag.
I got an email for a posting in this thread that I do not see:shhh:
CadillacSTS2003
01-09-08, 12:45 PM
wha???
AJ your not making sence again lol
mazda1949
01-09-08, 12:52 PM
I know what he's talking about!!!!! He He !!! But I aint tellin till he tells me I can.
AJxtcman
01-09-08, 12:52 PM
wha???
New or low posting members reply are held correct?
AJxtcman
01-09-08, 12:55 PM
I hate for mister X to get 100 phone calls today from one or two people. I would rather mister X work on more of my projects.
CadillacSTS2003
01-09-08, 01:00 PM
lol no new posters posts are shown immediately
and as for the mister X thing i got no clue what that means
mazda1949
01-09-08, 02:59 PM
AJ how about Emailing me. Im sorry I mentioned names. I did it before I thought. Im not going to say anything without you telling me I can. I know how hard you've been working on this and you deserve all the praise. I've been reading your post for a long time but have never posted myself.
I tried to PM you instead of posting but the forums said I had to post at least 20 times before I'd have the privilege to PM anyone. I've not been a member long either. Email is ( wssears@charter.net )
mazda1949
AJxtcman
01-09-08, 03:17 PM
Thanks
Please do not call him!
I mean mister X aka Lyndon Wester. This is an LS1 PCM not the Northstar.
I will give some updates on other Northstar PCM work soon. He will need time to figure it out. If he is getting bugged he can't work on it!:rant2:
urbanski
01-09-08, 03:40 PM
whats going on here
AlBundy
01-09-08, 04:19 PM
:tisk:You said you weren't gonna let the cat out of the bag.:D
AJxtcman
01-09-08, 04:34 PM
whats going on here
I have inlisted some help!
lyndon Wester of Westers Garage.:bouncy:
Mazda1994 did.
AJxtcman
01-09-08, 09:30 PM
http://i224.photobucket.com/albums/dd25/AJxtcman/PCM%20Stuff/histo.jpg
lookin good and I can play with the new toy
http://i224.photobucket.com/albums/dd25/AJxtcman/PCM%20Stuff/histo2.jpg
mazda1949
01-09-08, 10:37 PM
Boys I cant wait any longer , I gotta show ya what I got . My little 91 Mazda (mid engine) pickup with a Northstar. And AJ I got to hand to ya boy ur pretty slick but Im gonna show ya how to make a northstar lay down some rubber. My plans are to put twin turbo's on and do a little head work and change all the cams. Im gonna make this baby scoot.
http://i255.photobucket.com/albums/hh158/mazda1949/000_0010-1.jpg
http://i255.photobucket.com/albums/hh158/mazda1949/000_0018.jpg
mazda1949
01-09-08, 10:51 PM
Oops I gotta learn to post pics on here. maybe this will work
http://i255.photobucket.com/albums/h...000_0010-1.jpg
http://i255.photobucket.com/albums/h...9/000_0018.jpg
mazda1949
01-09-08, 10:56 PM
Shoot !!! what am I doing wrong. Let me try this
mazda1949
01-09-08, 11:02 PM
Im gonna make a sleeper out of this one . When I get the cover over the bed you'll never know its back there.
http://i255.photobucket.com/albums/hh158/mazda1949/100_1090.jpg
AJxtcman
01-09-08, 11:20 PM
I will have some Dyno # after this weekend
:thumbsup:
dwight.j.carter
01-10-08, 08:33 PM
So will the ls1 pcm work with a stock STS or do I need to just have my stock pcm recalibrated ?
AJxtcman
01-10-08, 09:11 PM
I could set it up to run on a stock STS, but it would be like how mark has his in his STS turbo. You would set DTC's like he does, but if you wait a short time I will be able to use nice tuning software on your PCM.
Yes I said a short time.
dwight.j.carter
01-10-08, 09:23 PM
Lol I am not in any hurry just let me know when you get er done. It sounds like you have your hands very full these days.
AJxtcman
01-10-08, 10:48 PM
Life has been going well.
Someone gave me a supercharger.
Life is good.
Someone negotiated a tune for my LS1 PCM at the perfect price. I should say a program.
Life is good
work is slow, but I am doing ok.
Life is good.
I have met some great people here
Life is good.
I cross my fingers life is good and I get my aftermarket tuning software. Please.
Then life will be overwhelmingly good:bouncy:
AlBundy
01-10-08, 10:52 PM
See what a night in a cell got ya.:D
CadillacSTS2003
01-10-08, 11:47 PM
lol
thats one way to look at it
AJxtcman
01-11-08, 08:19 AM
This is a nice car.
You may wonder why I spent so much time on this.
I was not selling enough Tuned PCM to the Caddy guy's
I was trying to look at the fuel and spark tables to turn my car up a notch.
I need to make some cash to support my tuning efforts.
The Northstar's in sand rails, street rods, Fiero's needed something better than the current sources of aftermarket PCM's. I worked on a $25K sand rail with a Northstar. Those guy's have $$ to spend.
The list goes on.
I have not removed my Caddy computer yet, it looks like I can set the LS1 up for an auto. It is all in place just set to manual trans.
Mark my word the was the 1 biggest step to getting a program built to program Northstar PCM's the correct way. Not screwing around and screwing up PCM's with GM's program.
http://www.classicmustang.com/includes/12242_Series_1/12242_PSF_500.jpg
http://www.classicmustang.com/includes/12242_Series_1/12242_F_500.jpg
http://www.classicmustang.com/includes/12242_Series_1/12242_R_500.jpg
http://www.classicmustang.com/includes/12242_Series_1/12242_ENG_500.jpg
http://www.fsu.com/media/2003/11/10/homecoming_car_1.jpg
http://www.snuffledopple.com/images/92428y.jpg
http://pictures.topspeed.com/cars/car-news/-shelby-series-1-gets-destroyed-ar28881/IMG/jpg/b/22shelby_20061212_002w.jpg
The Shelby Series 1 is one beast of an American automobile with 320 horses a top speed of 185mph and a note to sixty in 4.5 seconds. This special Shelby was also faster than the classic Shelby Cobra 427. To no suprise, one of the few produced was wrecked when the owner of the limited muslce car was speeding excessively and struck a curb. As a result , the Shelby was shot a total of 4 into the air when it then struck a telephone pole. The pole then became dislatched and struck the bag of the vehicle as evident from the photos. Even more amazing, the driver from Reading Massachusetts escaped the crash and walked on his own to the ambulance! Luck guy...
Source:www.wreckedexotics.com
AJxtcman
01-11-08, 08:46 AM
The stock 4.0L made 250 hp
Shelby claimed 320hp with the VIN 9 cams and the LS1 PCM.
Shelby claimed 370hp with a blower and a "dirty tune" (X-50 package)
In 2001 a customer placed his Shelby Series 1 on a chassis dyno and found it delivered 270hp at the rear wheels.
The numbers on the certificate accompanying the engine package promised 370hp. The normal loss on a manual trans drivetrain is about 10 to 15%. this would put the car at 320 rear wheel horse power. :histeric:
flyinlow
01-13-08, 03:18 AM
Hi I just found this thread through google and am very interested in your progress on this project.
I am building an Open Road Race unlimited class car. I will be building a twin turbo northstar hooked to a porsche 930 trans with the ring gear flipped to run mid engine so no tranny control would be needed .
I will be using C4 Vette hubs and spindles so I can use an abs sensor for VSS input to the pcm.
I was planning to use a megasquirt system but would rather have the reliability of a factory system if possible.
Are you planing to sell the program when you are done?? and will it work on a 96 northstar engine?
I was also born and raised in SW washington and a dealer tech since 1984.
Here is a pic of the type car I am building
http://www.mantacars.com/images/be006.jpg
and the rear suspension I will be building for it
http://www.mantacars.com/images/kw7.jpg
I am shooting for a 240 mph top speed (and can actually do it legally in Nevadas Open Road Racing)
Kevin, Owner
Adrenaline Junky Motorsports
AJxtcman
01-13-08, 11:22 AM
Kevin, Owner
Yes it is for sale and yes it is for a 96 to 99 Northstar Manual Trans
What street is the picture above taken or the city?
SW Washington correct.
I will update my signature
AJxtcman
01-13-08, 12:20 PM
This Program has change the way I can work with Northstar PCM's.
If I pull in some customers that have Northstars in non Cadillac's I can effort to spend money on the Cadillac Northstar PCM projects.
If we or I can raise the outlook on the Northstar by allowing for a GOOD tunable PCM that will run correctly you will see them in more hot rods. Yes 2006+ have been tuned for a few years.
This will raise the prestige of the Northstar, raise the value of a Cadillac, and may lead to people developing fixes for know issues.
Examples: Norm's Head-bolt Inserts, TimeSert Big Inserts.
Someone that is an engineer or machinist may have a project in his garage (33 Chevy or a 39 Cadillac Sixty Special or even a 1957 Eldorado Biarritz) and wants to update the chassis and drivetrain. This guy looks at a problem as a problem solver. He may design a new head gasket or intake manifold.
Corvette Guy's are installing modern Chassis and Drivtrains under older C2 and C3 cars
Fiero Guy are goofy. I am not a big fan of the car, but the guy's on the Fiero site build and design very nice stuff
Example: Russ544 has put together a Multi (8) throttle body Northstar! (http://www.fiero.nl/forum/Forum2/HTML/087315.html)
nhoAR3UfLRo
http://i224.photobucket.com/albums/dd25/AJxtcman/Fiero/Multi%20T-body/294301846.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/Fiero/Multi%20T-body/291089647.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/Fiero/Multi%20T-body/293384569.jpg
and the bad news
http://i224.photobucket.com/albums/dd25/AJxtcman/Fiero/Multi%20T-body/295116416.jpg
Lots of talent on other forums also
flyinlow
01-13-08, 03:28 PM
That pic. is in upstate New York. it is not my car but the same model that I am building
I see you were from Washougal, I lived just west (upwind fortunately) from Camas for a while
I will Pm you as I am definately interested in the PCM
CadillacSTS2003
01-13-08, 03:45 PM
Mark99 has claimed it so dont shoot the messenger
but the reason why we revel at his STS so much (i mean more so then for simply the reason its turboed) is that his OBD-1 PCM is spidered into the stock harness and programming so well it DOES NOT throw any codes...
flyinlow
01-13-08, 03:50 PM
I assume that the PCM will still be tuneable with normal LS1 tuners since I will be twin turbocharging it and building it for Open Road Racing, so I will need to dyno tune it when done
Plus of course eliminate all emissions sensors, rear O2 sensors and Vats.
AJxtcman
01-13-08, 03:56 PM
Yes you should have a Dyno, but I think you can run this without a dyno tune. I think a dyno tune may give you 100 to 200 more horse power
AJxtcman
01-13-08, 04:03 PM
Hmmmmmmmmm I see that you have not kepted in touch with Mark.
He is running a CHRFab holley engine management setup and a PCS Trans conrtoller.
He has more warning messages and warning light on then I can list or remember.
Just ask him. How did you come up with no codes being set?
CadillacSTS2003
01-13-08, 04:30 PM
no worries man i believe you
before he ran the holley, with the stock injector set up he didnt have any warning issues at least i could of sworn he didnt
i didnt realize he switched to a different fuel management set up now
AJxtcman
01-13-08, 04:53 PM
Maybe I chatted about this in a PM or on another forum, but I thought he posted it in the Seville section here
CadillacSTS2003
01-13-08, 05:00 PM
egh i could of missed it
way too many posts here to even begin to remember lol
flyinlow
01-13-08, 06:08 PM
If you can PM me your phone # I will give you a call
I dont have quite enough posts to pm you yet
AJxtcman
01-18-08, 07:31 PM
Lyndon sent me a PCM and cable today. I don't need any more PCM's, but he set this one up. OMFG does it have some power. More grunt, but less RPM's per second:D at WOT
AlBundy
01-18-08, 07:38 PM
Stop tryin to get me excited.:tisk:
GizmoQ
01-18-08, 08:37 PM
Does that mean you got a PCM for the blower? :drool:
mazda1949
01-19-08, 12:59 PM
AJ are you shifting your tranny with the new PCM or are U still using the caddy PCM?
mazda1949
mazda1949
01-19-08, 01:03 PM
Oh I forgot, AJ what were U talking about when U mentioned cable, harness or what?
mazda1949
AJxtcman
01-19-08, 02:14 PM
mazda1949
I am using the Caddy PCM to run the trans. It is not working the way I like. The auto trans part of the LS1 PCM is well on its way and should be done soon. Then the LS1 PCM will run the engine with an Auto or a Manual
mazda1949
Not sure.
I recieved a cable from Lyndon yesterday, but I may have been talking about the Y harness :confused:
AJxtcman
01-20-08, 02:33 PM
I have a basic price for the PCM with a loaded program.
This will be for the 96 to 99 Northstar with a manual trans only.
$499 plus $50 core charge on the PCM.
An Auto program is soon to follow and a 2000 to 2005 will be out also.
This is not for a Caddy, but I have my foot in the door with Wester's.
If you are a Hot Rodder this will work perfect. You can run an non Electrically controlled Auto trans with this PCM
AJxtcman
01-20-08, 02:47 PM
http://www.speedway32.com/images/C2_roll_features_09.jpg
Features (http://www.speedway32.com/features.html)
Street Rod Parts (http://www.speedwaymotors.com/d/225_Street-Rod-Parts.html)
mazda1949
01-27-08, 10:58 PM
AJ if I could PM you I would but I dont have enough post yet. Have you did anymore with the blower you showed us?
Im kinda anxious to see how well your fiero does with the blower.
Steve
AJxtcman
01-28-08, 08:00 AM
The car is buried in snow. I need to get it ready for the dyno this weekend. I want to get it Dyno'd first before I do the blower set up.
eldorado1
01-28-08, 12:13 PM
good thinking!
AJxtcman
01-28-08, 03:07 PM
I am taking three PCM's to the dyno
Stock Caddy PCM (300 hp) for reference
Stock 108 MPH PCM (275 hp) for reference
Tuned Caddy PCM
LS1 now Tuned PCM
Yeah we get to see if I can get any thing more out of my Caddy program also
DUNEZRUNNER
01-29-08, 09:35 PM
AJ,
I have one of the shelby series 1 engines and I am planning on running it in my sandrail. With this tune you developed will it be possible for me to run the engine "stand alone" with only me hooking up a few wires to the engine. I have the shelby PCM and the wiring harness. Will I need to gut the harness or will I be able to just tie up the "leftover plugs".
Any info would be greatly appreciated.
Thomas
AJxtcman
01-29-08, 10:42 PM
AJ,
Thomas
Yeah I will pm you
AJxtcman
01-30-08, 09:08 PM
I have 5 LS1 Setups in the works. I don't mean watchers, but I have orders and people are sending me harnesses to adapt:D
AlBundy
01-31-08, 01:12 PM
So when does the $$$ come in? I need a loan.:eek:
mazda1949
02-04-08, 08:39 AM
AJ, how are the automatic transmission controls for the LS1 PCM for the northstar coming?
Also have you had time to install the blower on your fiero yet?
Mazda1949
AJxtcman
02-12-08, 08:34 AM
I will need to know some more info about the cars.
Tire size
Final Drive Ratio
VSS Pulse Per Rev
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Shelby%20Tuning/TireCalc.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Shelby%20Tuning/tirecalc2.jpg
caddysornothin49
02-25-08, 07:00 PM
So is this program available for purchase yet? If so where? I have a 01 sts and would love to get it tuned.
AJxtcman
02-25-08, 07:51 PM
This setup won't work for you, but I have one that will.
http://www.cadillacforums.com/forums/northstar-performance-technical-discussion/105315-northstar-tuning.html
This one will. No need to read all the crap that has been posted. Just the last 100 post should do :stirpot:
No really That thread is the thread, but it is long:thumbsup:
caddysornothin49
02-25-08, 11:18 PM
Thanks AJxtcman!
caddysornothin49
02-26-08, 02:20 AM
K a lot of good info but not really what I was looking for. I was hoping for something more along the lines of a website to get me going in the rt direction.
Shaggy
02-27-08, 06:10 AM
This would be that website. You have no other options.
submariner409
02-27-08, 05:37 PM
He's ^^ looking for plug n' play, which doesn't exist for his car. AJ is the only act on earth.
caddysornothin49
02-27-08, 07:43 PM
Lol come on guys! I'm not looking for a plug and play. I can read and its pretty obvious that the N* is an engine that can't have much if anything really done to it when it comes to mods. I swear sometimes you treat new people like they are retarded. I'm pretty sure we are all here cause we like the same thing. Some of us have more knowledge in cars then others. But whatever life goes on. I did have a question about the Westers place in Canada. Just wanted to know if this place was ever able to do anything with the N* or not? If so what can they do and how much does it cost?
Thanks
AJxtcman
02-27-08, 09:34 PM
I am in Vegas:shhh:
I will get to you on this (Wester's) in about two weeks. :o
Long story that I cant go into yet.
caddysornothin49
02-27-08, 09:59 PM
Sounds good! Appreciate it AJ
AJxtcman
05-08-08, 08:41 PM
Just joking :lies:
caddysornothin49
05-14-08, 01:31 PM
Wow AJ.... Your sarcasm is just hilarious! Keep it goin 4 sure :histeric:
mazda1949
05-18-08, 09:19 PM
Hey guys, I finaly got to drive my little mid engine Northstar powered Mazda pickup. Look on page 9 of this thread if you want to see old pics of the truck. I'll try to post some more pics and info later on when I have the time.
I did install a single turbo just to see what this thing was going to do. I didn't run a whole lotta boost but what little I did run was awesome!!!!!!!!!!!!!!! 6lbs to be exact. I can go all the way up to 35lbs but I dont think my stock engine will stand much more than that without scattering a bunch of parts all over the road!!!! Im going to build me a good stout engine when I get all the bugs worked out.
Lyndon Wester at Wester's Garage did me an LS1 ECM with a turbo tune. I cant even begin to tell you all what this was like. I was expecting the truck to spin like crazy but I was amazed. The tires are 235-50-ZR18 Firestones . I thought if it wouldn't spin the front end might come off the groung but it didn't. It just took off like a rocket and pinned me back in the seat without any wheelspin at all. I dont think the truck weighs much more than 2200 lbs not counting the northstar engine and tranny.
Right now I have a 3.11 gear in the 4T80E tranny but I've got a 3.70 Im going to change it to later on. Lyndon wasn't able to get the tranny controls working in the LS1 ECM in a reasonable length of time so I went with a stand alone Power Control Solutions - Transmission Control Unit which is very tunable. I think I might like it better anyway. I can change line pressure , shift points , TCC , tire size, VSS and gear ratios and such. This control unit will let you have a performance calibration and a normal driving calibration with a flip of a switch. (A) for performance and (B) for normal driving.
I got to drive this thing about four or five times up and down the road in front of my shop before it decided to twist one of the axles in two. This thing has an awesome amount of torque with the turbo. Im having another set of axles made as we speak. Im giong to try some 4340 and have it heat treated this time. The axle shaft is what broke not the joints. The stock Caddy CV axles are definitly not going to be strong enough. Anyone got any ideas on stronger axles?????
I hope AJ will chime in on this one. He has a lot of experence with these engines and ECM's . I'd like to know if he's made any progress with his super charger for his Fiero to.
AJxtcman
05-18-08, 09:47 PM
Nice steve
I think you can get Strange Axles or Curry Axles to make you some.
I have seen then done up with a flange at the trany side. They look like a VW axle or ones from the front of a GM 4X4
mazda1949
05-19-08, 09:09 AM
Hey AJ do you have any pics or a website I might go to to see these flanged axles. I might be able to make some of this stuff myself. I also am a partner in a machine shop but we dont do splines. We have 3 CNC lathes and 2CNC Mills. I can do splines but the way I would have to do it would take forever.
My buisness is the Garage buisness, I've did that for 40yrs. I furnish the building for the machine shop and dont do a whole lot of work in there.
I would like to talk to you personally but I dont want to do it here in the forums. I dont have enough post to PM you so if you could tell me how we can communicate in private let me know.
Steve
mazda1949
05-20-08, 04:18 PM
http://www.cadillacforums.com/forums/images/editor quote.gif
mazda1949
05-20-08, 04:22 PM
Here are some pics of the the turbo if anyone is interested.
http://i255.photobucket.com/albums/hh158/mazda1949/100_1097.jpg
AlBundy
05-21-08, 01:45 AM
There is always interest in the future development of the N*.
Highline Cady
05-21-08, 02:39 AM
Nice!!!
eldorado1
05-21-08, 10:32 AM
What turbo is that? doesn't look water cooled.
mazda1949
05-21-08, 02:51 PM
Hey Eldorado, the turbo is a (Super T70/T3 Turbo Charger 4" .70 AR Stage IV 35psi) and I think you mean intercooled in stead of water cooled. You dont have to run an intercooler but Im sure its worth a little more horspower.
Steve
mazda1949
05-21-08, 03:03 PM
More pics
http://i255.photobucket.com/albums/hh158/mazda1949/100_1101.jpg
http://i255.photobucket.com/albums/hh158/mazda1949/100_1098.jpg
http://i255.photobucket.com/albums/hh158/mazda1949/100_1094.jpg
mazda1949
05-21-08, 03:09 PM
http://i255.photobucket.com/albums/hh158/mazda1949/100_1090.jpgMore
http://i255.photobucket.com/albums/hh158/mazda1949/100_1096.jpg
http://i255.photobucket.com/albums/hh158/mazda1949/100_1091.jpg
eldorado1
05-21-08, 07:07 PM
Steve
No, I mean the turbo isn't water cooled. You'll have to idle it for 30 seconds before turning the engine off or you'll coke the bearings. Water cooling eliminates that and makes for a better "daily driver".
T70 is a little small but it will give you plenty of midrange torque.
Nice job on the install. Looks very clean. What did you do to the throttle cable to get it to reach?
mazda1949
05-22-08, 01:14 AM
The throttle cable and the gearshift cables made me put on my thinking cap. I used the throttle cable housing from the mazda on the gas pedal side and the caddy cable housing on the engine side. I used a section of 1/4 inch stainless tubing in between which ran down the frame rail under the truck. The Mazda cable had a nut and stud adjuster that hooked to a bracket on the mazda intake. I welded a short section of 5/16 inch tubing on the front end of the stainless tube so I could slide the mazda cable in for the adjuster. I used that end to take up the slack and have some adjustment. On the other end I simply slid the caddy cable housing inside the 1/4 tube until it butted against the mounting part of the caddy cable housing. I was able to buy the inside stranded cable in one long peice and crimpable ball ends and barrel ends to complete the job. I couldn't find a cable housing long enough so I just made my own. I know this was a long explanation but you asked!!!!!!!!!!!!!! Ha Ha
I used a console and shifter from a 1999 malibu and believe it or not the cable and housing were just barely long enough and worked perfectly.
My original plan was to run twin turbo's and I might still do that. I think two of the turbos like I have would be more than enough. You sound like you know quite a bit about turbo's. This is my first. I've got a lot to learn.
Im an old dirt track round D round boy and never fooled with turbo's until now. A turbo is the cheapest horspower I've ever bought. I couldn't beleive how much more power it gave my northstar with just 6lbs of boost.
Thanks for asking about my little project. Im real excited about this little ride. Its going to be a sleeper when I get the bed cover on.
Steve
mazda1949
05-22-08, 01:28 AM
Ive got to take some more pics. I have since installed my wastegate and my oil drain line. They look kinda neat also.
Steve
mazda1949
05-22-08, 07:17 PM
Pics of wastegate and oil drain back lines.
http://i255.photobucket.com/albums/hh158/mazda1949/100_1105.jpg
http://i255.photobucket.com/albums/hh158/mazda1949/100_1103.jpg
http://i255.photobucket.com/albums/hh158/mazda1949/100_1102.jpg
mazda1949
05-23-08, 08:17 AM
I hope Im not boring you all with all this stuff. Im just kinda proud as I get stuff accomplished. Im 59yrs old and am surprised Im still as ambitious as I am.
I get my new axles back today I hope. I hope they are stronger than the last ones I had. Maybe the heat treat and harder metal will do the trick this time. I was going to up the boost a little at a time and am sure the axles need to be strong enough for that.
Also I am going to be installing a blowoff valve (BOV) in the next day or so and I'll show some pics of that to.
Now to the prayer request. Im sure this forum has beleivers in prayer and its power!!!!!!!!!! I was diagnosed a month ago after a CT scan for a kidney stone which I passed within an hour after I got to the ER to see if I had any more stones before they let me go home. They came back 30 minutes later and told me I didn't have anymore stones but that they saw a mass on my pancreas. I have been in hospital after hospital for the past month trying to figure out if I have cancer or not. For some reason no one has been able to do or get a biopsy because of the location of the mass. The mass is plain to see with CT and MRI scans but is impossible to get to for a biopsy.
The bottom line is Im going in for surgery to remove the mass on Wednesday. This is a very serious opperation and am hoping that if it is cancer we caught it in time and it hasn't spread anywhere else.
I wanted to live long enough to see my two little grandboys (3 and 4yrs old ) grow up and to finish my truck.
Please remember me in your prayers!!!!!!!!!!!!!!!!!
thank you
Steve Sears
AlBundy
05-23-08, 04:13 PM
You have my prayers good Sir and good luck.
eldorado1
05-23-08, 05:27 PM
best wishes for a speedy recovery!
mazda1949
05-23-08, 08:30 PM
Thanks Guys, I aint never been scared of nuthin but this has got me really worried. Im trying to stay positive!!!! After all I gotta finish this truck.
Keep me in your prayers!!!!!
Thanks again
Steve
AJxtcman
05-24-08, 07:58 PM
Thanks again
Steve
Get well soon
AJxtcman
05-24-08, 08:02 PM
This is the first version I will be making changes to them.
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Schematics/1.gif
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Schematics/2.gif
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Schematics/3.gif
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Schematics/4.gif
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Schematics/5.gif
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Schematics/6.gif
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Schematics/7.gif
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Schematics/8.gif
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Schematics/9.gif
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Schematics/10.gif
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Schematics/11.gif
http://i224.photobucket.com/albums/dd25/AJxtcman/Shelby%20stuff/Schematics/12.gif
Dubya
06-25-08, 01:41 AM
so what ever happened to this?
AJxtcman
06-25-08, 07:59 PM
I have a couple of them done, but I am busy getting my house ready to sell. I need to move to the Charlotte area. I won't have any time to pick this back up for a few months
AJxtcman
12-28-08, 12:42 PM
Sorry guy's I messed up these pictures. :mad:
http://i224.photobucket.com/albums/dd25/AJxtcman/Mazda%20Truck/HPIM1374.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/Mazda%20Truck/HPIM1377.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/Mazda%20Truck/HPIM1379.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/Mazda%20Truck/HPIM1378.jpg
http://i224.photobucket.com/albums/dd25/AJxtcman/Mazda%20Truck/HPIM1375.jpg
AJxtcman
12-28-08, 12:49 PM
If someone wanted to spend the time to sort out the Trans functions I could get this setup to run in a FWD Cadillac without any DTC's. If I could get some time I would take care of it myself. I have the PCM setup to control the engine in a Cadillac without setting DTC's and it will send out all the required Class II data messages so all the other modules will be happy and not set DTC's:yawn:
97EldoCoupe
12-28-08, 03:01 PM
AJ - I'll be sending you a PM about this in a few minutes....
SupRNatural
12-28-08, 09:51 PM
Interesting Topic: I for one am interested In a LS-1/Auto PCM :yup: for a 1996 Y Eldorado. If this ever becomes reality, please feel free to let me know... BTW AJ I sent you a PM a while ago. Thanks.
AJxtcman
12-29-08, 02:56 AM
It is 1am and I just got back to my house in Milwaukee. I have been down in Rock Hill at my other house for the holidays with Jodie and the Kids.
I will keep you posted.
SupRNatural
12-29-08, 09:32 PM
:mystery::preach::ohthedrama: I'm on standby...
AJxtcman
12-29-08, 10:41 PM
You have a 96 Y and that is a hard one to get every thing lined back up. I did a couple. #1 had a ABS/TCS message. #2 did not pass emissions. :bonkers:
#2 was a revised version and I had plans to install it in #1's car, but then it wouldn't run the OBD II readiness test that are required to pass emissions.
1996 programs are all by them selves and they take the most time to reassemble.
I think I have got a total request of 4. That is a very small number for such a hard program.
AlBundy
12-30-08, 12:29 AM
Therefore 96s and 97s aren't the same. Does this only apply to the LS1 program?
CadillacSTS2003
12-30-08, 12:27 PM
nope
it means u gotta trade you 96 base eldo in for a 97+ ETC there AL tehe
SupRNatural
12-30-08, 03:05 PM
:thumbsup: I guess Baby will have to settle for the ham sandwich... I tried.:alchi:
AJxtcman
01-03-09, 03:04 PM
This is from a LS1 Northstar customer
I had some software issues and couldn't tune his on the spot. I left him with a Manual Trans Fiero Tune that was setup for N/A. I have a new Boost tune all finished up for him and it will be mailed out soon.
AJ, I want you to know that this program that you wrote to my ECM is awesome.
I finally figured out what was wrong. The fuel pressure was dropping to 18 lbs at full throttle. I put another pump on it and wala!!!
This thing is so fast I cant contain myself Im so excited. Its so fast it is really scarry!! You can take of from a dead standstill and it just leaps without spinning untill it reaches 20 or 30mph or so, no bog, lags or delays and then it lights up the tires. Then it takes a hold and pins you back in the seat and never stops pulling. You gotta ride in this thing now!!!!!!!!
It still has a little problem with the idle though. Stephen got the tranny shifting much much better. Hooked the laptop up and adjusted here and there with the tranny program.
Call me some time if you want. Man am I excited!!!!!! I've never rode in anything that fast!!
AJxtcman
01-03-09, 03:14 PM
I ran across some 4L80E stuff in this program. :hmm:
What does that mean? :rolleyes: It means that is has an Input Speed Sensor in the trans. Hmmmm The reason the program won't work on a 4T80E is because it doesn't have the capability to have an ISS. I guess it does. :hmm: more work is Needed, but this is a big step on running a 4T80E on the PCM
SupRNatural
01-03-09, 06:51 PM
AJ will a 97 PCM with LS1 program fit in a 96???
AJxtcman
01-03-09, 09:07 PM
No
The 96 to 99 all use the same PCM's
96 uses UART and Class II data. 97 on up just use Class II.
It is all good I just need more time to get my house on the market.
mazda1949
01-03-09, 11:56 PM
AJ you da man!!!
OK guys Im gonna brag on old AJ here a little bit. If he gets my little mazda truck with the Northstar engine much faster with the turbo tune, Im gonna have to put some slicks on and some wheelie bars. I dont think it will be long until AJ has this LS1 PCM perfected even with the tranmissions controls.
I dont think I've ever saw anyone as dedicated as AJ on a project as he is. I dont think most people realize what an undertaking it is to come up with a program that will run on a Northstar. Without AJ I dont think this LS1 program for the Northstar would have ever even gotten of the ground.
I for one want to personaly thank you AJ for all your efforts so far!!!!!!!
BTW Im the customer AJ is talking about in his post
Thanks
mazda1949
F55 STS
01-07-09, 08:58 PM
Hi
Will this work in a 03 STS with out setting codes?
Do you make an adapter harness or something?
Thanks
AJxtcman
01-15-09, 08:19 PM
HPTuner has been offering a tuning package for this setup for a while!
The software I own has more parameters.
Oh yeah I have HPTuners also! I know for a fact that Wester's DDT has more parameters.
Just ask the V6 guy's if Wester's/TunerCat has more Parameters than HPTuner's
So it has been a year now since Wester's set me up. I would think within a year HPtuner will have the 96 to 05 Northstar VDF's out.
I won't be able to stop it. :rant2:
N0DIH
01-15-09, 09:41 PM
I counted around 70 parameters in the V6 in HPT, there are around 300-400 in my tuner package..... Yeah, HPT is a joke in the V6 segment.... They don't care, they don't support much, they have zero plans for updates to make it better, they don't support many PCM's at all, just overall a poor offering...
AJxtcman
01-21-09, 08:22 AM
I talked to Steve yesterday to see if had the PCM with the new tune in the the truck yet. He told me that the tune I left him with runs really good. He was driving drown main street and nailed the gas at 30 mph. The lower control arm ripped off the frame. :helpless: He said it got the truck stopped with out any further damage.
I think he said it was the from bracket on the right side, but this is the bracket I am talking about, just the left rear.
http://i224.photobucket.com/albums/dd25/AJxtcman/Mazda%20Truck/100_1097.jpg
I hope to hear today how the new tune runs. :D
wait4me
01-21-09, 10:54 AM
I have that tune file also made for the ls1 computer. A customer hired me to make a file for it back in 2001 i think?? I dont think it was made from gm. It was made somewhere for someone. The ls1 computer is not able to handle Variable cam timing.
In our software, efilive, you can transfer transmission segments from files as long as the operating system matches another you need. So that will not work of putting in a front wheel drive trans as, i dont believe there where any out there running it. The file you have is its own operating system and layout. I dissasembled it and found about 70 tables, as it looks simular to a 1999 ls1 type format, and then stopped. I only added enough to help out a customer that needed to add more fuel because his was running WAYYY lean.
wait4me
01-21-09, 11:07 AM
OHH one more kinda warning, The S h elby people have been sueing the piss out of ANYONE that is using / copying anything they own.. http://www.ffcobra.com/forums/showthread.php?t=206494
AJxtcman
01-21-09, 02:18 PM
Jesse I am using the Stock GM OSID for this setup and a 01_0X VDF.
Nice to see you over here.
Mick & Ross have emailed and sent messages to me to get a hold of you for some help on the Simtec PCM
wait4me
01-22-09, 10:39 AM
simtec sounds kinda fun.. :)
Yeah im just finally getting some free time to start checking out other cool forums. This one is pretty good.
An explination of what i meant by using someones code is, with a hex editor, go to location 6310A in your file. IF you have a RAW bin pulled from the ecm, goto location 7Ed0a.
The gm osid is not a gm id released to i dont think. That is why i never put it in for the efilive guys to use.
AJxtcman
01-22-09, 08:27 PM
Yes I have seen the note
I didn't acquire my cal from a cable like that. I pulled it off the server and stored it in my Spat Command Center! :shhh:
AJxtcman
01-22-09, 09:00 PM
I have seen that EFILive stuff :histeric:
VIN 12345678XL000055
Engine ____________ N/A
Transmission _______ N/A
PCM flash _________ 512Kb
Operating System __ 0936114X
Calibration _______ 2147483647
OS ID ___________ AL
Cal ID
BCC ____________ CYCB
OS Level
Cal Level
Cal file name _____ 0936114X.cal
Cal file version ____ N/A
Cal file date ______ N/A
Operating System _______ 0936114X _ $6790
Engine Calibration _______ 9360697___ $8EE1
Engine Diagnostics ______ _9390351 ___ $6091
Transmission Calibration ___ 9360702 ___ $A77C
Transmission Diagnostics __ 9360704 ___ $B61B
Fuel System _____________ 9360705 ___ $ACAA
System__________________ 9386828 ___ $82F4
Speedometer ____________ 9360708 ___ $A6F5
AJxtcman
01-22-09, 09:37 PM
Well I got the riped out spindle arm mount on the frame fixed on my truck and put the new PCM in and it does seem to be a good bit faster. Its sounds a little different and seems to have more torque all through the power range.
I have a 2800 stall converter coming within a week or so. I hope that is going to help me come off the line a little better. Im hoping by the time I come off the line the turbo will be spooled up and I can feather foot it if it wants to spin. Right now it has a hesitation and lag or bog comming from a dead stand still . Its not noticable at all just driving normal. When I try to bring it off the line it bogs pretty bad and then when it gets to about 20 or 30mph the turbo spools up and it starts to spin the tires, even though its spinning its still pulling pretty hard. Sometimes the truck will want to torque off to the left. This thing has an awsome amount of torque with the turbo. Its unbelievable!!!! I cranked the boost up to 9lbs with my new home built boost controler. I wonder how much boost this stock engine will take before I start scattering parts?
I beleive the truck will be in the middle elevens at the drag strip. We marked of a 1/4 mile in front of the shop (1320 ft) and with a stop watch it was well below 12seconds several times. This was with the old PCM so Im sure the one you just wrote will be even faster especially if I can get the lag out.
Lookin good
mazda1949
01-24-09, 01:01 AM
Hey guys , I got my 2800 stall torque converter today. I'm hoping to get it in the truck sometime by the middle of the week. I would try to do it tomorrow but I've got to go to Atlanta and see my two grandboys this weekend. A couple of weeks ago I had to go to my oldest grandsons daycare to pick him up, this is the 5yr old and he looked up at his teacher and said, Miss Janie this is my Popa and he's got a hotrod truck!!!!!!! I beleive he's gonna be a chip off the old block. He likes Popa's truck!!!!
Guys , for a stock Northstar engine with a turbo I've never set my butt down in anything this fast. Old AJ has got his stuff together on this one. He's been awful nice to work with me on my little project so far. If any of you are thinking of going with the LS1 ECM tune AJ is the man that can get you to laying some rubber down. Their is no comparison to the first tune I had on my LS1 PCM that was done by someone else. AJ's tune is awsome!!!!!!!!!!!!!
I turned 60yrs old last weekend and when I sit down in my little Mazda rear engine pickup I feel like Im in my
20's again. This is the most fun I've had since I used to drive Late model (round D round) dirt cars. I think Im going through my second childhood.
Well boys I gotta go for now . Me or AJ will keep you posted on what happens next.
Steve (aka mazda1949)
mazda1949
01-28-09, 12:53 PM
Here is a video of my truck.
mazda1949
01-28-09, 01:12 PM
http://<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/ZX7mEQPQfkY&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ZX7mEQPQfkY&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
N0DIH
01-28-09, 01:36 PM
You mean this one?
http://www.youtube.com/swf/l.swf?swf=http%3A//s.ytimg.com/yt/swf/cps-vfl74240.swf&video_id=ZX7mEQPQfkY&rel=1&eurl=&iurl=http%3A//i3.ytimg.com/vi/ZX7mEQPQfkY/hqdefault.jpg&sk=ilwNFf3oTI2R4aqEsANAXltfMpxF4bDwC&use_get_video_info=1&load_modules=1
AJxtcman
01-28-09, 02:42 PM
Hey recheck that Fuel Pressure.
With the ignition ON, and engine OFF (zero vacuum), system fuel pressure at the pressure test connection should be 333-376 kPa (48-55 psi).
Start the engine. You should have a (3-10 psi) drop
Say your target is 55 psi WOT. Then you want about 50 psi running.
If that doesn't take care of the black smoke and the flutter drop the pressure to 50 psi WOT or 0" vacuum. This may take you down to about 45 psi running. Recheck to see if that gets rid of the flutter/black smoke/lag.
AJxtcman
01-28-09, 02:45 PM
ZX7mEQPQfkY
mazda1949
01-28-09, 03:36 PM
Thanks AJ for embeding that video for me . I've got to figure out how to do that. I must be missing something but I'll figure it out sooner or later.
Old truck sounds pretty good doesn't it? Not only does it sound good it is fast as H#%*$L to.
I'll try the fuel pressure stuff and see if that helps .
Steve
AlBundy
01-28-09, 03:45 PM
Old truck sounds pretty good doesn't it? Not only does it sound good it is fast as H#%* to.
Steve
Nice video. Keep up the good work.:thumbsup:
AJxtcman
01-28-09, 07:43 PM
Steve
Any time you want to learn something like that. Hit Quote and it will show you what I did.
I only inserted the vid #
The Tony Show
01-28-09, 07:58 PM
How am I just now noticing this thread?
Awesome work by AJ, and awesome truck!! :thumbsup: :thumbsup:
cbulen
03-19-09, 04:19 AM
AJxtcman,
I attempted to PM you, but as I am too new of a member to this forum, I cannot sent PM's yet. Would you contact me, or provide your contact info, as I would like to talk to you about buying one of your LS1 PCM solutions and wiring harness for my 1996 Northstar. I am using a Manual transaxle, so no tranny management is needed in my case. Basically, I need a stand-alone ECM solution. I am considering the CHRFab Holley system, but I would like to look into the LS1 solution you have, first.
Chris
cbulen at sbcglobal dot net
AJxtcman
03-19-09, 08:24 AM
contact me at cadillactuner@airfueltuning.com
Starfire88
04-15-09, 06:15 PM
For 100% clarity which transmission are you able to run with the LS1 PCM?
AJxtcman
04-15-09, 07:39 PM
The was originally a RWD Manual trans Program. I have it running with a FWD Manual trans. I also had it running in a car with a SECOND controller for the 4T80E. This was similar to an 06 DTS setup.
cbulen
08-03-09, 05:30 PM
AJ
Willl the LS1 PCM support an aftermarket fuel pump? I am planning on using a 255 lph Supra fuel pump in my MR2 + NOrthstar project, and I think this fuel pump is actually too big at lower RPMS/lower horspower (ie not wide open throttle). THe SUpra Turbo Computer controls the fuel pump by dropping the voltage it supplies to the pump when you are not driving the SUpra at WOT. It kicks up the voltage when more gas is needed. This pump is capable of up to around 750 hp.
http://www.gadgetonline.com/FuelPump.htm
N0DIH
08-03-09, 06:03 PM
GM doesn't manage the fuel pumps like others, Ford does this now too. GM just puts injector characterization data in the PCM so it can compute instead of try to mechanically manage it.
GM does on the Supercharged bump up the fuel pump speed, known as a 2 speed pump. Like my SC 3800, around 125 kPA it kicks in the second speed of the pump.
AJ
AJxtcman
08-04-09, 07:43 AM
GM also uses a PWM fuel pump on many other newer cars and trucks and the Fuel System is a returnless on-demand design.
This is not supported by the older LS1 type PCM.
