View Full Version : my fifth wheel won't drop
still_walkin
10-31-07, 08:29 AM
I found a fifth wheel and I installed it the backup lights work the manual drop works but I have one problem the electric drop won't. I'm assuming its gfrounded correctly cause the lights work. I plugged it up to a 12v connection and got nothing not even a spark. What is the correct fuse rating for it and what am I doing wrong. I know its supposed to be wired with the trunk pop system but I was going to wire it to a relay so I can drop it with the trunk or without so why doesn't it work?
submariner409
10-31-07, 11:11 AM
Fifth wheel ??? Are you pulling a trailer with your car ?
still_walkin
10-31-07, 11:17 AM
Sorry about that some people refer it to a fifth wheel. I was talking about a contiental kit. The decorative tire that sits on ur bumper
submariner409
10-31-07, 05:19 PM
Sounds like a bad ground somewhere in the bracket/solenoid wiring. No spark no 12v.
still_walkin
10-31-07, 05:27 PM
So if its a bad ground how come the reverse lights work . The bolts I used to connect the kit are steel and the bumper has no paint on it but the kit has black paint where the bolts go . Which is weird cause the lights work. What's your suggestion
still_walkin
11-01-07, 08:50 PM
Thanks submariner409 you were right it wasn't enough ground for the pop release . I had to scrap away more of the paint from the wheels bumpers end.
submariner409
11-01-07, 10:03 PM
Good catch. I wondered if the wheel package has its own ground wire in the wiring harness so you could hook it to a solid ground in the trunk.
still_walkin
11-01-07, 10:17 PM
Well I would think that too but it doesn't. For example when I was testing the lights I was having problems getting them to work so I removed them from the kit hoowked it up to a 12 volt and the back casing for the light is metal and it worked when I used that as a ground so I was taken under the assuption that the kit will be grounded by the bumper since its attached to the chasis but it didn't work for the release but it worked for the lights so I had to add a ground from the car to the kit. I grounded the kit and it worked. But the stock harness for the kit has 3 wires but they are seperated 2 for the lights and release so I don't know it worked;)
cadillac_pimpz
11-19-07, 01:31 AM
you building a slab?
still_walkin
11-19-07, 10:08 AM
Yes i am I want it to have the slab look but not to flashy and for it to have a texas/classic cadillac look. Check out my link.
http://www.cardomain.com/ride/2238122
cadillac_pimpz
11-19-07, 04:19 PM
Just get some candy paint and 84's and your all set.
still_walkin
11-19-07, 04:44 PM
True thanks I want some vogues and some more grain. Also I want to add a reverse camera, hp alternator and that's about it for now
still_walkin
02-06-08, 04:28 AM
i figured it out it was a broke solieond i had to replace the whole latch and solieond and the manual release doesnt work .but it drops
