I found this http://www.installer.com/item/display_item.php?it=70-1856
Which looks like good times if I plan on powering my speakers using the factory wire and my new headunit. The question is, is this harness overkill if I plan on going total aftermarket and running RCA's to the trunk and re-wiring the speakers? Or is it worth it just to make the rest of the wires plug and play even if i dont use the speaker wires.
I'm thinking probably the 2nd but I was hoping somebody had some experience in this. Because if thats the case probably what I will do is run the front and rear of the HU at first and then at the 2nd stage of install run a 4ch amp.
Thoughts?
Thoughts?
