View Full Version : Snow Tires 05 STS
carman33
10-20-07, 04:42 PM
Love the site, OK you guys I have a 05 STS V6 RWD. It has the original miserable Michelin tires on it now 235-50-17 fr and 255-45-17 rear. I would like to buy 4 winter tires but no one I have found has a matching set of snow tires this size. My dealer he told me he has never ran into this before ?? ( I live in upstate New York) but said I would need to stick with the factory sizes but he didnt know where I could get them. He also said if I ran with 235 50 17s all around which Bridgestone makes it would affect the electronics. Has anyone else ran up against this?? Thanks
dkozloski
10-20-07, 05:02 PM
I have an '06 V8 AWD STS. I use 235/45/17 WS-50 Blizzaks all the way around and it works perfectly. TireRack had a big closeout sale and I got them for $132 each.
Caroutisine
10-20-07, 06:44 PM
I have Michelin Pilot Alpin 235/50/17 on all 4 corners on the same car you have.
2 seasons with no problems. Your dealer is wrong about having to keep the same sizes front / rear.
The winter performance of these tires on this car is acceptable.
Edit:
I switch over to the factory tires on aftermarket rims in the summer (back to the different front & rear tire sizes) and all I have to do is reprogram the Tire Pressure Monitors using the instructions in the owners manual.
carman33
10-23-07, 06:29 PM
Thanks so much for the info just wondering if you used the 235 50 17 snows on the rear using the 255 45 17 rims.
Caroutisine
10-23-07, 08:47 PM
Yep. :yup:
I keep the rims in the same place (front to rear) and the tire size 235/50/17 fits on both wheels.
carman33
10-24-07, 08:28 AM
Thanks again you have been more help than my dealer or GM.
BirdJC
11-02-07, 03:25 PM
Edit:
when you do this, do you have the tire pressure sensors switched to the aftermarket rims? Or is that something you can do yourself???
Caroutisine
11-02-07, 09:10 PM
I have pressure sensor monitors installed in both sets of rims. When I switch them, I just reprogram following the instructions in the owners manual.
