: RWD Northstar(s)?
S10xGN
04-26-04, 09:52 PM
Hi All,
Has Cadillac built any RWD northstar powered cars? If so, what body style and years were offered?
TIA!
slk230mb
04-27-04, 01:01 AM
The SRX and XLR.
Pimpin_Whity
04-27-04, 08:49 AM
i didn't know u could get a NorthStar SRX :hmm: , the XLR is a RWD NorthStar but the tranny is in the back like a vette. the new STS that's going to come out will have an RWD NorthStar. that's about it :rolleyes:
Caddy_Daddy472
04-27-04, 03:32 PM
i have already posted something like this, i was told that the N* would bolt up to a 200 4R tranny, however, i dont know if it will hold up to the power.
BeelzeBob
04-27-04, 04:11 PM
The RWD Northstar was a new engine for 04.... it is in the XLR and the SRX and will also be in the new 05 STS. There was never a factory RWD, longitudinally mounted Northstar prior to this. All of them were FWD and mounted in a transverse configuration. You can put a FWD, transverse Northstar into a specialty (hot rod, street rod, sand rail, etc....) in a longitudinal, RWD orientation if you use the correct tranmission parts.... If that is the type of application that you are talking about then check out www.chrfab.com (http://www.chrfab.com) as they are the specialists at converting the FWD Northstar to RWD applications.
Smokey
04-29-04, 09:52 PM
What does the CTS V-Type have in it?
slk230mb
04-29-04, 11:04 PM
5.7L LS6 Engine, same as in the Z06 Corvette
S10xGN
04-30-04, 11:03 PM
Kinda what I was thinking, guess a few years down the road we'll have some better material for engine swaps...
gothicaleigh
04-30-04, 11:33 PM
The SRX has the same engine as the XLR. They both run HydraMatic 5 speed transmissions with a driver shift select feature, but the XLR's is in the rear like you said...
320hp 4.6L V8 Northstar with VVT
It will also appear in the new STS.
Greg55_99
05-26-04, 02:55 PM
There might be better material now. I'm a junkyard dawg and checking out the Northstar (and other motors) has been high on my list for a RWD conversion. I think the biggest issue to get around is the rear mounted water pump and assembly. CHRFab has some nice pieces to start a work around on that. I'm theorizing that an external belt driven waterpump like one out of a water cooled VW Vanagon might be plumbed into place.
It also seems to me that if you had a GM S10 2.8L V6 bellhousing, you could have it modified yourself for not much coin. 94-95 2.2L S10 bellhousings have the GM 60 pattern on the block side and the Ford T5 pattern on the tranny side. I should also point out that the 96-02 2.5L Dodge Dakota bellhousing can be used to bolt up the Toyota Supra Turbo R154 5-speed to the Northstar. So, you have a few choices. All have to be modified of course.
Recently, I've found that the flywheel from a 3.2\3.5L Isuzu Trooper has it's bolt holes less than an eighth of an inch off from the Northstar pattern. The flywheel is the same diameter as the Northstar one. Could be that by elongating the holes a bit and having a spacer made to center the flywheel on the Caddy snout, you may save yourself quite a few bucks.
Just the observations of a Junkyard Dawg.
Greg
Sean McDonald
06-07-04, 06:49 PM
Apparently the Isuzu Trooper rear end will bolt up to the STS's or so I've heard anyways.
