: STS 2005 AWD 30,000 Miles
FCBank
10-11-07, 11:45 AM
Please tell me if anyone has had the following problem:
2 days prior to engine shutdown, low water warning/low oil warning/1 lb aire pressure warning in LF then engine woudl start, go forward 50 ft and shut down. Car had to be towed. Dealer diagnosed clogged catalytic convertor. Car in shop for 1 week waiting on parts.
Anyone familiar with this problem?
Thanks
Jack:banghead:
dkozloski
10-11-07, 04:18 PM
It sounds to me like basic maintenance has been totally ignored. It needs some coolant, some oil, and some air. A jackass wouldn't put up with treatment like that either.
malcolm
10-11-07, 09:27 PM
I had clogged catalytic convertor problems in an 82 Olds and it definately stops the engine a common problem at that time but I have not heard of it in recent years.
dkozloski
10-11-07, 09:31 PM
It would require severe misfires over an extended period of time and/or foul fuel to plug a catalytic convertor.
z06bigbird
10-11-07, 10:56 PM
Did car show a code for convertor?
Those things have become enormously expensive since the shortage of various metals.
dkozloski
10-11-07, 11:23 PM
There's less than $50 worth of rare metals in a catalytic convertor. The stuff is applied to the innards in an extremely thin layer.
Maximln
10-12-07, 12:46 AM
I just had to have my catalytic converter replaced on my car. It didn't stall or anything but the check engine light kept coming on intermittently. I took it and they said the cat was faulty and had to be replaced.
Max
dkozloski
10-12-07, 01:34 AM
Misfiring cylinders will cause a CAT convertor to burn up. Leaded fuels and worthless additives will poison the catalyst.
