View Full Version : Found a V! Need a Vin check!
m32V
10-08-07, 11:20 AM
Found a 05 CTS-V CPO. Need a vin check. 1G6DN56S750188969
Also would like to have the in service date to know how much time is left on the CPO warranty. I've been lurking around here for a while and have finally decided to trade in my M3 for V. It's silver with about 40k miles on it, has Corsa exhaust and new tires. Any suggestions on what a good price would be? Thanks.
The Tony Show
10-08-07, 11:26 AM
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
06/16/2006 048910 # Z6720 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 29211 miles
06/15/2006 D89341 # Z2085 - ROADSIDE SERVICE (PREMIUM) 28000 miles
06/15/2006 D89342 # Z2080 - ROADSIDE SERVICE (TOWING) 28000 miles
06/15/2006 048644 # N6622 - WIRING AND/OR CONNECTOR - OCCUPANT INFORMATION SYSTEMS - R 29211 miles
06/15/2006 048644 # Z7901 - 1-DAY COURTESY TRANSPORTATION 29211 miles
06/06/2006 910684 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 29186 miles
06/05/2006 910684 # J5350 - PEDAL, ACCELERATOR - REPLACE 29186 miles
06/05/2006 910684 # Z7902 - 2-DAY COURTESY TRANSPORTATION 29186 miles
06/05/2006 910684 # R0760 - RADIO, REMOVE AND REPLACE 29186 miles
06/05/2006 910684 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 29186 miles
05/09/2006 906745 # H2505 - MODULE, ELECTRONIC BRAKE AND/OR TRACTION CONTROL - FOUR WH 28205 miles
05/09/2006 906745 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 28205 miles
03/20/2006 992558 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 25074 miles
03/20/2006 992558 # Z7902 - 2-DAY COURTESY TRANSPORTATION 25074 miles
03/20/2006 992558 # J3100 - RADIATOR ASSEMBLY - REPLACE 25074 miles
03/20/2006 992558 # D1135 - SENSOR, A/C REFRIGERANT PRESSURE - HIGH PRESSURE - REPLACE 25074 miles
09/06/2005 003371 # Z8013 - ROADSIDE SERVICE (FUEL DELIVERY) 11084 miles
09/03/2005 725548 # Z2085 - ROADSIDE SERVICE (PREMIUM) 11000 miles
03/18/2005 667059 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 10 miles
In-service date is 2/2/2005, so the CPO goes to 2/2/2011 or 100,000 miles, whichever comes first.
m32V
10-08-07, 11:32 AM
Wow. Thanks. It looks pretty clean to me. Do you have any comments about anything on there? Has all the recall work been done? Is there any way to tell if it has the higher end suspension?
The Tony Show
10-08-07, 11:53 AM
According to the VIN you posted, it has the FE4 (standard) shocks, but are you sure that's the right VIN? I ask because you said it's silver, and the VIN you posted is Black Raven.
z06bigbird
10-08-07, 11:54 AM
Need to print out an RPO complete list. Call any GM dealer with VIN. Only cost is a box of donuts.
m32V
10-08-07, 11:58 AM
I better call them to be sure. I haven't seen the car yet. That's the vin they gave me and told me it was silver with black interior.
The Tony Show
10-08-07, 11:59 AM
Option Codes
Ah8 - 10-way Pwr. Pass. Seat W/ Pwr. Lumbar Al2 - Power Lumbar Control
Am9 - Split-folding Rear Seat Aq9 - Seat Frt Bkt, Luxury
Ay0 - Inflatable Restraint Dri & Pass A45 - Memory Seat Adjuster
Ce4 - Washer Headlamp, High Pressure Cf5 - Express Open Sunroof
Cj2 - Hvac Frt. Auto Temp/aux Temp Dd8 - Mirror Auto Day/night I/s R/v
Dl5 - Decal - Roadside Service Info Dr5 - Mirror O/s Remote L/h R/h
E2c - Rapid Delivery System Fe4 - Suspension
Fe9 - 50-state Emissions Gt4 - Axle Rear 3.73 Ratio
Il5 - Trim Interior Design Jja - Pt Dress Subassembly Installed
J56 - Brakes, Antilock Ka1 - Heated Front Seats
Kg4 - 150 Amp Generator Ls6 - Ls6 5.7l V8 Engine
M12 - Tremec 6-speed Manual Trans Nt9 - Emission - Federal
N34 - Steering Wheel, Leather P32 - Wheel 18" Aluminum
Qkr - P245/45r18 W Rated R8e - Gas Guzzler Tax
R9z - Poms Expedite-sold Orders/tse Sll - Sold Orders
Uav - Dvd Navigation System Incl: Xm Satellite Radio - Over 130 Chnls Of Digital Entertainment Service Fee Extra.1st 3mos.inc (deletes Compass In Mirror) Ue1 - Onstar Communications System Incl 1yr Safe & Sound Plan
U2k - Xm Satellite Radio - Over 130 Chnls Of Digital Entertainment Service Fee Extra.1st 3mos.incl U30 - Instrument Cluster,tach,clock
U57 - 8 Speaker System Vm3 - Label-frt & Rr 5 Mph Bumper
V73 - Vehicle Statement Usa/canada 1sa - Cts-v Standard Package
1sz - Preferred Equipment Savings 19i - Ebony Interior Trim
195 - Ebony 41u - Black Raven
6mh - Comp Frt Lh Computer Sel Susp 7mh - Comp Frt Rh Computer Sel Susp
8gw - Suspension 9gw - Suspension
m32V
10-08-07, 02:13 PM
Ok it was the wrong VIN. Here is the right one: 1G6DN56S250103603
Could you run this one for me?
10-08-07, 02:44 PM
CLAIM HISTORY
09/14/2007 058083 # E0722 - TIRE PRESSURE INDICATOR SENSOR REPLACEMENT 42423 miles
08/30/2007 057355 # J1507 - MOUNT, ENGINE - FRONT - BOTH - REPLACE 42254 miles
07/25/2007 055314 # N3360 - MOTOR, SUNROOF DRIVE - REPLACE 41221 miles
07/25/2007 055314 # F2154 - BUSHING, REAR DIFFERENTIAL CARRIER SUPPORT OR MOUNT - REPL 41221 miles
07/25/2007 055314 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 41221 miles
11/14/2006 042905 # J3080 - RADIATOR ASSEMBLY - R&R 34210 miles
11/14/2006 042905 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 34210 miles
08/11/2006 F44020 # Z2080 - ROADSIDE SERVICE (TOWING) 36000 miles
06/15/2006 035004 # Z7901 - 1-DAY COURTESY TRANSPORTATION 23882 miles
09/19/2005 024481 # Y0039 - INVENTORY UPGRADE - REPROGRAM POWERTRAIN CONTROL MODULE (P 11402 miles
06/07/2004 A03603 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
That one is Silver for sure :D. It has the FE4 (standard) suspension also, and the CPO is good through 2/16/2011.
m32V
10-08-07, 02:55 PM
Thanks so much. Should I be concerned about the replacement of the Rear Diff carrier mount? That was only 1000 miles ago. What does VIP Freight/Postage mean? It doesn't really indicate what the towing was for on 8/11/06. Is that unusual?
urbanski
10-08-07, 03:25 PM
thanks for joining as a supporter :)
10-08-07, 03:41 PM
The diff carrier mount is a normal issue with these cars- it may have just needed tightening, but either way it's no big deal. VIP postage is when they rush deliver a part so the customer isn't without their car for too long.
The towing claim was just after the bushing replacement, so the owner probably was afraid of damaging the car by driving and requested a tow (which is unnecessary, but smart if you aren't familiar with the problem). The Dealer probably just waited a few days to submit the towing reimbursement claim.
It looks pretty good to me!
m32V
10-08-07, 04:16 PM
ok. thanks. I'm gonna leave work a little early and go check it out. Wish me luck!
The Tony Show
10-08-07, 06:15 PM
Have fun storming the castle!
:wave:
CIWS
10-08-07, 08:02 PM
:yeah:
POINTS for support !
rand49er
10-09-07, 08:38 AM
ok. thanks. I'm gonna leave work a little early and go check it out. Wish me luck!:food-snacking:
m32V
10-09-07, 10:51 AM
Cosmetically the car was ok. It had some scratches on the top of the passenger side fender (like they parked under a shrub), that they said they would buff out as best they can and apply touch up paint if I wanted. The nav buttons looked awful, like melting ice cream. I didn't realize that the button wear issue was that severe. How much money did GM save by not molding the buttons out of grey plastic? But at least they said they'd replace them under warranty. Also the bezel where you load CD's was worn, but they said they'd replace it under warranty. The hooks in the trunk where the cargo net attaches where broken (warranty again). On the test drive the armrest was really squeaky and they were willing to try to fix that. The wheels had the clearcoat peeling pretty significantly and they were unwilling to trade them with the wheels from another V. I figured I’d talk them down an extra $500 and buy someones stock wheels from the forum.
Now mechanically the car was awesome it has the Corsa exhaust and the sound was amazing. It was loud and throaty when you floor it but quiet when cruising. Also engine wise it was the strongest V I've ever driven (driven a 2005 & a 2007 before this one) and it was even noticeable for the salesman. I looked for signs of mods but as far as I could see it was stock and it passed the CPO inspection so I was pretty happy with it. The Shifter seemed more rubbery than other V's I've driven, but this car has more miles (def. have to get that short shifter kit).
So I talked numbers and got them down to where I wanted them but they wouldn't give me enough for my trade in. They really lowballed me and gave me a bunch of excuses but they had a car in worse shape than mine but the same year with fewer options and were charging $7k more than they wanted to give for mine. I couldn't let them make anywhere near $7k off my car and still feel good about the deal. So I'm gonna try to sell my car really fast for below market rate and if theirs is still there I'll buy it. Overall it had quite a few little foibles but still has the original rear and it's not whining at all. It seemed unusual for a 2 year old car to have so much interior wear but the seats and carpet were perfect and the wear was in the places I expected from reading the forum. Plus since the service manager seemed so willing to replace these things under the warranty I felt ok about them. On most of the stuff he even admitted that a lot of them have these problems.
10-09-07, 11:04 AM
The nav/center stack peeling issues are totally normal, as you know. The offer to switch wheels with another V is generous, just be sure they don't gouge the new ones swithcing them over (seen it happen).
Sounds to me like there's a new V owner in our midst- congrats! :cheers:
m32V
10-09-07, 11:28 AM
Thanks. I'm really excited to get one now and join the ranks here in the forum. After driving a really strong v, I can't imagine how anyone resists buying a maggie for only $5-6k. Although my understanding is that considerable gains can be had from headers, x pipe and stealthV tune, while maintaining a better chance of warranty service than with a Maggie.
10-09-07, 11:38 AM
I did my mods slowly, one at a time. The difference seemed "good", but not awesome.
I drove a stock 2007 V for the first time in a while yesterday, and WOW- it felt sluggish as hell compared to mine (Flywheel, Headers/cats/Corsa and Stealth tune). Resisting mod hell will be difficult, my friend. :)
ctsvflorida
10-10-07, 03:47 PM
I will take your Beemer on trade if you are interested in my 04 V? I saw the description of the V you saw and mine is LIKE NEW! It is on ebay now, it is silver with black interior and kooks, exhaust, tune, cold air and I will negotiate! I will price it to sell it! PM me with phone number or I will PM you mine! I am in NY now but will arrange to make it happen! I am so busy and rarely on here but PM Tony for my number and he will give it to you. Thanks
Brian
m32V
10-13-07, 03:39 AM
Well I sold my M3 to a friend and bought that silver CTS-V. So now I'm supporting member and a V owner. I just love driving this thing. The torque is so exhilarating. So far looks like one of the tire sensors is not reading and my nav is stuck in Michigan. Tire sensor was working when I left the dealer but quit sometime before I got home. Other than those things I'm extremely happy. They said they were going to replace the radio due to the button wear. Will that fix my stuck i Michigan problem or will I still need to obtain the firmware disc?
CIWS
10-13-07, 09:16 AM
I would assume the radio replacement would have an updated flash in it. Sounds like a way to kill two birds with one stone. (buttons / Mich). However one thing you need to check after they replace the radio before you leave is make sure you can put the car in Competitive Driving mode, if all 4 of your tires sensors are working at the time. Some dealerships forget to program the radio with the TechII to tell it its in a V vs a normal CTS. If they forget (or don't know) you won't be able to select Competitive Driving Mode from the traction control.
m32V
10-13-07, 12:20 PM
Thanks for the tip on the com[etitive mode. I'll be sure to check it. Is it common for a tire sensor to quit working? It was just strange that it stopped 30 minutes after I bought the car.
CIWS
10-13-07, 12:31 PM
Not sure how to classify how common the TPS not working is, but it certainly does happen. I would just say coincidence in your case, but no matter it should be a warranty covered item.
m32V
10-13-07, 12:52 PM
The faq says the system that reads the tire sensors also reads the key fobs and one of my key fobs doesn't work either. I guess I have the warranty, so I don't have to figure this stuff out. But was just curious. Thanks.
heavymetals
10-13-07, 01:33 PM
You will need the firmware flash for your nav.
If your dealer is clueless, pm me and I can hook ya up.
However, all flash discs are out so there is a waiting line.
Keys8541
10-13-07, 06:36 PM
how do we get on this list?
