View Full Version : Good deal? Need dealer history. mrwhite 10-02-07, 03:48 PM I've found a local CTS-V in my area. It was originally listed at 30,000 a month ago, and is now 29,000. It has 31,000 miles. Black on black. Comes with corsa exhaust and intake. Is this price about right?
Here's the VIN
1G6DN57S140164163
Thanks in advance for any help. you'll have to become a supporting member first....it's cheap, and all will be willing to help.
http://www.cadillacforums.com/subscribe.html mrwhite 10-02-07, 03:55 PM Oops... Didn't realize I had to be a supporting member. Just subscribed! urbanski 10-02-07, 03:57 PM thanks! :)
let me enable your PMs real quick...thats a benefit, too rand49er 10-02-07, 03:59 PM Oops... Didn't realize I had to be a supporting member. Just subscribed!Unwritten policy around here. BUT, you'll get more info and help on this forum than ten times the cost anywhere else!
Points for becoming a member and ... :welcome: Berserker 10-02-07, 04:05 PM Clean Autocheck history.:cool: Someone else can run a service history for you. mrwhite 10-02-07, 04:08 PM thanks a lot guys. Hope to buy a CTS-V within the week. Redline CTS-V 10-02-07, 04:38 PM Warranty history... Redline CTS-V 10-02-07, 04:41 PM It probably has a broken motor mount. Looks like the previous owner was complaining of the car "dieseling" after shutting the engine off. The dealer said that they compared it to another vehicle and that everything was OK. That usually the concern or description when there's a bad mount(s)... mrwhite 10-02-07, 04:47 PM OK, I might be new to this, but where do you see the "dieseling" complaint? I don't see it.
Overall, it doesn't look like it has had a diff replaced. That could be a really good thing. Possibly shows that he's not romping on it. What do you guys think that I should offer him? Should I buy this car or move on? Is it reasonable to take the care into a Cadillac dealer to have it inspected?
Thanks again for everyone's help. onebadcad 10-02-07, 06:12 PM Just a thought, look into the extended warranty (100K miles/6 years ???) and see if you can get the seller to drop the price to cover some/all of it. If you plan on keeping the car for at least three years and not go to mod hell, this may save you big dollars over time. Good luck with the V, once you own it, you will never part with it!!!!
Check the Forum's Classified section, always a few good ones in there. Redline CTS-V 10-03-07, 06:44 AM OK, I might be new to this, but where do you see the "dieseling" complaint? I don't see it.
You can't see it... On the first line of the warranty history is "Customer concern not duplicated". I looked at the claim information and the notes say that the customer was complaining of "dieseling".
Overall, I'd say the history doesn't look too bad. I second onebad's recommendation on an extended warranty if you are going to keep it for a while... mrwhite 10-03-07, 05:59 PM Thanks for everyone's help thus far. There's another 2004 V available in my area. It's listed at 30,000 with 30000 miles stock. Can one of the dealer's run a check on this VIN?
1G6DN57S640158987
Anyone feel free to give their opinions on which car they would choose. Either other way, I'll be purchasing the GMPP package along with the car. It really comes to purchasing the best car up front though.
Thanks again. lusterblade 10-03-07, 06:10 PM Thanks for everyone's help thus far. There's another 2004 V available in my area. It's listed at 30,000 with 30000 miles stock. Can one of the dealer's run a check on this VIN?
1G6DN57S640158987
Thanks again.
Keep in mind that the 3 items on 04/03/2006 are standard recall items.
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
06/06/2007 014950 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 24645 miles
06/06/2007 014950 # R0760 - RADIO, REMOVE AND REPLACE 24645 miles
06/06/2007 014950 # J1507 - MOUNT, ENGINE - FRONT - BOTH - REPLACE 24645 miles
06/06/2007 014950 # Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 24645 miles
06/06/2007 014950 # F2154 - BUSHING, REAR DIFFERENTIAL CARRIER SUPPORT OR MOUNT - REPL 24645 miles
06/06/2007 014950 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 24645 miles
04/03/2006 083005 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 20350 miles
04/03/2006 083005 # V1302 - 05004 - REPLACE SDM 20350 miles
04/03/2006 083005 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 20350 miles
02/11/2004 358660 # B1794 - CONTAINER, WASHER - WINDSHIELD - REPLACE 10 miles
02/09/2004 A58987 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles chesrowncadillac 10-03-07, 06:18 PM We just purchased a 1 owner 2005 CTS-V -Stealth Gray with Black, with the sunroof. less than 10000 miles for $30900.00. If you want the Cadillac certified warranty add $1200.
I have sold V's to many forum members
David Chesrown
Chesrown Cadillac
8002066966 ext 211 urbanski 10-03-07, 06:53 PM Thanks David mrwhite 10-07-07, 09:58 PM All right, one more to take into consideration:
2004 CTS-V
32,000 Miles
$29,000 OBO
Comes with a corsa exhaust and intake. Does that affect the warranty? I haven't searched about warranty issues. I'm sure it's fine considering if something goes wrong and it's not the intake or the exhaust's fault.
VIN: 1G6DN57S140164163 I'd buy the one from Chesrown first. darkman 10-07-07, 10:39 PM I don't have clue about the intake. The Corsa exhaust however, was a GM licensed add on for the 2004 and 2005 Vs and should have no effect on the waranty. (GM has since gone to licensing Borla exhausts I am told). z06bigbird 10-07-07, 11:55 PM Personally, I would try to locate one still covered by GM warr and with less than 24k miles. GMPP is very affordable with those parameters.
Tons of Vs out there. Buyers' market. mrwhite 10-08-07, 01:21 AM The problem with Chesrown is that I'm located in Arizona, as well as the CTS-V is not black.
Wouldn't the CTS-V with the exhaust and intake still be covered by Cadillac warranty? How much am I looking to pay in order to put a GMPP on a 2004 with approximately 30K miles? lusterblade 10-08-07, 08:58 PM All right, one more to take into consideration:
2004 CTS-V
32,000 Miles
$29,000 OBO
06/12/2007 311537 # J9993 - CUSTOMER CONCERN NOT DUPLICATED 28909 miles
06/12/2007 311537 # Z7901 - 1-DAY COURTESY TRANSPORTATION 28909 miles
05/01/2007 307947 # E7690 - SENSOR, STEERING WHEEL ROTATION - REPLACE 27687 miles
05/01/2007 307947 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 27687 miles
05/01/2007 307947 # H2582 - VEHICLE YAW SENSOR REPLACEMENT 27687 miles
05/01/2007 307947 # R0760 - RADIO, REMOVE AND REPLACE 27687 miles
05/01/2007 307947 # Z7903 - 3-DAY COURTESY TRANSPORTATION 27687 miles
01/04/2007 297669 # C6555 - PANEL, FRONT SEAT CUSHION OUTER FINISH - LEFT - REPLACE 23956 miles
01/04/2007 297669 # Z7901 - 1-DAY COURTESY TRANSPORTATION 23956 miles
12/13/2006 295966 # C0383 - REGULATOR, REAR DOOR WINDOW - LEFT POWER - R&R OR REPLACE 23264 miles
12/13/2006 295966 # Z7901 - 1-DAY COURTESY TRANSPORTATION 23264 miles
08/18/2006 285373 # N4199 - INSTRUMENT CLUSTER REPROGRAMMING WITH SPS 20431 miles
08/18/2006 285373 # J9994 - CUSTOMER CONCERN NOT DUPLICATED 20431 miles
08/18/2006 285373 # B0485 - FRONT AIR DEFLECTOR REPLACEMENT 20431 miles
04/06/2006 273784 # N0110 - BATTERY - ONE - REPLACE 16711 miles
04/06/2006 273784 # Z7901 - 1-DAY COURTESY TRANSPORTATION 16711 miles
08/11/2005 376523 # V1302 - 05004 - REPLACE SDM 11363 miles
01/19/2005 355852 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 7665 miles
01/19/2005 355852 # V1228 - 04068 - REPLACE FF JUMPER PIPE ASSEMBLY 7665 miles
01/19/2005 355852 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 7665 miles
06/02/2004 334715 # E4181 - INSULATOR AND/OR SUPPORT, REAR STABILIZER SHAFT - LEFT - R 520 miles
02/25/2004 A64163 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles | |
