View Full Version : Has anyone broke an 06-07 Rear Diff?
STAGEUP
10-02-07, 01:48 AM
I know the casing is different, and appears to be made of different material. Question is, has anyone granaded an 06-07 rear diff yet? It seems as if my 06-07 diff has been holding up very well, but can it be a ticking time bomb?
STAGEUP
10-02-07, 05:14 AM
BTW, for a quick visual, here is a side by side picture of an 04-05 diff Vs an 06-07 diff. The one on top is the 06-07 diff.
http://i44.photobucket.com/albums/f16/stageup/04-05rear-06-07rear.jpg
ronr
10-02-07, 08:28 AM
I haven't broken the '06 but it needed the vent tube changed (I believe there is a TSB on this) and it lost nearly a quart of fluid before having it changed. The clutches ended up being damaged (loud...LOUD rubbing noise, kinda like brake pads with no lining on a rotor when turning sharp at very slow speeds, like pulling into a parking space). As a consequence I now have a new set of clutches in the diff but everything else is good.
whisler151
10-02-07, 08:30 AM
Nothing here...
P-Funk
10-02-07, 09:16 AM
So far so good.
svassh
10-02-07, 09:22 AM
You sure about that? I thought the 06 had more fins for cooling.
darkman
10-02-07, 09:42 AM
My 06 has significantly more fin area than my 05, by virtual of longer fins. The number of fins may be the same.
whisler151
10-02-07, 09:45 AM
You have a 2006 and a 2005?
Seattle CTS-V
10-02-07, 10:15 AM
I haven't grenaded any of my first 3 diffs. #2 and #3 were both '06 models though and they both ended up whining like little beeotches. #4 is not perfectly quiet, but livable.
RodSmith32
10-02-07, 12:07 PM
My brand new diff has developed a whine, it has less than 2k miles on it. Oh well so is life with a V.
darkman
10-02-07, 12:14 PM
No, I have 2005 V with a recently installed 2006 differential so I have seen both. You can also see the additional fin area on the 2006 differential in the pictures in this thread.
STAGEUP
10-02-07, 01:04 PM
Yes, I also noticed that there is more fin area. And that the cooling fins are longer. I also noticed that the 04-05 diff looked like the casting was very light, porus, and cheap. The new diff seems to be made of better material, and of a much better casting.
fredcook
10-02-07, 07:46 PM
I have an 05, and just got the rear end replaced. It had the one the bottom in your pic... and now has the newer 06/07 version (upper pic).
The old rear had a whine, but had no idea how bad it was until now. 75 miles on the new rear, and still quiet! :)
SLPR 6.0L
10-03-07, 01:02 AM
31K and doing fine. No leaks or whines.
WheelHop
10-03-07, 06:00 PM
200 miles on the 06/07 diff and no whine.. The new rearends didn't happen to come w/ bigger axles do they?
StealthV
10-03-07, 09:06 PM
Nope. The big axles/halfshafts cost big bucks and are a PITA to ship across the country.
gauge hp
10-04-07, 12:17 PM
Your dealer will still warranty yours with maggie and all? Mine won't even talk to me!
SwampFox
10-04-07, 05:33 PM
Didn't break it , but complained about the noise and Don Massey Cadillac replaced it. Picking it up tonight.
No argument or stalling. they are great! 06 w 23k miles.
STAGEUP
10-04-07, 05:54 PM
Been changing the fluid in my 06-07 diff every oil change. Still quiet as a mouse, no clunks, or anything. I think I may have a winner! lol
ronr
10-04-07, 08:39 PM
Mine treats me very well, maggie and all.
WheelHop
10-05-07, 12:41 PM
Do you have any type of diff support!?!?
Also, do new rearends come w/ new diff mount bushings?? Mine diff is brand new and it still clunks!
LV_V
10-05-07, 05:36 PM
Mine's at the dealership right now getting a new diff; I believe its #7 or 8, I've lost track at this point. I just got the BMR Pinion Support Brace in hopes that it would quiet it down or remove the clunk. It helped somewhat, but the clunking and whining is horrible. Hopefully with the new diff AND the pinion support brace, this new diff lasts me longer. *crosses fingers*
WheelHop
10-05-07, 05:45 PM
Not to piss on your hopes, but uhh, mine still clunks w/ the BMR brace and quick clutch petal press... FN annoying.
