akimball442
09-30-07, 05:51 PM
I have an 81 CDV with the buick 4.1 V6. How do you extract the error codes? This has a much different connector under the dash (only 5 pins). I've tried shorting two at a time out, and never get a check engine light flash.
Holding Off and Warmer on the ECC panel gives you the ". ." or "- -" Readout, but you never get the "88." Perhaps this only works on EFI models?
The check engine light is off, but it did come on while driving and go out again. This has only happened once, but I'm curious as to what it could have been.
Any help is greatly appreciated.
Aaron K
Aaron K
