: Northstar motor install
dwalker42
09-30-07, 12:01 PM
Hi,
I have a 98 deville I had to replace the motor that part was easy here's the problem, I can get my car to turn over but it will not stay cranked. The anti theft system shuts the car done. How do I reset this anti theft system? Its weird because if I spray ether on the carborator the engine will start but as soon as I stop spraying the ether the car shuts off. So is there something not talking to the other.
Help!Help!Help! :bonkers:
dwalker42
Ranger
09-30-07, 12:16 PM
Start by pulling the DTC's. The anti theft system is shutting down the injectors. There is no carburetor. It is a throttle body (TB).
Submariner409
09-30-07, 12:23 PM
Excessive use of starting fluid (ether spray) will wash the lubrication off the cylinder walls and valve guides. Be careful.
zonie77
09-30-07, 01:07 PM
Check the fuel pressure. You might have a problem there. It could be wiring or the pump may have failed.
dwalker42
09-30-07, 01:21 PM
Thanks bunches! what are the DTC's? where do I find these and what do I do after I have pulled the DTC's dwalker42
urbanski
09-30-07, 01:27 PM
you really need to use search and read the sticky.
dwalker42
09-30-07, 01:37 PM
Thanks got my answer DTC's are the diagnostic trouble codes! Thanks so much!
dwalker42
09-30-07, 03:45 PM
Ranger, can you tell me how to reset my DTC's for the anti theft system?
Ranger
09-30-07, 07:08 PM
The "sticky" in the Tech Tips section will tell you how to clear them.
dwalker42
10-01-07, 01:46 AM
Can anyone help me? The following codes come up when I pulled my DCT's but I do not quite understand how to reset them. I have the following codes
PZM U1255, PZMB2719, IPCB2750, IPCU1255, TCSU1255, TCSC1276, ACMU1255, RFAU1255, MMMU1016
It appears there is a loss of communication. Is this because I changed the motor, why does the car turn over but will not stay running?
Help!
zonie77
10-01-07, 03:02 AM
You can clear codes by discoing the battery or from the dash (on a caddy) but if they immediately return it means the problem is still there. You cannot "turn them off" if there is a problem.
Did you check fuel pressure??????????????????????
Starting with spray, but not running, usually indicates no fuel pressure or no injector pulse. Please check that. There is a Schrader valve on the fuel line at the intake, check there.
Mark C
10-01-07, 10:59 PM
U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction)
B2719 - CTD-Trunk Tamper Switch Fault
B2750 - PASSKey Data Communication Failure
U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction) Instrument Panel Computer
U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction) Traction Control System Computer
C1276 - Delivered Torque Signal Circuit Malfunction
U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction) ACM
U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction) RFA
U1016 - Loss of Communications with PCM
Are you using the original PCM that came in the car, or did you change it to one that came with the engine? What other changes have you made? New key perhaps?
