View Full Version : Looking for OEM STS 18in rims
jjsocrazy
09-28-07, 05:51 PM
I am really looking hard to try and find the 18in STS OEM Performance Rims. The pic is below:
http://cgi.ebay.com/ebaymotors/Factory-Polish-05-2006-2007-Cadillac-STS-18-inch-Wheel_W0QQitemZ180164010783QQihZ008QQcategoryZ4395 8QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
If someone is selling them or could find them for a good price please let me know. I have the 17in rims right now and I would like to put these on b/c it gives it a look of a 19in wheel and its original.
Thanks!
Benjamin Simon
09-28-07, 10:12 PM
I have a set with tires you can buy for $2K.
LStasy003
09-29-07, 12:11 AM
I have a set too with Michelin Tires..... I have mine for $1500 or best offer
jjsocrazy
09-30-07, 04:06 PM
Now with my car I have the AWD. Will 18's effect the car a lot or be able to fit correctly?
Thanks!
caddycruiser
09-30-07, 07:38 PM
Thanks!
They'll bolt right up, and ride should be very similar, with even better handling. Wheels and such off one STS fit exactly the same on another.
The issue that does come up, however, is that the stock 17" wheel & tire combo is smaller in overall diameter than the 18" wheel & tire combo (because they use the same/similar sidewall heights on both wheel sizes), so if still using the stock sized 18" tires, your speedo and all else will be off noticeably, with the full 1" difference overall.
Front: 235/50/17 --> 235/50/18
Rear: 255/45/17 --> 255/45/18
http://www.1010tires.com/TireSizeCalculator.asp
This is why the 17" wheel & tire combos REALLY do look smaller than the 18's, because the stock sidewalls are the same for both. The solution, I presume, is for either lower profile tire changeout (like a 45 or so sidewall), or a computer re-flash so the car is set to work with the 18" stock combo.
lreddiablo
10-01-07, 04:23 PM
I just got an STS AWD that came with the 18s. How have people done with 20s? Any problem with rubbing and scraping? What size tires are you using?
big kahuna
10-03-07, 02:34 AM
I have a set with the factory michelins,in very good shape with about 3,000 miles on them. I am selling them for a $1,000or best offer! I see you live in N.Y. ,I live in L.A. Im not sure what shipping would be.If you are interested, e-mail me at jvgrim@aol.com,thanks!!!
jjsocrazy
10-05-07, 10:15 AM
Now lets say I wanted to put 20in rims on my car, I heard things that the AWD will be effected, is this true? Will it be able to work without problems?
Thanks!
Onalaska
10-05-07, 10:32 AM
Sounds like going from 17" to 18" would drop engine RPM slightly which might actually give an improvement in gas mileage.
MM STS
10-09-07, 09:31 PM
[QUOTE=caddycruiser;1234101]
[QUOTE]
Interesting I'm looking at the 18" wheels for my 2000 STS and my 16" are the same as the 18". I'd want to go with the recalibrate as the taller 18's would fill the wheel well better. JMO Mike
z06bigbird
10-09-07, 10:37 PM
I have a set of 15s that you can have for $2.00.
